For discussion of all things Powell!!
Old Jan 10, 2014 | 03:56 AM
  #901
EmperorJJ1's Avatar
yes fell down on that, email me again I ran some extra bolt plates for you last week.
are these still available?
Old Jan 10, 2014 | 06:04 AM
  #902
MajorLazerz's Avatar
What's the price for tower strut bars on a cobalt TC?
Old Jan 10, 2014 | 06:05 AM
  #903
Can you run the triple x sway bar in a stock suspension set up? My cars pretty out of the box... And so far I had the triple x sway bar, the harness bar, and also the strut bars... Any info I should be aware of.
Old Jan 10, 2014 | 07:08 AM
  #904
Powell Race Parts's Avatar
I dont do strut bars as the towers are welded into the firewall not sitting in the middle of nowhere like a Beemer....i would suggest YYZ springs with an XXX bar for track work along with T CABS, you will need snap in lap belts and seats with belt ports for a harness bar if you are heading for le Circuit....reply later, off to NY
Old Jan 10, 2014 | 10:31 AM
  #905
andrewcarr1993's Avatar
Awesome, can't wait to meet up.
Old Jan 10, 2014 | 09:56 PM
  #906
email me john@powellraceparts.com happy to help
Old Jan 10, 2014 | 11:32 PM
  #907
YelloEye's Avatar
Originally Posted by Sox-Fan
John isn't the only mad scientist in the family
My diffent exhaust idea : C6 Z06 B&B Fusion on a C5 Z06 - Corvette Forum
That sounded awesome.
Old Jan 13, 2014 | 02:33 PM
  #908
gonna need some rear cab bushings me thinks, sub'd
Old Jan 13, 2014 | 07:29 PM
  #909
in stock except for rear trailing beam brackets. email works john@powellraceparts.com you can re use your brackets if you have a unibit to enlarge the pivot bolt hole.
Old Jan 13, 2014 | 07:59 PM
  #910
JRCobalt's Avatar
Hey John, have a spacer question!
Want a little more poke for my ss/tc on stock rims. I've read all the threads on spacers, but I'm about to install your v.3 yyz spring so want your approval haha. Tires are 235/40/18
I'm thinking 3-5 mm spacer up front with stock studs
Arp extended studs in the rear with 8-15mm hub centric spacer
Would you anticipate any rubbing issues doing this? Can you do thicker spacers?
Old Jan 13, 2014 | 08:08 PM
  #911
63 Nova SS's Avatar
you dont need spacers for that size tires unless you want them. V3's don't sit as low as say sportlines do, and they are alot better.
Old Jan 13, 2014 | 08:14 PM
  #912
63 Nova SS's Avatar
I must have trained 2500 engineers at GM over the years. John Cafaro is one of the pre emininent designers every to survive the GM culture, he did the C5 , the new Impala and the new truck afaik. Kirk Bennion worked with him back then, Kirk is a super designer; all the folks at design staff there are pretty darn good, again considering the stifling culture that is GM.
Jeff Gordon is one of the best I have ever trained with; smart, sensitive, intellectual, dedicated, fast.
and a regular guy.
so yes.
Got the chance to hang out with him ( Jeff) for a day just after he and Brooke were divorced. Couldn't believe how busy he was. Really nice guy who never came off as being better or richer than you. Had a great time.
Old Jan 13, 2014 | 08:39 PM
  #913
JRCobalt's Avatar
To your first post, yeah the 235's fill it out more but also run 225's on another set. Just want it filled out a little more overall.
Didn't Jeff Gordon divorce his wife 2 weeks before their 10 yr anniversary. I thought that was hilarious, something about the money is split even at 10 years? Jeff Gordon is the man, only reason I was interested in Nascar for awhile
Old Jan 13, 2014 | 09:18 PM
  #914
I didnt read the rear spacer part. that wont work no matter what tires you use imho...email if you need to discuss. tomorrow is busy but I will get to it. so much to get out of here for shipping....
Old Jan 15, 2014 | 10:54 PM
  #915
armcclure's Avatar
JP FTW
Old Feb 3, 2014 | 06:24 PM
  #916
m33pm33p's Avatar
You should be looking more or less 20-25mm in the front and 15-20mm in rear for a "flush" Regardless at that point you will be rubbing with those tires and yyz I bet.
Old Feb 6, 2014 | 09:15 PM
  #917
Bad-A-SS's Avatar
Hey John, what option is the best for the swaybar end link? Seems like the front end of my car whenever i make a turn it makes a popping or kind of slapping sound. Any ideas thanks
Old Feb 6, 2014 | 10:30 PM
  #918
Powergrid, Inc. ask for chip tell him i sent you, If you are in canada i carry these in stock.
alternatively, the Moog drop link is cheap and very robust, a little agricultural compared to the powergrid but if you dont want adjustability and are concerned about bux, go mooog
Old Feb 7, 2014 | 02:38 PM
  #919
Bad-A-SS's Avatar
The moog I found is 9.86" and cost 20 bucks. Will this work? MOOG Part # K750012
Old Feb 7, 2014 | 02:46 PM
  #920
rico's Avatar
The 2004 Ion Redline had a supercharged engine and transmission that would make it to the 2005 Cobalt SS until 2007. But the 2004 Redline had a unique cradle and front engine mount. This is our exclusive all steel rotated front mount for that car. No one else does mounts like this for the Redline 2004.
I think I'll need this gotta check if my car has it or no from previous owner
Old Feb 7, 2014 | 02:50 PM
  #921
Staged07SS's Avatar
Administrator
Administrator
Yes, that is the proper part number for the FE5 suspension.
I've been running Moog endlinks for 3 years now.
Just an fyi, paint them if you don't want them to develop surface rust.
Old Feb 7, 2014 | 03:06 PM
  #922
Bad-A-SS's Avatar
I mean I figured for 20 bucks you couldn't beat that at all. And thanks for the tip if I get them I deff will paint them.
Old Feb 7, 2014 | 07:22 PM
  #923
Also make sure you grease the Moogs before installing them.
Old Feb 9, 2014 | 11:48 PM
  #924
rico's Avatar
Yes, that is the proper part number for the FE5 suspension. I've been running Moog endlinks for 3 years now. Just an fyi, paint them if you don't want them to develop surface rust.
Can u use those an a redline too ? Or just lnf ?
Old Feb 9, 2014 | 11:51 PM
  #925
redlines are longer unless u upgrade the arms etc.
