need second opinion
Old Sep 4, 2006 | 03:55 AM
RYCobaltSS's Avatar
need second opinion
ok, i posted about this a while back, about not having second gear, heres the deal. i believe i chewed the 2nd gear synchro but id really like a second opinion. i drive off in 1st shift to second...slight grind instantly following the tranny kicks gear selector out of second and into neutral, shift to third and everyother gear after that is ok....but heres where i get confused...took to the dealer they say bent shift fork or synchro, not under warranty cuz mechanic has pictures of me at local drag track so its abuse. anyways I CAN STILL DOWNSHIFT TO SECOND but the second i touch the gas it kicks out....so i can slow down in second but not accelerate without it kickin out.
had a similar problem in my 84 stang but with 1st gear, but i could just put it back in gear and it would stay....im stuck on the synchro because if it were the shift fork 1st gear would be fucked up as well....no? well any and all comments are accepted...i will be performing the repairs myself and also make a how to: for it as well but id just like a second opinion, especially if there is a gm mechanic on the forums.
thanx
Old Sep 4, 2006 | 04:50 AM
Dead Zen's Avatar
I would debate the fact that a mechanic has a pic of you at the track. How can they prove it was you??
Rick
Old Sep 4, 2006 | 04:58 AM
REIGN SS's Avatar
Original Hayden Fanatic
...go to another dealer???
Old Sep 4, 2006 | 02:01 PM
rnjmur's Avatar
Yeah, take it to another dealer.
That definately sounds like it could be a bent fork or synchro. When you shift to second and deccelerate, the gears are problably ok. When you hit the gas you are knocking it out of gear because it probably isn't meshed all the way. When deccelerating there is little torque going through the transmission. When you hit the gas you cause torque on the gears, and since it isn't meshed it's causing it to kick out.
Old Sep 4, 2006 | 02:17 PM
EvlPeanut's Avatar
Take it to another dealer, any GM dealer would be able to order the part(s) required to fix you up. Then I'd go back to the mechanic and ask for proof that the photo was of yourself, he may have a photo of you, but if it can't be 100% proven it's you (i.e license plate in picture or your face in picture) they can argue that you're the cause of the damage but they have to prove it if they are not going to fix it.
Old Sep 4, 2006 | 02:21 PM
05BlackCobaltSS's Avatar
I agree. Unless they have pics of your face, and/or plates, that's some bullshit.
Old Sep 4, 2006 | 02:31 PM
RaineMan's Avatar
and thus... is why I always take off the plates and tape over the VIN number when I go to the track... it takes like 5 seconds... better safe than sorry...
Old Sep 4, 2006 | 03:21 PM
RYCobaltSS's Avatar
seriously, even tho my car looks like this...do you really think i could pull off that it was someone else at the track and not me...even if they couldnt see the plates or my face..????
edit: its only 210% for the shift fork and synchro, so i guess i could just spend the extra 40 for the shift fork and get er done
Old Sep 4, 2006 | 03:32 PM
Boosted_SS's Avatar
Dude take it to another stealership and play dumb!!! don't pay cash to get it done.
Old Sep 4, 2006 | 04:43 PM
RaineMan's Avatar
Why don't you take it down to the dealership that "Kanabrewski" works at on South BLVD... I know it's a long way... but he may have an "in" for you.
Old Sep 5, 2006 | 06:43 AM
RYCobaltSS's Avatar
oooooo...good idea...ill cruise it down there after i come back from florida...should be late sept. thanks for the heads up raine
Old Sep 5, 2006 | 07:05 AM
05REDROCKET's Avatar
I agree with going to another dealer because obviously you know how to drive a stick
so I don't think you F'd it up, besides you never know you might walk in the door and they might help you right away just to get you as a customer.
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
dasoftest
Sep 29, 2015 02:14 PM
reybalt
Sep 22, 2015 06:35 PM
Haily229
Sep 17, 2015 07:18 AM
