loss of boost pressure..
this only happens when it rains it seem..is my intake getting wet or my intercooler cracked and water getting in there? im not sure but i think its probably one of the two..it goes from stock 15psi to about 5psi and lots of power lost..anything? thanks
oooooo ok, well it could be your intake sucking in water if you're gunnin it when it's pouring outside.. you should check to see if theres a hydroshield on the actual filter.. you can tell if you open the hood an peer down, but if you still cant see, then take your headlight off on that side..
Sl0wbaltSS
Nov 21, 2018 11:11 PM
