wierd zzzzz noise
wierd zzzzz noise
there's a weird Zzzzzz buzzing/ticking noise coming from what sounds like the passenger side of my car. you cant hear it at idle its only on acceleration, anyone have any ideas.
also my heat shield started rubbing pretty loud by my resonator, could the flex pipe have broken and its allowing the exhaust to shake more?
i dunno pretty annoying if anyone has any ideas it would help alot
no its not a wheel bearing or anything like that, ive had one go bad before, i read somewhere about the timing chain tensioner is that a big issue or just a noise i have to get used to
thanks
-chris-
thanks
-chris-
It's like a $40 part w/ shipping from CED. There's a a guide in the how-to section on the forums on how to change it.
it be so much cooler if a bumblebee was bouncing around my exhaust all pissed off, everyone says go to that post for how to install but there's other people saying you don't even have to do all that, there's a different version out, just pull the old one out and put new one in. is it that easy or should i have a shop do it
Ok so I bought the tensioner and put it in I'm assuming I needed it because the old one fell apart when I pulled it out, but the noise is still there, next step I'm gonna ghetto rig up some kind of smoke machine to find a leak I guess
Did you just take out the old one and put the new one in?
Does it sound like this (watch videos in the first post):
https://www.cobaltss.net/forums/2-0l...o-fins-265742/
I had a hissing sound only on acceleration and I thought it was an exhaust leak. Come to find out it was a hole in my flex pipe. Then eventually my flexn pipe completely blew out and i was runing open headers. HELLA loud bro lol
Holidai,
I see that you've already replaced your timing chain tensioner, and that you're now looking into gaskets. If you do decide eventually to work with a dealership towards diagnosing this concern, please let me know!
Best,
Sarah
GM Customer Service
Best,
Sarah
GM Customer Service
PpoThanks sarah I actually have a appointment Tuesday to get my power steering recall Taken care of and if I ccant fix it by then I'm going to ask them to look at it, if it is the flex pipe would it be covered under the same 10yr warranty as the catalytic being its part of the same pipe
You can also try tightening your header bolts down, some people have had a problem with them not being tight enough. I had a sound coming from the passenger side too and it was the header bolts. The bolts going to the head not the downpipe.
Ok I'm gonna have to check that out too, my brothers a mechanic and we were feeling around for a leak in the flex pipe and header area but couldn't feel any exhaust coming out but I'm going to check the header bolts when I get off work
Ppo
All the best, and a great Thanksgiving!
Sarah
GM Customer Service
DANRICKARD
Oct 1, 2015 12:08 AM
