2.0 LSJ Engine: Return-style fuel system for 2.0 LSJ
I am using -6 as well, but the rail comes with -8 and 2 plugs. I figure I can use one of the plugs for it, or put in a bushing to plug in a gauge. The hole was the perfect size to tap for -8. Too big to tap for -6. I am going to get it put together and run the rail plugged at the return end untill I get my pump, so I can verify that it bolts up and doesn't leak. Then when the pump comes in I'll finish the system.
Witt, would it be possible to use this layout above with this FPR directly replacing the stocker and a switch to a 1&1 fuel filer?
Basicly, I'm asking if I would need to add anything outside the fuel tank since the FPR would directly replace the stocker. I'd rather keep it as simple as possible.
Also, are those disk style injectors compatable with any of the currently availble injector harness' (stock, which is Multec if I remember right or the minitimer ones) and fit our engine or would I need to get some adapters? I've found 50# and 78# ones, though I'm not sure if they would fit. I would rather something in the 55~60 range, though I think the 78# ones are way to big for my application.
Delphi/Multec - Original Ecotec Harness
Ev1/Minitimer - Most common Aftermarket
Ev6/Uscar -LE5 and '07+ L61
RC makes disc style in all three, but unfortunately, each size tends to differ by type.
The Ford Racing 52 pound (Actually Ford rates at 39# FP instead of 43.5#'s, so they are really ~58 pound injectors) have mutiple spray holes even though they are pintle style. I am looking into finding refurbished and flowmatched sets of these as we speak. I have already found "blue giants" (rated at 39#, but really 42#) that are refurbished and flowmatched to less than 1% for pretty cheap.
EVERYONE working on return-style systems:
Why does everyone want to do a returnless system that still "dead-heads" the fuel rail?!?!??!?
No, both sides of the rail are already tapped and recessed for -8 o-ring fittings. I am just going to screw in the plug on the return side untill I get all my parts in.
Huh? We are doing return. We already have returnless. Personally, I am doing a passthrough system. Even a system that ends at the injector rail will have the advantage of a rising pressure rate, which will help with keeping the injectors within their linear range.
Everyone I've talked to with similiar setups on ANY vehicle has had this issue with Walbro 255's, so, I don't think they all got monday pumps.
This will be my system when it is done:
Alternatively, I may run the check valve on the input side of the regulator.
Just so everyone who cares knows, stay away from the venom rail unless you like machining stuff! Not only did I have to tap the previously mentioned hole for an -8an plug, but when I went to bolt it up, it hit everywhere. I had to machine a groove where it hit the head, the inlet had to be shortened, retapped and capped and a new inlet had to be drilled and tapped on the top by the #1 injector, because the edge of the rail hit the water neck. What a PITA! I should get it back in the car tomorrow. If it works, I will put the rest of the system together this weekend. Anyone know what fittings I need for the new fuel filter or to connect to the return side of the tank?
Good question. Not really sure, other than I am a plumber and my gut said to put it there.
Well unless the regulator is bad fuel shouldnt leak past it, I would put it shortly after the pump. what fuel filter are you using? If I know that I might be able to help with the fittings, and thats the same problem I had with the fuel rail I tried to make, there's just no room by #1
I just need to know how to connect to the filter and the tank and I'll convert from there to whatever I need. I have a speed shop nearby. I just would like to know what the fittings are, so I don't have to remove the tank and filter to take down there, just to find out they don't have the one fitting I need.
http://www.shopatron.com/product/par....11710.0.0.0.0
