Second Gear going bad?
Old 01-29-2018, 04:01 PM
Wind's Avatar
While the car is off I can shift through all the gears fine. Once I turn it on only the second gear has a problem going in. When going in from first to second if I try to put it in right away it kinda grinds but if I wait like 2 seconds then it goes in fine. The rest of the gears are fine its just second that does this.
Should I be looking into getting a new trans?
Also just to add I read a cel on my car P0833 Clutch pedal switch 2 circuit malfunction
Old 01-29-2018, 04:04 PM
Kolt's Avatar
sounds like the syncro is going out. not the gear itself.
Old 01-29-2018, 07:28 PM
63 Nova SS's Avatar
Could be a syncro, but I wonder if your cables are out of adjustment?
Old 01-29-2018, 07:46 PM
Wind's Avatar
I'll check that out probably Wednesday but wouldn't this only be the case if it didn't want to go in while it was off?
yeah this is what I meant :|
Does anyone rebuild transmissions
Old 01-29-2018, 09:41 PM
63 Nova SS's Avatar
I changed my shifter out and couldn't get it in 2nd off or on. Adjusted my cable and it worked fine.
Old 01-29-2018, 11:40 PM
Rattlesnake Race Shop
USMCFieldMP's Avatar
If it's grinding though, it's either the clutch isn't fully disengaged or the synchro is going out... and since OP is only having the problem with one gear, it's most likely the synchro.
This is likely to be your problem.
See how the three inner "wings" on this ring look a little flattened/grooved?
That prevents it from dropping down into the corresponding grooves... as seen here.
In this case, it was from downshifting very hard from 3rd to 2nd.
Old 01-30-2018, 11:08 AM
Wind's Avatar
So what do you guys think that I should do?
Old 01-30-2018, 11:33 AM
Kolt's Avatar
Check and adjust your shift cables first, then prepare for a trans if it continues or learn to rev match your shift. From what I hear its cheaper to get a new one than rebuild.
Old 01-30-2018, 01:55 PM
63 Nova SS's Avatar
You can have them rebuilt, but the really good guys who do them can sometimes have a long turnaround time.
Old 01-30-2018, 11:21 PM
More than simple rev matching, he'll have to learn to double clutch. It's not impossible though.
Learn to double clutch. Drive it until you can find a replacement.
Old 01-30-2018, 11:59 PM
Sharkey's Avatar
if i had to double clutch 2nd gear to get it to go in, and i had to drive the car i think id simply shift 1st to 3rd.
Old 01-31-2018, 12:46 AM
Eh, it's not that bad once you get the hang of it. I did it for a little while with my OE transmission back in 2006.
Old 01-31-2018, 07:39 AM
sixgear's Avatar
I had the same thing happen about a year ago, one day trans was fine, next day was a little hard to get in first, then did just like yours, I figured something broke in second, probably the syncro and I thought about fixing it myself but wasn't sure where to get parts or if special tools were needed to split the case, I ended up finding a used trans (kind of hard to do) and put the old one on the shelf should I have problems again and then fix it.
Old 01-31-2018, 08:18 AM
Wind's Avatar
This is what I've been doing tbh lol
I guess I'm just going to have to find something used lnf, lsj and redline all have compatible trans right?
Old 01-31-2018, 11:04 AM
That's what I did. I still have my OE trans from 2006 with the above pictures busted blocker ring.
Learn to double clutch. It isn't that hard. A bit of a relic from the old days when cars didn't have synchros. But it'll help you out a bit from time to time and keep you from having to wind first out deep and/or lugging the hell out of the engine in third.
Old 01-31-2018, 11:15 AM
double clutch's Avatar
Im so popular today
Old 01-31-2018, 11:17 AM
So easy, even a grandma can do it!
Old 01-14-2019, 11:39 PM
RoelSS's Avatar
Did a search and came across this thread. My second gear grinds going in but if I double clutch, it goes in fine. I'm certain it's a synchro issue, but does anyone know of a good transmission guy?
pursuitforever
02-23-2011 10:05 PM
BLUE TRANSFORMER
01-17-2010 08:03 PM
YzRider452
08-24-2008 11:55 PM
MfZx25z
02-28-2008 09:24 PM
Supercharged06
09-01-2007 11:26 AM
Quick Reply: Second Gear going bad?
