New exhaust, throwing Oxygen sensor codes???
Old Mar 31, 2010 | 10:07 AM
sscrazy's Avatar
I recently put on a Megans racing cat back system on and it threw out two O2 sensor codes. I also have a high flo cat on the car. Are there O2 simulators that I can put on to keep the engine light from coming on? Or do I have to put wide band sensors on? Either way where do I get them? (wide bands or simulators?)
The car also idles like crap!
Old Mar 31, 2010 | 10:08 AM
DjJoeski87's Avatar
Code?
Old Mar 31, 2010 | 10:13 AM
BigRyanJackson's Avatar
its probably a p1406 or something like that? do you have a header on it? its probably just running rich. the o2s are tellin the comp to put more fuel into the motor because of how much exhaust is coming out of it now. just get a defouler for the downstream o2 and youll be good.
Old Mar 31, 2010 | 10:17 AM
Staged07SS's Avatar
Administrator
Administrator
the code is from your high flow cat .... not your catback. you can purchase an angled cel eliminator.
Old Mar 31, 2010 | 10:27 AM
rnjmur's Avatar
High flow CAT is your problem. There are two ways to fix the CAT efficiency code. One is to tune it out with HPTuners. The second is to put a spacer on the O2 sensor that pulls it out of the exhaust stream.
What were both of the codes? If you were just getting the CAT efficiency code it shouldn't cause rough idle. by rough idle to you mean the the RPMs are jumping up and down? Is the car dying?
Old Mar 31, 2010 | 12:37 PM
sscrazy's Avatar
Not sure what the codes were. I took it to autozone to check it out and he said that it was both o2 sensors throwing the codes.
Yes the idle jumps up and down and sometimes dies. It smooths out at times though. I know on my camaro I had to put O2 simulators to "trick" the computer. Is that what I need to do here?
No header. What is a defouler? And where would I get one?
Does this eliminator get rid of the bad idle or just eliminates the CEL?
Old Mar 31, 2010 | 12:45 PM
Bl4des's Avatar
the bad idle is not from the exhaust clean your throttle body and maf
Old Mar 31, 2010 | 01:10 PM
Staged07SS's Avatar
Administrator
Administrator
just the CEL. your bad idle could be due to a dirty throttle body or MAF sensor.
Old Mar 31, 2010 | 03:11 PM
it is an o2 sensor extension that makes the o2 sensor farther away from the downpipe to make the code go away. i got a strup cel eliminator from clubrsx.com it was like 30 bucks
Old Mar 31, 2010 | 04:13 PM
sscrazy's Avatar
I will clean them and reset the computer
Old Apr 2, 2010 | 04:48 PM
dspeed123's Avatar
If cleaning the throttle body and MAF doesn't work, check sensor 1 (manifold o2 sensor). It may be bad, throws code P1131. The downstream sensor and Code is P0420 and I would think would have come up before you put the catback on.
Old Apr 2, 2010 | 05:01 PM
RecklessL61's Avatar
Vince from trifecta can right a tune that can delete the rear O2 from you computer, or u can us a spark plug non fowler, put it in the O2 hole then put the O2 in the non fowler and that should solve your problem. you can get one at any auto parts store
Old Apr 6, 2012 | 05:51 PM
tscott21's Avatar
i recently added a zzp header with a cat and a slp loudmouth and i keep throwing a p0420 code any suggestions?
Old Apr 6, 2012 | 06:10 PM
LS6Rally's Avatar
^ defouler or Tune
Old Apr 6, 2012 | 07:56 PM
tscott21's Avatar
I e mailed ottperformance when I got the exhaust and asked them if I needed a retune for my stage 2 kit but they never got back to me...
Old Apr 8, 2012 | 12:01 PM
pHazer's Avatar
What's the easiest way to go about cleaning your throttle body?
Old Apr 11, 2012 | 11:26 AM
LotusRenaultF1's Avatar
It's not from the catback, there are no O2 sensors behind the cat. It might be from the cat itself because it isn't tuned for that particular exhaust?
Old Apr 12, 2012 | 08:13 AM
Racerdad's Avatar
The rough idle is probably from a bad upstream O2 sensor. The downstream one is the one that can be ignored/tuned out, but the front one controls fueling. It COULD be from the MAF or something on the intake side, but if that's not it, you should next be looking at the front O2 sensor.
And, make those Autozone guys give you the codes!!! It's pretty hard to fix the problem without knowing what the ECU thinks is wrong.
06MetallicBalt
Jul 20, 2025 08:47 PM
turbochargedss2012
Sep 20, 2023 12:17 PM
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
jmelton327
Sep 26, 2015 10:04 PM
