EVAP code
Old Dec 20, 2011 | 12:09 PM
Dart_SI's Avatar
EVAP code
Car threw an EVAP code. After I fuel up it takes 2 or 3 cranks, then it runs fine. I can't fox this for a few weeks cuz im 1200 miles from home. Will this have any problems if I don't fix it right away? Also would unplugging my eval purge solenoid have any negative effects? Any help would be awesome.
Old Dec 20, 2011 | 12:12 PM
Chevycobaltss3's Avatar
Evaluate purge. 25$ part. It'll burn ure plugs up quick Ure trims will be off enough to cause a shitload of detonation and ect
Old Dec 20, 2011 | 12:50 PM
Dart_SI's Avatar
I've been keeping an eye on my afr and it hasn't been jumpy at all. How will I know if my evap solenoid is bad or if it's the canister.
Old Dec 20, 2011 | 01:13 PM
The code. or take Ure purge out and blow in it. If you can blow in it then the valve is bad. Which if Ure havibg hard cranks its bad.
Old Dec 20, 2011 | 01:28 PM
Dart_SI's Avatar
Its only bad after fueling. But ill prolly order a new one. Where's it 26 bucks at? Dealer said its 60
Old Dec 20, 2011 | 01:45 PM
dealers on crack order on line... The purge solenoid is bad period, Reason it acts up bad after fueling is its sucking in fumes and ect from the evap system. And running the car with the bad purge causes fouled plugs and ect and cels. So id get it fixed quick!! Its not a major thing but it does cause issues!!
Old Dec 20, 2011 | 01:49 PM
2010SS's Avatar
Amazon its 26, had the same problem. Changed it and it's fine
Old Jan 21, 2012 | 05:17 PM
RiceCop's Avatar
Mine appears to be bad too. Took the one off the manifold and blew in it and it doesn't let any air through, so I'm guessing it's the back. You guys have the part number?
Old Jan 24, 2012 | 04:12 PM
2.2balt's Avatar
If the code is P0446 its the vent solenoid at the back of the car in the canister. Mine threw it today. $25 part.
Just throwin that out there...
Old Jan 25, 2012 | 04:34 PM
grim_reaper's Avatar
Help
i have multiple codes coming up. P0446, P0300, P0171,P0420.p0446 is evap vent solenoid performance,p0300 is random engine misfires, p0171 is bank 1 fuel trim lean, and p0446 is cat converter low efficiency.
Any suggestions on where to start?
I'm not sure if i fix one others will shut off.
Old Jan 25, 2012 | 04:38 PM
Dart_SI's Avatar
Probably a bad evap canister and solenoid. And also a bad 02 sensor. Not 100% tho just taking a guess.
Old Jan 26, 2012 | 03:29 PM
ls4montess327's Avatar
took my to the dealer about a month ago, and replaced the evap line that goes from the engine to the evap canister in the rear. under warranty, no issues or engine light at the moment. The part was on back order and it took 2 weeks to get it. Dealer said It was ok to drive at that time and will not hurt anything.
Prior to that, I drove the car for a month or so with the engine light on. no drivability issues but did smell a hint of fuel ordor.
Old Jan 26, 2012 | 03:36 PM
NinjaHampster's Avatar
i have replaced the purge valve on the engine but was unaware there was another one in the back, i thought it was just the cannister itself
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ernnyyes
Oct 2, 2015 05:16 PM
Extremespeed
Sep 29, 2015 04:34 AM
DocSvensk
Sep 27, 2015 02:24 PM
