Help : 09 Cobalt SS makes no boost
Old Aug 27, 2021 | 10:49 AM
Kalob09SS's Avatar
So recently here the last month or so i have been trying to figure out why my cobalt is only making 0~5 psi. Ive scoured the forums and asked many of my cobalt owning friends for ideas and so far everything has come up dry with no changes in performance. It all sort of started after I pulled into a shop to get my transmission fluid replaced and on the way out of the building my resonator got caught on something on the floor. Resonator cracked open like a pop can and so i took it off and had it repaired. i had no issues the whole time the resonator was off of the car. After getting it back and reinstalling it my issues began. So far I have done these.
  • Boost leak test at least 5 times
  • Cleaned and checked BPV for damage (found no signs of wear)
  • Replaced MAP sensors with gms1 to match my tune
  • Replaced MAF twice
  • Replaced boost control solenoid
  • Replaced wastegate actuator solenoid
  • Replaced EVAP purge solenoid
I really thought the wastegate was the issue and after 5 hours spent on the replacement I still have no change in performance. I was wondering if anyone else had experienced something like this. If so how did you fix it? The only code that eventually gets thrown is a MAF range/performance code. I really have no clue what it could be at this point in time and I'm hoping someone on here may have some ideas for me.
Last edited by Kalob09SS; Aug 27, 2021 at 02:35 PM. Reason: Added replacement part to the list
Old Aug 27, 2021 | 11:29 AM
Which MAF code is it? Can you scan for pending codes?
Any way to log the car to see what is occurring in the ECU?
Old Aug 27, 2021 | 11:33 AM
Kalob09SS's Avatar
i don't remember exactly what code it was of the top of my head but i have an hptuner that i use to scan for codes and i can log with it. i just don't know enough yet about the ecu to figure that out myself
Old Aug 27, 2021 | 12:29 PM
Kalob09SS's Avatar
Got a log from the other day and will be making a new one today once my laptop is charged and i read through some saved code logs from my torque pro app on my phone and the code it throws is P0101
File Type: hpl
Old Sep 9, 2021 | 07:17 PM
Kalob09SS's Avatar
So ive discovered unplugging the MAF sensor lets the car build up to 15psi but after replacing the MAF sensor yet again now with the sensor plugged in the car wont run it will bounce rpms at idle until it eventually tries to build boost and dies. any ideas?
Old Sep 9, 2021 | 07:21 PM
Have you check the wiring for the maf?
That code seems super familiar been out of the diagnostic side since I stop visiting but if I recall that's the Boost leak code. I could be wrong
Old Sep 10, 2021 | 08:36 AM
Usually the P0101 is a boost leak, but if it passes a boost leak test then I would start looking into the wiring for the MAF.
Old Sep 10, 2021 | 10:28 AM
Well yeah that all depends if the OP did the test correctly lol but I agree with you if it was done properly then start checking wiring for the maf
Old Sep 10, 2021 | 10:50 AM
ProfDNS's Avatar
I'd do it for the $15.
https://www.rockauto.com/en/catalog/...onnector,10183
Old Sep 10, 2021 | 11:18 AM
Originally Posted by ProfDNS
Sometimes its not the connector it's a pinched wire or the coating has been rubbed away on a wire in the loom.
Old Sep 10, 2021 | 05:19 PM
ProfDNS's Avatar
Of course. Worst case scenario, it's a cheap replacement.
What OP didn't mention is if they have one of those MAF cable extensions either (for CAI). Those are a little more $. Just in case, here's a link for that -> https://www.ebay.com/itm/17237081172...4AAOSwZJBX-9Ks
Kalob09SS
Aug 31, 2021 05:40 AM
Tenacious James
Oct 6, 2019 06:22 PM
Ronn2005
Feb 13, 2014 12:11 PM
Kurisutofa
Dec 17, 2013 11:40 PM
sprchrgdss
Aug 8, 2012 09:35 PM
