2.0 LSJ Engine: Return-style fuel system for 2.0 LSJ
Old Apr 10, 2008 | 12:56 AM
  #201
SJSchafer's Avatar
Originally Posted by Raven SS
well i would have to have mine tapped for an-6 then since thats what all my line and fittings are...good find steve let me know
I am using -6 as well, but the rail comes with -8 and 2 plugs. I figure I can use one of the plugs for it, or put in a bushing to plug in a gauge. The hole was the perfect size to tap for -8. Too big to tap for -6. I am going to get it put together and run the rail plugged at the return end untill I get my pump, so I can verify that it bolts up and doesn't leak. Then when the pump comes in I'll finish the system.
Old Apr 10, 2008 | 12:58 AM
  #202
Raven SS's Avatar
so u need to tap it for the return?
Old Apr 10, 2008 | 01:13 AM
  #203
lsjwannabe's Avatar
Originally Posted by SJSchafer
That's the great thing about opinions. Even the dumb ones get heard.
likewise
Old Apr 10, 2008 | 03:58 AM
  #204
InfinityzeN's Avatar
Originally Posted by Witt
Witt, would it be possible to use this layout above with this FPR directly replacing the stocker and a switch to a 1&1 fuel filer?
Basicly, I'm asking if I would need to add anything outside the fuel tank since the FPR would directly replace the stocker. I'd rather keep it as simple as possible.
Also, are those disk style injectors compatable with any of the currently availble injector harness' (stock, which is Multec if I remember right or the minitimer ones) and fit our engine or would I need to get some adapters? I've found 50# and 78# ones, though I'm not sure if they would fit. I would rather something in the 55~60 range, though I think the 78# ones are way to big for my application.
Old Apr 10, 2008 | 08:50 AM
  #205
shabodah's Avatar
There are three main types of injectors people are using in ecotecs:
Delphi/Multec - Original Ecotec Harness
Ev1/Minitimer - Most common Aftermarket
Ev6/Uscar -LE5 and '07+ L61
RC makes disc style in all three, but unfortunately, each size tends to differ by type.
The Ford Racing 52 pound (Actually Ford rates at 39# FP instead of 43.5#'s, so they are really ~58 pound injectors) have mutiple spray holes even though they are pintle style. I am looking into finding refurbished and flowmatched sets of these as we speak. I have already found "blue giants" (rated at 39#, but really 42#) that are refurbished and flowmatched to less than 1% for pretty cheap.
EVERYONE working on return-style systems:
Why does everyone want to do a returnless system that still "dead-heads" the fuel rail?!?!??!?
Old Apr 10, 2008 | 09:36 AM
  #206
SJSchafer's Avatar
No, both sides of the rail are already tapped and recessed for -8 o-ring fittings. I am just going to screw in the plug on the return side untill I get all my parts in.
Huh? We are doing return. We already have returnless. Personally, I am doing a passthrough system. Even a system that ends at the injector rail will have the advantage of a rising pressure rate, which will help with keeping the injectors within their linear range.
Old Apr 10, 2008 | 10:12 AM
  #207
Josh@ottp's Avatar
Originally Posted by jgarciarivera
My pump didn't come with a check valve and no its not defective
if its a walbro they all come with check valves. if it didnt have one on it maybe you got a monday pump?
Old Apr 10, 2008 | 10:36 AM
  #208
shabodah's Avatar
I'm sorry, I mistyped. I did mean return style (edited above). My point is that having a dead-head style rail is known to cause contamination to get stuck at the very end of the rail and sometimes cause the final injector to fail. Furthermore, fuel pressure is going to drop after the injectors because fuel is leaving the rail, so you should have better response with the FPR after the injectors. A passthrough system seams to be a better setup.
Everyone I've talked to with similiar setups on ANY vehicle has had this issue with Walbro 255's, so, I don't think they all got monday pumps.
Old Apr 10, 2008 | 10:38 AM
  #209
lsjwannabe's Avatar
hm funny mine works fine
Old Apr 10, 2008 | 10:41 AM
  #210
Josh@ottp's Avatar
so what are you saying? they installed them wrong? they do come with check valves...
Old Apr 10, 2008 | 10:44 AM
  #211
Edubs's Avatar
From what I've heard there are small clearance issues that a little experience can avoid...
Old Apr 10, 2008 | 10:47 AM
  #212
lsjwannabe's Avatar
was really no issue when we installed it, we had the car put back together in 15 mins
Old Apr 10, 2008 | 10:54 AM
  #213
shabodah's Avatar
No, I think we're missing something obvious.
Old Apr 10, 2008 | 10:58 AM
  #214
lsjwannabe's Avatar
maybe but the install was pretty straight forward
Old Apr 10, 2008 | 11:08 AM
  #215
Area47's Avatar
Rent me! per hour
someone go open the hood on a b series honda, or a dsm, and look at how it is set up.
THAT is a return system.
Old Apr 10, 2008 | 11:35 AM
  #216
SJSchafer's Avatar
This will be my system when it is done:
Alternatively, I may run the check valve on the input side of the regulator.
Old Apr 10, 2008 | 11:43 AM
  #217
jgarciarivera's Avatar
It's a Walbro, and again no, didn't come with check valve. I hope on Monday I can install the Earl Performance check valve.
Old Apr 10, 2008 | 12:21 PM
  #218
Josh@ottp's Avatar
why arent you putting the check valve on the feed side right after the pump?
Old Apr 10, 2008 | 12:45 PM
  #219
shabodah's Avatar
I was thinking right after the filter, just so you don't have to worry as much about contamination catching in it and holding it open.
Old Apr 10, 2008 | 12:59 PM
  #220
Josh@ottp's Avatar
sounds like a good plan
Old Apr 10, 2008 | 09:52 PM
  #221
SJSchafer's Avatar
Good question. Not really sure, other than I am a plumber and my gut said to put it there.
Just so everyone who cares knows, stay away from the venom rail unless you like machining stuff! Not only did I have to tap the previously mentioned hole for an -8an plug, but when I went to bolt it up, it hit everywhere. I had to machine a groove where it hit the head, the inlet had to be shortened, retapped and capped and a new inlet had to be drilled and tapped on the top by the #1 injector, because the edge of the rail hit the water neck. What a PITA! I should get it back in the car tomorrow. If it works, I will put the rest of the system together this weekend. Anyone know what fittings I need for the new fuel filter or to connect to the return side of the tank?
Old Apr 10, 2008 | 10:41 PM
  #222
spike's Avatar
as long as it doesnt leak i am going 2 do the thing
Old Apr 10, 2008 | 11:41 PM
  #223
Josh@ottp's Avatar
Well unless the regulator is bad fuel shouldnt leak past it, I would put it shortly after the pump. what fuel filter are you using? If I know that I might be able to help with the fittings, and thats the same problem I had with the fuel rail I tried to make, there's just no room by #1
Old Apr 11, 2008 | 12:00 AM
  #224
SJSchafer's Avatar
I just need to know how to connect to the filter and the tank and I'll convert from there to whatever I need. I have a speed shop nearby. I just would like to know what the fittings are, so I don't have to remove the tank and filter to take down there, just to find out they don't have the one fitting I need.
Old Apr 11, 2008 | 12:09 AM
  #225
Raven SS's Avatar
this is the way to do it so when the car is shut off u have fuel in ur line for the next start up....this is how we do it on the desiels i work on
this is the style thats needed i just dont know the exact size...
http://www.shopatron.com/product/par....11710.0.0.0.0
