2.2 L61 Engine: Hunter's How to Install M62 on 2.2l Cobalt
Old Jan 13, 2011 | 07:53 AM
  #376
Jeffs 06SS 2.4's Avatar
Will this guide work for the 2.4? Is there a 2.4 straightforward supercharging guide? Thanks.
Old Jan 13, 2011 | 08:51 AM
  #377
MP81's Avatar
Yep, it's the same, other than some small wiring differences. The physical installation is the same, yes.
Old Jan 13, 2011 | 09:01 AM
  #378
COLER59's Avatar
sub'd sweet write up bro..congrats..
Old Jan 13, 2011 | 12:31 PM
  #379
COLER59's Avatar
I read yu need a tune to perform supercharging..i have a trifecta tune alread would i need a new tune or just a retunE..or none at all...
Old Jan 13, 2011 | 12:39 PM
  #380
MP81's Avatar
You would need a retune. I think trifecta charges $75 for that.
Old Jan 20, 2011 | 02:55 PM
  #381
pep22's Avatar
Thumbs down
what size and brand fuel injectors are you running on your cobalt?
thanks.
Eric
Old Apr 8, 2018 | 02:40 PM
  #382
ChefordSS's Avatar
For swapping the washer resevoir over to the passenger side, any brackets needed? Cutting? Etc etc. What' needed to complete other than LSJ washer jug
Old Apr 8, 2018 | 02:57 PM
  #383
MP81's Avatar
ZZP sells a bracket to do just that - bolts right in.
https://zzperformance.com/ecotec/opt...ervoir-bracket
Old Apr 8, 2018 | 04:30 PM
  #384
ChefordSS's Avatar
That's for the option b....i was referring to the washer fluid canister.....on the 2.4L LE5 they are on driver side.....the LSJ intake will go there and the washer fluid resevoir moves to the passenger side.
Old Apr 8, 2018 | 05:26 PM
  #385
MP81's Avatar
Ok, you had said the coolant reservoir, hence my answer.
No, the LSJ washer fluid reservoir just bolts in.
Old Apr 8, 2018 | 11:35 PM
  #386
Henry3959's Avatar
Just some extra line and move the wiring to that side
Old Apr 9, 2018 | 06:13 AM
  #387
ChefordSS's Avatar
you mentioned abs pipes....which abs pipes?
Old Apr 9, 2018 | 10:15 AM
  #388
Henry3959's Avatar
Do you have ABS? Check to see if the Hydraulic pipes are in the way of the CAI pipe.
Old Apr 9, 2018 | 10:40 AM
  #389
ChefordSS's Avatar
Oh duh! Im an idiot....i thought u meant ABS as in abs plastic lol....
Old Apr 9, 2018 | 06:45 PM
  #390
chevygirl2006's Avatar
ONLy the 08 le5 has clearance issues with the abs lines
Spanky's Monkey
Mar 7, 2016 06:06 PM
RedLined
Sep 9, 2015 09:11 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
Stardustolol
Sep 2, 2015 09:59 AM
