Install gone bad
Old Jul 10, 2010 | 04:02 AM
wesphily's Avatar
Install gone bad
Installed the following: ottp stage 2 kit/dual pass endplate/opt b/ottp heat exchanger.
Ther is a hollow bolt that goes into the upper radiator hose. We forgot to put the line leading to coolent tank before trying to screw the hollow screw in. Needless to say, we snapped the bolt.
My question is, how do we get the the screw out?
Old Jul 10, 2010 | 07:51 AM
Coblasts's Avatar
You could buy a "easy out",(technical name.)There are two different kinds.
The wedge shaped and the reverse threaded kind.Any auto supply or tool supply store will have them.
Old Jul 10, 2010 | 08:40 AM
rukkee's Avatar
This is the only part number i can find for that bolt . Freek posted it in 07 thou . Good luck .... they seem hard to come by .
12797711 - BOLT, ENG COOL AIR BLEED PIPE
Old Jul 10, 2010 | 09:20 AM
SunburstSS's Avatar
I Am Assuming Ur Talking About The Bolt That Goes On The Cylinder Head On The Front That Bleeds The Air To The Surge Tank Correct ?!
If So Do The Following & Please Be Carefull, I've Done This Before A Couple A Years Ago On A Friends Car...
Drill It, Clean Up, Rethread, Flush Ur Coolant System A Couple Times & Ur Set... Drill It With A Bit Thats The Same Size Of The Hole It Self So U Can Screw The New Bolt In Easily...
Thats Not That Bad Try Snapping A Spark Plug In The Head, Now Thats A Fun Project To Get Get Out, Been There Done That Works Great
Old Jul 10, 2010 | 12:33 PM
wesphily's Avatar
would it be possible to take canned air and turn it upsidedown to try tofreeze the bolt. Then hit it with screwdriver and hammer to break it out?
Also, when i try typing that part number in nothing shows up. Is there a specific place to find it?
Old Jul 10, 2010 | 02:17 PM
SunburstSS's Avatar
If that was the case all cars would break when it snows outside
Old Jul 10, 2010 | 02:49 PM
wesphily's Avatar
The idea is that since it is thin, it could be broken.
Old Jul 10, 2010 | 02:55 PM
Terminator2's Avatar
Is this bolt hollow through the center? If so, you could maybe wedge something inside the hollow part and twist to get it out.
Old Jul 10, 2010 | 04:22 PM
rukkee's Avatar
Like someone already said ..... the right size easy out should work just fine .
Old Jul 10, 2010 | 09:10 PM
wesphily's Avatar
Ok well we will keep trying.
Once we get it out I will need another bolt. Where would I find it?
Old Jul 12, 2010 | 10:51 AM
wesphily's Avatar
Anybody?
dennis69
Oct 20, 2015 07:39 AM
Oct 13, 2015 09:32 PM
ernnyyes
Oct 2, 2015 05:16 PM
justinchinn
Oct 2, 2015 12:18 PM
Iceberg
Sep 29, 2015 12:33 PM
