Forced Induction Turbos/Superchargers
Swapping pullies
Old Mar 1, 2007 | 05:20 PM
Admiral Jedi's Avatar
Swapping pullies
Is it SUPPOSED to be a bitch to remove the stock supercharger pulley? Any advice?
Old Mar 1, 2007 | 05:30 PM
xravenwingsx's Avatar
never done it personally--there might be a howto in the appropriate section: just do a quick search, and prepare to buy or rent yourself a pulley puller
Old Mar 1, 2007 | 05:35 PM
Ljavy17's Avatar
taking off the pulley was really easy, and it was also simple to put it back on, as long as you rent the tool from ZZP. Now get ready for a headache when you try to machine your snout.
Old Mar 1, 2007 | 07:15 PM
I have the ZZP puller right now. I'm putting an unbelievable amount of force into screwing it to pull the pulley off, it's making me a bit nervous.
I got it guys, thanks.
Last edited by Admiral Jedi; Mar 1, 2007 at 07:15 PM. Reason: Automerged Doublepost
Old Mar 1, 2007 | 07:18 PM
BallsoutBalt's Avatar
Just keep going dude!!!! It will pop all the sudden and you'll be good.
Getting the new one back on was the bitch for me.
Hello Hammer and a piece of wood!!!
Last edited by BallsoutBalt; Mar 1, 2007 at 07:18 PM. Reason: Automerged Doublepost
Old Mar 1, 2007 | 07:26 PM
spaz's Avatar
zzp rents the snout machining tool.putting the hub on is easy, just use a power steering pulley installer or a nut bolt some grease and a couple washers.
Old Mar 1, 2007 | 07:28 PM
^ LOL ^
Ya it's as easy as that. LMFAO
Old Mar 2, 2007 | 12:02 AM
lol, I just used a big wrench...it worked. I had to have my sister sit on the s/c though to prevent it from rolling.
Old Mar 2, 2007 | 02:16 AM
Doc's Avatar
Doc
No **** I burnt out a brand new drill doing it.
Hopefully you kept going until you heard a pop seriously you think it can't be on this tight then it falls off and you're like 'whew'. Trygetting a pulley hub off....mine popped 4 times. I kept waiting and it finally fell off the end.
Old Mar 2, 2007 | 02:47 AM
repoman's Avatar
I seen where ZZP's pulleys now can go down to a 2.6 without maching the snout.
Old Mar 2, 2007 | 02:55 AM
Doc's Avatar
Doc
some can....some can't...the snouts are different sizes (different amounts of material around it).
Old Mar 2, 2007 | 09:16 AM
Ljavy17's Avatar
Dude that happened to me too, I ussually stopped when I saw a little bit of smoke though, so It didnt end up burning. Took me a while.
Old Mar 2, 2007 | 09:24 AM
06blackg85ss's Avatar
yeah removing the stock pulley is a bitch and a half by itself... and maching.. well I killed my drill a 1/4 way through and did it the rest of the way by hand... so much fun and took like 3 hrs/
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
ernnyyes
Oct 2, 2015 05:16 PM
ThoR294
Sep 28, 2015 05:31 PM
