cooling fans do NOT come on.
Old Jun 21, 2016 | 09:07 PM
  #51
[QUOTE=canadianviper;7612570]
[QUOTE=canadianviper;7612567]
Originally Posted by ItalianJoe1
103 celsius is about normal turn on if the a/c is off why does it heat up between 89-92 degrees Celsius when driving and over 100 degrees Celsius when stopped at a light or in slow traffic
It's all about airflow. You're still in a normal temp range, maybe a coolant flush and wash your rad off.
Old Jun 21, 2016 | 09:19 PM
  #52
canadianviper's Avatar
[QUOTE=ECaulk;7612571][QUOTE=canadianviper;7612570]
It's all about airflow. You're still in a normal temp range, maybe a coolant flush and wash your rad off. I sprayed the rads out last week with a pressure washer at the local car wash
Old Jun 21, 2016 | 09:23 PM
  #53
[QUOTE=canadianviper;7612574]
Did you bend them over?
Old Jun 22, 2016 | 12:01 AM
  #54
biniecki's Avatar
I have this problem happen all the time. I eventually installed a switch to manually turn it on. I did a how to many years ago. The only thing is I have the switch wired to a constant power for when i was staging at the drag strip. Sucks if you forget to turn off the switch. I would recommend tying into some that is only on when the key is on
Old Jun 22, 2016 | 09:28 AM
  #55
turbosmart4's Avatar
The fan I don't have wired to a switch now comes on when around 187-190 on low ... Just like it used to. I still left the other one wired to a switch ... I tested the wiring by wiring my headlight halos to see when the halos would come on and they've been working... I'm going to rewire everything back to normal this weekend. Seems like I'm good to go after replacing Tstat, coolant temp sensor , and checked the wiring.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
dennis69
Oct 20, 2015 04:49 PM
Tupp
Sep 30, 2015 08:18 PM
DocSvensk
Sep 27, 2015 02:24 PM
roth
Sep 26, 2015 12:16 PM
