bypass
Old May 3, 2012 | 05:26 PM
sscrazy28's Avatar
bypass
Hey guys, im running only 4 psi for the past week any suggestions why???
Old May 3, 2012 | 05:27 PM
sscrazy28's Avatar
Stock 2006 supercharged no engine light
Old May 3, 2012 | 05:42 PM
nhanson's Avatar
Check vacuum connections. Also check the bypass and try lubing the bypass rod (i had irregular boost, lubed and it smoothed out)
Old May 3, 2012 | 10:39 PM
bluebalt07's Avatar
Very likely that it has something to do with your bypass valve, whether it just be that rod or something is messed up inside of it
Old May 3, 2012 | 10:56 PM
kkline_83's Avatar
Its an 06 cobalt, stage 2 setup but was doing it in stock form. Intermintent issue here. Has an Injen intake, catless downpipe, 2.9" pulley, 1 degree colder plugs. The CEL comes on but goes off randomly. I see no issue in datastream. Codes it triggers are P0101 & P1182.
Not sure how the bypass works on these cars as far as how they react but if you rev car up from idle, the bypass rod pulls in but then instantly shoots the rod all the way out until car come back to idle then it pulls rod back in. Under load driving, the car maintains 3psi and triggers a CEL. Any ideas to check out?
Old May 5, 2012 | 04:47 AM
robertmichaels's Avatar
The bypass will be open during idle or any high vacuum time, when you get on the gas it creates a load on the engine which will cause vacuum to drop. The bypass want to be closed via the spring that's inside. You could pull the vacuum line off the bypass and plug it to see what you run then.
Also what are the codes??
Old May 5, 2012 | 01:40 PM
kkline_83's Avatar
read the thread
Old May 9, 2012 | 05:40 AM
heathkidder's Avatar
does the pin need to be in the bypass to get vacuum ?
turbochargedss2012
Sep 20, 2023 12:17 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
Hugger1975
Oct 15, 2015 03:28 PM
allpro666
Sep 23, 2015 07:47 PM
DevZX
Sep 16, 2015 06:19 PM
