Methanol pros and cons
Old Aug 25, 2012 | 02:09 AM
  #151
Frogstofall's Avatar
Originally Posted by Murdered SS
So what will happen if someone runs meth without a tune? also what if someone is tuned for meth but doesnt want to run it all the time and turns if off but is still tuned for it?
I'm pretty sure I answered this a couple pages back, no?
Old Aug 25, 2012 | 02:16 AM
  #152
Murdered SS's Avatar
yea you did sorry but my next question is if i get tuned for meth do i have to run it all the time. what if i shut it off? how can i run it safely do i have to have 2 different tunes.
Old Aug 25, 2012 | 02:17 AM
  #153
kdub1492's Avatar
Why would you want to shut it off? It's not flowing all the time, most systems are based on boost pressure, so are only spraying at a certain PSI
Old Aug 25, 2012 | 02:19 AM
  #154
like i mean what if i dont want it to spray at 10psi and i just want it shut off? do i have to run it?
Old Aug 25, 2012 | 02:24 AM
  #155
kdub1492's Avatar
If you are tuned for it then yes. When you get a tune and you are on meth many things will change. If your car is at say 25* advance at WOT while on meth, but then try that 25* WOT without meth you will be fucked. Not those exact numbers, but you get the idea
Old Aug 25, 2012 | 02:27 AM
  #156
ok coo so if im tune for meth and shut it off car will run really **** or boom.
Old Aug 25, 2012 | 02:28 AM
  #157
kdub1492's Avatar
Pretty much
Old Aug 25, 2012 | 02:31 AM
  #158
ok thanks for the info kdubs how can i have a tune set up where i can switch tunes? is there a way this is possible sorry for the noob questions but i'm new to meth kits? thanks in advance
Old Aug 25, 2012 | 05:51 AM
  #159
armcclure's Avatar
Not without HPT.
If
You want to run meth, ecpecially for the octane boost, it's going to have to be on at wot. If you don't want it to tirn on for some reason then just stay under the boost switch setting. Simple.
Old Aug 25, 2012 | 09:35 AM
  #160
TStone's Avatar
You can get meth, have the car tuned for meth, and still drive it every day just fine.. AS LONG AS you stay out of boost. You won't be able to go WOT with your meth tune UNLESS you have meth, and your system works properly.
I leave my tank empty for like a week before I fill it. Keeps me out of boost but saves money
Old Aug 25, 2012 | 09:58 AM
  #161
06cobalt racer's Avatar
lol as long as you dont forget that it is empty!
Old Aug 25, 2012 | 10:02 AM
  #162
TStone's Avatar
Haha it's hard to forget when a blinking LED is right in your face for a week straight
Old Aug 25, 2012 | 01:37 PM
  #163
sLAsh's Avatar
Simple visual for those that may have had trouble following the debate about supercharger efficiency increasing due to rotor sealing.
Stock SC is like a bucket with a hole in the bottom. It has a fixed volume but some is lost each time before you can dump it. Meth effectively seals the rotors to the case like plugging the hole in the bucket. You can move more volume each time(bucket load or SC rotation)making it more efficient.
Typed on my iPod so sorry if it isn't as clear as it should be.
Old Aug 25, 2012 | 08:43 PM
  #164
armcclure's Avatar
great analogy!
Old Aug 25, 2012 | 11:13 PM
  #165
I get it thanks for the advice guy. I need a tune now lol
Old Aug 26, 2012 | 10:23 AM
  #166
lol true
Haily229
Sep 17, 2015 07:18 AM
Highgross89
20
Sep 11, 2015 03:24 PM
