loss of boost pressure..
Old May 17, 2011 | 12:33 AM
DWoods54's Avatar
this only happens when it rains it seem..is my intake getting wet or my intercooler cracked and water getting in there? im not sure but i think its probably one of the two..it goes from stock 15psi to about 5psi and lots of power lost..anything? thanks
Old May 17, 2011 | 12:38 AM
MastaShaKe_88's Avatar
got any mods?
Old May 17, 2011 | 06:39 PM
DWoods54's Avatar
thanks for responding!
full mpx exhaust and mpx downpipe with cat that i put on..and probably the problem- a hahn cai in which i did not install, previous owner did.
Old May 17, 2011 | 09:47 PM
oooooo ok, well it could be your intake sucking in water if you're gunnin it when it's pouring outside.. you should check to see if theres a hydroshield on the actual filter.. you can tell if you open the hood an peer down, but if you still cant see, then take your headlight off on that side..
Old May 17, 2011 | 11:09 PM
DWoods54's Avatar
ok ill look at this tomorrow thank you
Old May 17, 2011 | 11:15 PM
Rocky87's Avatar
same thing happened to me today, and it kinda putted around, i couldnt go past 3 grand. i came home started it up 4 hours later and everything was fine
Old May 17, 2011 | 11:17 PM
importkiller's Avatar
perhaps the MAF is getting wet and skewing things until it dries out.
Old May 17, 2011 | 11:19 PM
Baron7700's Avatar
my guess. Its pretty hard to suck water in unless your headlight is really loose or you went thro a 2 foot puddle
turbochargedss2012
Sep 20, 2023 12:17 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
tomj77
Oct 4, 2015 11:39 AM
ernnyyes
Oct 2, 2015 05:16 PM
