Boosting 13.6 lbs w/2.8??
Old Mar 23, 2009 | 10:44 PM
MarqueDo7BabyBalt's Avatar
Now that I have my car back up and running I have been driving it lately and noticing the extra power it was from stock, but with a 2.8 I should be boosting 17-18 psi right? Well I am only seeing a max of like 13.6 to 14 at wot and this is with my scan gauge and manual gauge, so any help or suggestions are welcome...
also my iat's got up to about 140* and went down but that was the highest but i wasnt running back to back at all...
2007 Chevy Balt ss/sc
mods in sig...
Old Mar 23, 2009 | 10:54 PM
StreetDreamz's Avatar
Blown rings? Bad bypass solenoid? /fail on boost bypass in tune? Intake manifold gasket bad?
Old Mar 23, 2009 | 10:55 PM
carbombss's Avatar
im goin with bypass valve opening dumpiing boost
ok so your saying i either have a tune limiting my boost or my engine is blown right?
Old Mar 23, 2009 | 10:56 PM
ok so i can fix this thru my hptuners right? or do I have to buy another one..
Old Mar 23, 2009 | 10:59 PM
If you have HP Tuners and you didn't modify the boost limit tables, then you are stuck at near stock boost, yes. If you are unsure of what to do, you should always ask first. Don't just plow into it because you could really screw some things up when modifying the PCM. Also, get some new tires before the sidewalls on one of your blow out and you die.
carbombss's Avatar
hpt shoud do the trick.......does the car smoke at all?
Old Mar 23, 2009 | 11:23 PM
um first off if you read my sig it says OTTP tuned not self tuned...OK..and 2nd of all these tires have been doing nicely for me and this is my first time with Nexen's but the ride quality is amazing and 3rd of all thx for the help...
yea it should...and when i first started her up it did, but it went away...and now it doesnt
Old Mar 24, 2009 | 08:53 AM
Old Mar 24, 2009 | 08:57 AM
RedEcotecSS's Avatar
mine did that when i went to a 2.8.. my tuner had to load the stage 2 (with fuel trims for 60's, of course) into car car, do a couple pulls, then load in my 2.8 tune. do that a few times. he said he pretty much changed small things in the tune until i saw full boost again.
it's an 07 thing.
you could PM 1badBlueberrySC or SCblkRL. they're my tuners.
Old Mar 24, 2009 | 09:10 AM
oh coo man thx..
Old Mar 24, 2009 | 09:16 AM
SCBLKRL's Avatar
sending PM
Old Mar 24, 2009 | 10:04 AM
1badBlueberrySC's Avatar
PM Sent
Old Mar 24, 2009 | 10:08 AM
MP Cobalt's Avatar
What's the normal coolant temp for a stage 2 cobalt?
Old Mar 24, 2009 | 10:26 AM
That isn't coolant temp... that is IAT temps!
Normal coolant temps range from 170*-190ish*
A 140* IAT2 is HIGH
Old Mar 24, 2009 | 11:33 AM
it's an 07 thing.
Your tuners sound like they don't really know whats going on if they are loading in a Stage 2 tune (for a car that isn't stage 2, also the stage 2 tune is a HORRIBLE tune), then modifying it, then modifying it, then again, just to get your boost where it should be.
Old Mar 24, 2009 | 11:53 AM
SCBLKRL's Avatar
don't get too far ahead of yourself there.....stage tune was the original tune pulled from the car, changes were made to the tune based on the modifications to the car....there is nothing in that tune that is part of the stage tune...the boost is where it should be....just a small quirk of the 07 OS
Old Mar 24, 2009 | 06:49 PM
I've never seen that "quirk" in the 07 lol. Must just be something about the cars you work on.
Old Mar 24, 2009 | 07:20 PM
ok guys i will be doing what you said when i get home..thx alot and will update when its fixed
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
