Methanol pros and cons
Old Aug 23, 2012 | 01:46 AM
  #101
killtank's Avatar
so... what do I need to start a meth lab again? you all confuse the **** out of me!
Old Aug 23, 2012 | 02:57 AM
  #102
Frogstofall's Avatar
Well depending on what you have in the mix, how big the nozzle is and where its set to come on it may or may not affect anything. I would assume at the very least it would make your car stumble a little bit when it activates. Worse case it floods so bad that you shut down. Personally, I wouldn't run it without being tuned shortly after if not the same day.
As far as a having it to where you don't run it all the time... Thats kinda how the stuff works anyways. It doesn't constantly run (unless you have it set that way which would be pretty much unheard of). The idea behind them is to come on when the motor is under load and making power ie, under boost. I've never owned one myself but from the research I've done it sounds like the resovouir lasts a good while if you don't constantly floor it everywhere you go.
The other alternative would be to have two separate tunes where one is your track tune that you have the meth run at and the other would be a much less aggressive/conservative daily tune where the meth does not initiate what so ever. This would require you to always know which you're running so you can have the system on and ready to go or off so you don't flood your system.
OR
Just do E85 (j/k )
Old Aug 23, 2012 | 03:09 AM
  #103
Murdered SS's Avatar
Ok i see well i have a 3m nozzle and it's set to activate at 10psi. also whats the best way to have 2 tune set up and how can i switch them safely and quickly?
Old Aug 23, 2012 | 06:48 AM
  #104
armcclure's Avatar
Originally Posted by Chevycobaltss3
the roots style system is a like two 8s rotaing together so with one revolution of the rotor (8) it pulsates
uh.. there's 3 lobes
And btw when i was saying the rotating mass efficeny, i should have said ( the rotating masses max revolution based on tensil strengths, bearings, etc)
thank you
First and formost, I have been talking about the actual revolutions of the sc mechanical parts. I was stating over spinning them can cause issues.
uh.. no you weren't. you were trying to teach people about methanol injection which you don't fully understand
Now onto more about the compressor map. Say your pushing 1.5 bar which is 22.05lbs, after the Baro pressure has been accounted for. already begining your around 50% efficient, now rev out more and inlet flow goes up and the temp gets higher from the air passing through the rotors which will cause the efficieny to go down.
but you said....
Originally Posted by Chevycobaltss3 in previous posts
Infact the efficiency of the blower will never change.
Oh ok, we'll what's happening is the efficiency of the blower stays the same.
No matter what the efficiency of the actual sc will never change.
Going with a prerotor meth kit doesn't make the sc more efficient.
Now more onto the meth, throwing in meth/water yes it does seal the system better and may cause more boost because of the seal.
but you said it didn't....
But the m62 isnt a 100% flow, its a pulsating type system (roots). And more, lowering the temps within the oncoming air in the sc makes the efficieny rise if it lowers temps enough.
again.. the meth cools temps AFTER the blower, not before.
go ahead and change your words and edit your posts. i still have you quoted.
Originally Posted by Frogstofall
I'm sorry James but you need to stop. You aren't helping man. I'm sure we all appreciate you trying though.
i tried not to be a dick at first....
Old Aug 23, 2012 | 07:04 AM
  #105
Vander Nars's Avatar
I think the problem here is all the techical info is getting confusing, what james was trying to say i believe is that spraying meth dont make the sc more efficient there for is still a bad idea to over spin it, but with meth injection u can take the blower past its efficiceny. I dont see the need to argue this anymore just for the sake of disproving eaxh other
Old Aug 23, 2012 | 07:11 AM
  #106
Dart_SI's Avatar
I don't see arguing. Just some good info being posted.
Also, when you have someone who has a big influence on a lot of members here and he posts info that is not fully accurate, do you think they know that? He tunes a lot of guys on here and im sure they stand by almost anything he says about a technical topic because they look up to him. In a similar way I look up to my tuner and listen to almost everything he teaches me.
Old Aug 23, 2012 | 07:19 AM
  #107
armcclure's Avatar
That's the issue. Spraying meth pre blower DOES make the blower itself more efficient at moving air.
Old Aug 23, 2012 | 07:21 AM
  #108
armcclure's Avatar
That is EXACLTY why i even bothered with this. I don't care to argue with james just for fun. That would be pointless.
The time i spent putting my posts together and rounding up information was for the other ppl on this forum to learn from, not to just disprove someone.
Old Aug 23, 2012 | 07:42 AM
  #109
I wasn't trying to be a dick I was just trying to stop the bleeding. He was going on a tangent and I don't think it was helping.
Glad to see you here in this post armcclure. You've posted some very accurate and objective info.
Old Aug 23, 2012 | 08:23 AM
  #110
armcclure's Avatar
Oh i wasn't accusing you lol
I'll admit i started being a bit of a dick as this thread went on and for that, ccss3, i do apologize. My intention wasn't to just call you out but to put correct information on the table.
We all like to sling a little mud every now and then though :P
Old Aug 23, 2012 | 08:30 AM
  #111
armcclure's Avatar
Originally Posted by 100% METH
I'm well aware that 2.0 PR is 14.7
On the other hand since this thread is to be informative, this needed to be addressed. Most don't have a concept of what PR is.
And most ppl don't realize that where some of us run this blower every day is almost off the top of the map, yet gains are still made
Old Aug 23, 2012 | 09:59 AM
  #112
Ill be honest u seem like a nice guy and you answered alot of my questions on redline forums and Im thankful for that but they way you was coming off seem to me like u wanted to pick a fight, you told him to go ahead and edit his post because you have him quoted and then posted a pic of a gun, that was egging him on just to fight with him. U made ur point that with meth you can gain more power due too the rotors having a better seal, and im pretty sure james agreed with that also.
Old Aug 23, 2012 | 10:31 AM
  #113
alerosaint's Avatar
^^ this. I understand what james means. Im not a guru or nothing but from my past supercharger experience, I know meth helps you run your SC past its regular effiency range. The SC efficiency range is not gonna change because is it physically built to support that range. Like someone said earlier meth is a crutch. It just means you can use productively use it beyond its range. When the meth runs out, that crutch is gone and that supercharger is exactly where that map showed it suppose to be relative to the speed you was running it at. Its gonna be either range, in my case 2.8 stock pulley or out of range, my case again 2.6 pulley. But I will say i did get good info i never knew from both sides.
Old Aug 23, 2012 | 10:44 AM
  #114
armcclure's Avatar
I did start becoming a dick because the crap he was throwing back at me was rediculous.
Maybe james agrees now, but earlier on he specifically said i was wrong. I posted that pic because he is backpedaling and saying different things now than he claimed earlier.
Old Aug 23, 2012 | 10:51 AM
  #115
armcclure's Avatar
If you're talking about the compressor map, then yes, it doesn't change unless the factors used to create it are changed (w/m sealing rotors)
One of the points i was trying to make is that the efficiency of the blower at Xrpm CAN change due to outside actions. Anything that changes the pressure ratio without changing anything about the blower (same rpm/cfm) DOES change the efficiency the blower is operating at.
For example, say you have a stock car making 12psi. You add a header and catback and this is The ONLY thing you change. The boost drops, lowering the pressure ratio, and moves the blower into a higher efficiency range on the map.
You have just raised the operating efficiency of the blower without even touching it.
  #116
Chevycobaltss3's Avatar
I said its like (8), i didnt say its like a triangle because i dont have a pick within my laptop to put it so i couldnt give a visual. Which it still pulsates and yes i know there are thress lobes. I have a few m62s sitting right night to me
thank you
And yes i was actually talking about the actual scs abilitys not the efficieny of air coming out in a few of my posts.
See now this is where my words are getting jumbles up. I said the efficeiny within the actual Blower doesnt change. I wasnt speaking towards the actual sc airflow. ( i was meaning tensil strength)
but you said....
Now on to this comment, i am stating by cooling the air that is passing through the rotors and etc makes the boost more efficient (sc more efficient) spraying meth preblower lowers the incoming air after the rotors. but once the sc in sprayed preblower, the actual housing also is cooler so therefore it does cool it a little!
Now onto editing my posts, the only post i edited is where i incorrectly wrote somthing so i was not understood. So i changed it so i was understood!.
Now yes this argument or whatever you want to say it is is a very big misunderstanding. Here is why, you were talking about the blower efficiny changing due to cooling the sc down so therefore lowering temps down. I was mainly talking about the sc itself meaning the moving compnets .
There were parts where i said the efficieny of the blower isnt changed, this is where i was saying the actual blower rotating objects dont change within its strengths. Now onto the other parts where i said the meth preblower doesnt change the efficiency of the boost. I did say say it didnt change efficieny at first, mainly because i was thinking about somthing different. (thinking). Now you are right, in alot you have said and i wont argue.
But you saing i dont understnd the full amount of meth is eh. (incorrect) I understand it i just speak differently so understanding what i am saying is hard lol.. I am sure you can see that.. But anyways im done arguing!
Old Aug 23, 2012 | 10:54 AM
  #117
is someone not allowed to change there opinion? has no one ever told u ur wrong before? Im not saying ur wrong, im just saying people will have a difference of opinion and sometimes they will be new info that comes forward and they will change their opinion.
the only thing iv seen him say you was wrong about is meth making the SC unit more efficient, he said the air becomes more efficient but the unit it self is the same, either way u cut it it still comes out to meth making more power for the sc.
  #118
armcclure's Avatar
I know you know that. That was just a jab. Sorry.
But what about the rest?
Old Aug 23, 2012 | 10:58 AM
  #119
armcclure's Avatar
I have been wrong before. And if i am i admit it and move forward. The issue is that he never admitted to being wrong, instead just stating more opinions that contradict his earlier ones.
And meth does raise the output efficiency of the blower. You can't change the efficiency of air because it has none. No physical object does. Only actions do. Such as the action of the blower moving air.
Old Aug 23, 2012 | 11:02 AM
  #120
Im not trying to debate that, i wouldnt have a clue so I wouldnt comment about it, i was just saying that seems what james was talking about.
Old Aug 23, 2012 | 11:13 AM
  #121
armcclure's Avatar
Originally yes. Then one thing led to another and here we are.
Yeah i started getting shitty. That happens sometimes when sm1 tells you you're wrong in a shitty way. I'm incorrect and repulsive? Don't think so. I've been stating facts and science, and he comes back saying i'm wrong with no proof, just his opinions. Yes, that's going to **** me off.
Old Aug 23, 2012 | 11:27 AM
  #122
alerosaint's Avatar
Thats one thing that meth does, create a temporary conditions to allow your sc or tc to be usable in otherwise useless ranges. I wouldnt say efficiency of the air you can change but the "p"(density). Cause that what allows the sc to be more "efficient". That and that alone.
Another argument can be had where meth dont improve the sc efficiency because of where the meth is introduced. Some recommend that the meth be introduced after the rotors cause it can strip the rotors of its coating evenually making the sc physically less effcient. So in that situation the sc efficiencies is not improved but you will be introducing cooler, denser air into your system to make gains off of
Old Aug 23, 2012 | 11:29 AM
  #123
Am I wrong? To a certain point. Confusion just got into place because we were talking about two different things.
Te compressor map shows the actual efficiency along the boost and etc. so of course if air is cooled down or if the actual sc is cooled down the efficiency will rise because. The sc isn't making heat any longer
Old Aug 23, 2012 | 11:35 AM
  #124
alerosaint's Avatar
this how the convo went:
such an informative thread yet no mention of it's effect on blower efficiency....
Blower efficiency isn't rated at a more cfm or lifespan due to meth. Infact the efficiency of the blower will never change. A mechanical part will have its set efficiency due to its rotational mass. And etc
Originally Posted by 06cobalt racer
i think maybe he was implying that when you use meth you raise the efficiency of the blower because you can run a smaller pulley without raising the heat too much?
idk, but i agree with you that as long as you dont change the inner works of the blower then you cant really change the efficiency.
Oh ok, we'll what's happening is the efficiency of the blower stays the same. What's changing is what you can get away with. Basically like putting a bandaid on . The efficiency of the sc is set so either it is making to much heat or limited on airflow per boost . So all that's really going on is the methanol raises octane which then acts as the main key holder to get more out Of the engine by pushing the forced induction passed its efficiency range.
Oooh ok. Thank you so much for explaining that. So the boost gain that a properly set up pre-blower meth injection kit provides MUST be magic.
I'm not talking about the damn irrelevant compressor map. I say irrevelant because so few ppl know what it actually means or how to read one.
No matter how good a blower is machined, there is a gap around the rotors. W/M seals this gap up some and therefore increases the output effeciency of the blower. More air per revolution.
I dont not see any attitudes in any his earlier post. You the one that got riled up. Has attitude was in response to yours. Every action have a reaction. IJS. Probably if your reply was expressed in another way it would have been more of a debate than argument.
Old Aug 23, 2012 | 12:33 PM
  #125
armcclure's Avatar
what pissed me off was instantly being told i was wrong based off of an opinion.
if he would have stated his opinion with facts to back it then we could have had a nice little debate.
are you saying air density alone affects sc efficiency?
while density does play a part, it is far from the only variable.
i sat here and debated on weather to go into this or not, but because you brought it up i will.
spraying post blower does increase the operating efficiency (where it is in the compressor map at that moment) of the blower in a different and very small way.
it might help to mentally take a freeze frame of a WOT pull to understand this..
take that "frame" and imagine one spraying post blower and one not spraying at all.
the pressure in the IM (boost) is a representation of the amount of air in that confined space (IM)
the combined gas law
comes into play here. (this formula only works with si units)
now for me to plug in numbers and demonstrate exactly, i'd need to take a little time and convert everything over to si units, and if you guys want me to i will, but this will do for now.
in the freeze frame with no meth, those numbers go in the "1" side
so you have a given pressure, volume, and temp.
now add the w/m.
when the w/m is added, it absorbs heat from the air, decreasing the temp. (we all know this)
i'll throw some example numbers in here to give you an idea. (this is not exact numbers, but the ratios will change in the same direction)
say you have 10psi, 10cf, and 100*
10x10/100=1 <-- this is the "constant" that the other side of the equation must equal.
now with w/m added, the temp goes down to say 75*
volume never changes
So, in order for the law to hold true and get our "constant" of one, and volume didn't change, pressure has to.
so rearrange the equation a little, and we get (Tx"1")/V=P
our new temp is 75 so
75x1=75
75/10=7.5 <-- new psi
lower psi= lower pressure ratio
and if we go back to our compressor map, specifically in the areas that we normally run this blower, we can see that lowering the pressure ratio increases the operating efficiency of the blower.
some might say "yeah but you're putting meth in there so it's more stuff in the same volume" and they would be right IF the density of w/m and air was the same. w/m is so much more dense than air that the added molecules vs the heat they absorb is negligable in this estimated calculation.
now i am NOT saying you're going to see a boost drop spraying bost blower. like i said this is very small.
but, i just wanted to make it clear that spraying meth pre OR post blower does, in fact, have an effect on the operating efficienty of the blower.
