Codes on my LNF
Old Dec 17, 2014 | 03:25 PM
Getaway_Driver's Avatar
Codes on my LNF
P0100- MAF or VAF A Circuit malfunction
P0113- IAT Sensor 1 Circuit High Input
P0300- Random/Multiple Cylinder Misfire Detected
P0301- cylinder 1 misfire detected
P0303- cylinder 3 misfire detected
Those are the codes, and I saw what they stood for. I just don't know what I'm dealing with here.
Cylinders misfiring makes me think there's something off with the spark plugs, but I just installed them. They're brand new. Basically 10 miles on those damn things.
Old Dec 18, 2014 | 04:51 PM
Anyone?
Old Dec 18, 2014 | 05:03 PM
exninja's Avatar
My suggestion is to concentrate on the first two. The misfires are a symptom rather than a problem, so they may get cured by solving the P01XX codes. MAF sensor: you can try cleaning. IAT I believe is integrated with one of the MAP sensors but I could be mistaken. All three of them (MAF and 2 MAP's) are not that expensive but you can try troubleshooting those to narrow down which is the problem, if any. That's where I'd start. I know you're on a budget so see if you can find a way to test rather than just pulling and replacing.
Old Dec 18, 2014 | 05:10 PM
RyBread761's Avatar
Are you laying the hammer down when these codes happen? Does it happen right away? I agree above, the misses are a by product, possibly. I used to get random misses when I had shitty gas, only when I really leaned on the throttle.
Old Dec 18, 2014 | 06:03 PM
slapbetcommissioner's Avatar
If they only have 10 miles on them and the problems started em immediately after install I would say that's hwre your issue lies.
Either they are faulty/ gapped incorrectly/ not right for your application or the coils could be not seated correctly or they aren't tightened down enough. Not that they need to be very tight
turbochargedss2012
Sep 20, 2023 12:17 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
Oct 13, 2015 09:32 PM
patooyee
Oct 1, 2015 01:07 PM
