Other/Misc: How-To: Install a rear tow hook
Old Mar 14, 2012 | 07:02 PM
  #151
MastaShaKe_88's Avatar
i couldnt find any pics of his, but I'll pm him.. I'll send ya a pic in a sec..
Old Mar 14, 2012 | 07:19 PM
  #152
maybe i can cut a slit in like whyyoumadson? did?
Old Mar 14, 2012 | 10:11 PM
  #153
conerboner's Avatar
I would like to know how to mount one on the rear with that lip as well. That lip looks even better with dual exhuast but i'm too cheap to pay a shop 400 bucks to put a y pipe and two mufflers and two tips.
Old Mar 20, 2012 | 02:26 PM
  #154
ei3dag3's Avatar
subd
Old May 22, 2012 | 12:49 AM
  #155
PyroSiege's Avatar
id be worried that resting on the rear lip would take the paint off after rubbing for a while
Personally? If I got these, I would just leave the hook part off, leave it in my car with the proper wrench to tighten it, when/if I need to tow my car, then I just put it on.
Because I would have the same concern. I wouldn't want it flapping around while I'm accelerating/shifting.
That's just me. Haha.
Is there an actual reason people leave that floppy end on there all the time? Maybe I'm missing something?
That fascia looks awesome... haha, WANT!
Old May 22, 2012 | 01:41 AM
  #156
YelloEye's Avatar
Because in a crash that little tube of metal is more likely to get smashed flat than if it has the pin already in it.
Old May 22, 2012 | 10:29 AM
  #157
Maven's Avatar
Just keep the wrench in your car and make the bolt tight so it can't flop. Loosen it when you need it.
Do you really need to ask why they leave it on? Same reason they get them in cool colors ......because they look neat
Old May 22, 2012 | 04:03 PM
  #158
PyroSiege's Avatar
That makes sense. But at the same time, If that part is bent, chances are the rest of the car is in pretty bad shape too. I guess it makes it easier to pull it out of a ditch or something. I guess i was thinking more if something goes wrong on the track and you need a tow, chances are you could probably just put it on when you need it.
That happened to me when my shifter roll pin went, I needed a tow. One of those hooks would have been handy.
I guess that's the part I don't get.
Old May 22, 2012 | 06:45 PM
  #159
YelloEye's Avatar
I leave mine on cause I'm lazy
Old May 22, 2012 | 07:04 PM
  #160
BoostedBeaner's Avatar
i just installed my rear hook. think ill be lazy too lol
Old May 23, 2012 | 02:59 AM
  #161
Crav3's Avatar
I have that rear lip and a y with dual exhaust looks real neat and didn't cost me $400 to install
Old May 23, 2012 | 09:04 AM
  #162
^^this , do you have a rear tow hook tho??
Old May 23, 2012 | 10:09 PM
  #163
conerboner's Avatar
i'm thinking about doing dual exhaust with no mufflers but i think it would be too loud and get old quick haha
Old May 23, 2012 | 10:58 PM
  #164
I got no mufflers, but I got the SLP resonators on each pipe, it sounds pretty good
Old May 24, 2012 | 01:45 AM
  #165
PyroSiege's Avatar
Also a very valid point.
Old Jan 21, 2014 | 04:35 PM
  #166
Bubba0623's Avatar
May just have to cut me a few of these out ;-) I love being a waterjet operator!! Cool guys thanks!
Old Oct 25, 2014 | 02:07 AM
  #167
Cornhusker's Avatar
How do you just "drop the bolts" through those holes? I cant find a way to......
Old Nov 1, 2014 | 02:50 PM
  #168
YelloEye's Avatar
How do you mean?
Old Nov 1, 2014 | 04:03 PM
  #169
andrewcarr1993's Avatar
I ended up removing the rear bumper and crash beam just made it so much easier and I know it was done right then.
Old Nov 2, 2014 | 10:05 PM
  #170
Cornhusker's Avatar
I just realized you drill the holes all the way through the bar. I drilled a hole on one side and tried to put the bolt through that way.
Old Nov 3, 2014 | 11:57 AM
  #171
Powell Race Parts's Avatar
you buy hooks from us you get a detailed how to. Not sure how it is complicated. It doesnt require bumper removal. It does really take a good unibit otherwise a very good drill bit. The bumper metal is very strong and hard. I use one existing hole at the front on Cobalts and always install offset to the curb side for safety when hooking up. I had a guy I knew well, he was killed by a passing car when his race car trailer got a flat tire drivers side, and he was changing it on the shoulder....
justinchinn
Oct 2, 2015 12:18 PM
OrangeCoba
Oct 1, 2015 10:00 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Delta coupe
Sep 30, 2015 08:11 AM
