High pitched sound at WOT
Old May 6, 2011 | 10:49 PM
jordyboi's Avatar
This high pitched sound sound occurs when I floor the pedal with my Trifecta tune. This is the SS TC. I never heard it with stock tune. At :09 I floor it in second and you can hear it briefly there. If I hold down pedal the noise will last even longer.
Is this bad or is it normal and not to worry?
Thanks.
https://www.yousendit.com/dl?phi_act...T01Qb0kwTVE9PQ
Old May 6, 2011 | 11:03 PM
tuner923's Avatar
yea, probably a boost leak.
Old May 6, 2011 | 11:06 PM
jordyboi's Avatar
are boost leaks common? i bought the car new and it only has 5000 miles on it.
Old May 6, 2011 | 11:11 PM
tuner923's Avatar
what is your boost gauge reading while WOT? I wouldn't worry about a leak unless your gauge is reading much lower than anticipated boost level.
Old May 6, 2011 | 11:12 PM
Dart_SI's Avatar
i think i know what your talking about, i believe thats just a normal sound the turbo makes. lol. your fine. is it reeallllly high pitched?
Old May 6, 2011 | 11:14 PM
jordyboi's Avatar
yeah its really high pitched I wanted to record a better sound clip but that's all I got.
~20 PSI I asked for 23 in my tune
thx all
Old May 6, 2011 | 11:16 PM
tuner923's Avatar
if it sounds like tuning fork ringing. it's just a bit of vibration making the turbo hum like a tuning fork..
Old May 6, 2011 | 11:18 PM
AaronJ's Avatar
What are your mods? I've got just a K&N Sri on the stock tune and it makes a high pitched whistle at the top part of 2nd. I've never noticed it in 1st though, probably because the tires are making too much noise
tuner923's Avatar
thx all
so you could be losing 3lbs of pressure from the leak or it's just atmosphere or ambient temp related..
Old May 6, 2011 | 11:20 PM
jordyboi's Avatar
so you get the same sound..I never heard it on stock though. mods are K&N SRI catless and trifecta.
Old May 6, 2011 | 11:57 PM
AaronJ's Avatar
Since I got the intake I ride around with my windows down and radio off just so that I can hear the turbo, lol. That's my best guess though. I've never had a boost leak before but from what I understand boost leaks are more common with aftermarket charge pipes or the stock intercooler. I would look over the plastic end tanks on the intercooler to see if there are any cracks. I'm sure other members with boost leak experience can chime in and offer some more insight or ways that you can check for boost leaks if necessary.
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
biniecki
Oct 25, 2015 02:23 PM
no_ss
Oct 18, 2015 11:58 PM
jimbofug007
Oct 2, 2015 12:06 PM
