weird idle on the balt
Hey guys I just made this video not sure what could be causing this. You can hear the idle is bouncing around and the wideband bounces with the exhaust. I checked the exhaust for leaks with seafoam and the only one I found was by the back tire where there is a clamp. Also I did a BLT at the throttle body and couldn't find any leaks. You guys have any ideas of what could cause this? If you watch the rpm's they don't move but it sounds like it has cams or something. Still need to finish the tune right now its just has a base tune. The guy who tuned it set it up for 42's instead of 60's so aces on here fixed that for me. Also you guys know what causes it to idle surge while its coasting? As soon as it comes to a stop the surging stops but the whole time your coasting it surges a couple hundred rpm's
2.8 pulley - 60's - magnaflow cat back - injen intake
Cobalt SS idle - YouTube
After the previous tune. Aces did a quick fix we still have to finish it I was just wondering if you guys had any ideas. I just picked up some tb cleaner so I'm going to try that.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
roth
Sep 26, 2015 12:16 PM
