2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
he gave them his car to do some things to. actually quite a bit of things to do. instead they decided to take apart his engine and craft aftermarket parts to sell and they never completed what he wanted them to do. they just used his engine as an aftermarket guinea pig
FYI: To add to this parts list, any 2.2L WITHOUT AC will need to buy an AC Condenser to just SIT there and spin or if there is an a/c delete kit of some sorts you can buy for it to sit there... that would work as well.
just finished supercharging however I need to fix some of my setup since car isn't running properly (long story, I have 3 things I need to check)... You need to cut one of the ribs off the belt for it to fit since our pulleys only use 4 ribs and the s/c's have 5 ribs.
as for the belt, LSJs run 6 ribs, we run 5. You were just off by a rib. no biggie
yeah that's what I thought too cause I started looking for an AC delete kit, I couldn't even find one for a cavi with the eco maybe they make one for the sunfire but it wouldn't work for us most likely cause we have the 2 sided serp belt
Rob great info about the just got mine installed! thanks alot!!!! now just waiting on my injectors and harness which should be here this weekend maybe get tuned next weekend... given I don't have any other issues!
here's my car domain account that has all my build info on it... Thanks again for the tech support!
added some more pics today with the intake installed and belt and map sensor also installed. Do you have a cardomain account?
http://www.cardomain.com/ride/2366623
Heh oh well... my supercharger is installed & working... HOWEVER I have a vacuum leak I need to track down & fix. So it will be a bit while I troubleshoot to fix
where did you get your map sensor connector from? you did end up using an SS map sensor right? I have been trying to track one down and the only one my local dealer can find is the only one available right now and they want 96.00 for it... :-S insane! so with that said this is the only thing I am waiting on now thanks again for your help.
I have a fix for using the SCIP sensor in the intake manifold. I'm about to go out in the garage and work on it and then I'll post my pics.
Last edited by Gene Culley; May 28, 2009 at 07:21 PM. Reason: Automerged Doublepost
You'll have to buy the connector that I bought lol.
Which map sensor connector do you want? The SCIP or the 2.5 bar map? I can help you out with it for less than that.
It is a pigtail that will have to be re-wired.
If you got the real Stage 2 injectors (42.5lbs) they have a different connector. I ordered the injector wiring harness from a 2005 Cavalier. It has the same connections and it also has the right injector connectors.
I won't know if I need a plug until I get my injectors monday or tuesday cause the guy was cool and is hooking up a harness too... its for the stage 1 injectors(42#) so I would assume it should plug into the map sensor which is the plug I was looking for cause I have a harness that works with the stock lsj injectors but it doesn't plug into the map sensor... I will let you know either way thanks!!!!
Last edited by Gene Culley; May 29, 2009 at 08:27 PM. Reason: Automerged Doublepost
I have to rewire a stock 2.2 harness I bought.
I am getting the harness from the seller of the injectors already in the mail... so I need to wait and see what plug is on that harness. I believe it should be the right one thanks for the heads up tho...
While it may be the correct connectors for the injectors purchased, it doesn't mean that the harness will fit your car. It is probably going to be for an LSJ, not an L61, LE5, LAP, etc.
