Appearance: Install rear SS lip on LS bumper
Hmm, I'm going to check to see if the lip can be placed a little higher to compensate for the gap. I have the lip and a bumper cover so I can test fit off the car. Hope to start doing this fit up, this weekend.
I started to mock up the lip/bumper, did some measurements and found that the combination does have about a 1/4 to 3/8" difference nearing the leading edges of the lip. I carefully did some measurements, and I will not be using the lower body line because, it doesn't line up correctly with the 2.4l rear bumper. Basically, at the front leading edges, the lip starts 3/4" higher than the bumper line, then as it nears the license plate, it is around 1/2" higher than the body line. I know that using the body line makes things easier, but, when using the 2.4l rear bumper, there are holes at the bottom of the leading edges of the lip, and corresponding ones on the bumper, When you match these locations, you will see why I ended up measuring up an additional 3/4" above the bumper line.
I didn't take any pics yet, as I haven't started to do any cutting yet. I'm taking a break (after 2 hours of measuring, marking, remeasuring, remarking). I will start using the Dremel to make the slots later or maybe over the weekend.
Well i cut the slots just above the body line (bottom of slots on the body line) , and i have a 1/4 inch over hang on one side and 1/2 inch on the other. And i dont know how you can do 1/2 inch above the body line around the licence plate, because i did it with the bottom of the holes at the body line, and the part that the grill goes in is touching the bottom of the bumper.
After looking at additional pictures, I have to be careful that I don't make the lip sit too high on the bumper. It would leave too big a gap over the exhaust tip. May have to redo my layout.
You shouldn't go above the line on the 2.4 bumper cuz at the bottom corner ends of the lip touch the 2.4 bumper when installed. I cut mine right at the line and it came out perfect. 2.4coupe slots are at the line. If you go 1/2 or 1 inch it's not gonna fit at the bottom ends unless you gonna cut the bottom corners of the bumper too.
X2 on the gap by the exhaust. Just cut at the line dude
When the lip is installed, it's not gonna make the ends by the wheel look lower. I hope you know that. It'll only look lower when you go back and around. Also when you look at it from behind. Those areas are the only places that make the lip installed on bumper look lower. I hope I make sense.
Last edited by hailcesar75; Apr 10, 2009 at 09:03 PM. Reason: Automerged Doublepost
I'm going to take another look at it today, maybe cut new slots, get the old slots plastic filled before I send it off for paint. FYI, I bought a second bumper cover to install the lip, just for this reason, in case things went a muck.
My bumper is off to the body shop. We discussed about how the lip would be modified. The guy who is doing it does custom car body work, etc, and came up with some good, yet inexpensive ideas, for how to fit up the lip properly without doing an extensive amount of work. I should have it back early next week.
Sounds like our guys are on the same thought process. On top of that, the lip for my case, will also be reinforced with lots of glue to keep it tight to the bumper so that those ugly gaps don't appear, especially around the corners. (typical of the left hand corner where the lip touches the rear bumper on the SS coupes)
That sounds like a pretty good idea... I dont think im gonna go that far tho. Looking back right now, i should have just bought the bumper, it would save alot of time, but i guess you really dont have a choice.
Got a message today stating that my modified rear bumper is ready for a test fit before getting painted. Shop wants to make sure that the exhaust cut out lines up with the exhaust tip. Now, with this wonderful weather we are having, the test fit will have to wait till later in the week. I have to take off the OE bumper cover too, before the test fit (of course).
By next week, bumper should be painted and installed.
Make sure to post up some pics! And your lucky you get to keep your car, they guy at the bodyshop im going to says he wants the whole car, so he can fit it on the bumper while it is on the car. Well whatever, he knows best. Yours will probably be done before mine, he figures it will be all done and painted by next friday. (taking it in next tuesday)
have you not read the last couple of pages? This will not work. IF you dont believe me there are 3 other ppl, just in this thread that were unsuccessful. And if you still dont believe me, try it, and then you will realize it does not fit.
