EVAP code
EVAP code
Car threw an EVAP code. After I fuel up it takes 2 or 3 cranks, then it runs fine. I can't fox this for a few weeks cuz im 1200 miles from home. Will this have any problems if I don't fix it right away? Also would unplugging my eval purge solenoid have any negative effects? Any help would be awesome.
dealers on crack order on line... The purge solenoid is bad period, Reason it acts up bad after fueling is its sucking in fumes and ect from the evap system. And running the car with the bad purge causes fouled plugs and ect and cels. So id get it fixed quick!! Its not a major thing but it does cause issues!!
Help
i have multiple codes coming up. P0446, P0300, P0171,P0420.p0446 is evap vent solenoid performance,p0300 is random engine misfires, p0171 is bank 1 fuel trim lean, and p0446 is cat converter low efficiency.
Any suggestions on where to start?
I'm not sure if i fix one others will shut off.
took my to the dealer about a month ago, and replaced the evap line that goes from the engine to the evap canister in the rear. under warranty, no issues or engine light at the moment. The part was on back order and it took 2 weeks to get it. Dealer said It was ok to drive at that time and will not hurt anything.
Prior to that, I drove the car for a month or so with the engine light on. no drivability issues but did smell a hint of fuel ordor.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
