Engine Swap Compatibility
Old Jan 12, 2025 | 04:20 PM
Reef's Avatar
I have in my possession an 07 ss 2.4l 4 speed auto with a rotted out frame, my goal is to take out anything and everything I can and put it in another 2dr shell, my question is what are my limitations on options?
My intuition tells me as long as I take all of the electronics and wiring along with my motor and trans I won’t have any issues unless my roller was from a manual? I suppose this is the main yes or no answer I’m looking for.
Old Jan 18, 2025 | 01:46 PM
KMO43's Avatar
If you grab a 2 door shell with the same ECU plugs it would be an easy swap. You can pull your 2.4L and leave the engine wiring harness all attached and just unplug from the firewall. These engines are basically the same other than a couple small differences. If you get a VVT 2.2L shell with the same ECU plugs you should be good to go.
Old Jan 18, 2025 | 02:04 PM
Reef's Avatar
Much appreciated info, thank you!
Old Jan 18, 2025 | 02:09 PM
KMO43's Avatar
No problem I'm happy to help. Best of luck with the swap
Old Jan 7, 2026 | 12:38 PM
erween@'s Avatar
agent007kimball
Jun 23, 2015 10:56 PM
biniecki
Sep 19, 2013 11:53 AM
younggun11
Nov 15, 2009 11:21 PM
Blood Lucky Picnic
Oct 7, 2007 12:31 PM
DarkCobalt13
May 8, 2007 09:14 PM
