wierd zzzzz noise
Old Nov 20, 2011 | 04:55 PM
holidai's Avatar
wierd zzzzz noise
there's a weird Zzzzzz buzzing/ticking noise coming from what sounds like the passenger side of my car. you cant hear it at idle its only on acceleration, anyone have any ideas.
also my heat shield started rubbing pretty loud by my resonator, could the flex pipe have broken and its allowing the exhaust to shake more?
i dunno pretty annoying if anyone has any ideas it would help alot
Old Nov 20, 2011 | 04:59 PM
1 SLOW SS's Avatar
motor or rotational noise? wheel bearing?
Old Nov 20, 2011 | 06:07 PM
Gelladuga69's Avatar
That zzzzzzzzz noise is your timing chain tensioner.
Dunno about the heat shield.
Old Nov 20, 2011 | 06:24 PM
holidai's Avatar
no its not a wheel bearing or anything like that, ive had one go bad before, i read somewhere about the timing chain tensioner is that a big issue or just a noise i have to get used to
thanks
-chris-
Old Nov 20, 2011 | 06:31 PM
thanks
-chris-
I mean, I suppose it's a big issue. It's your car and completely up to you to whether you want to change it or not.
It's like a $40 part w/ shipping from CED. There's a a guide in the how-to section on the forums on how to change it.
Old Nov 20, 2011 | 06:43 PM
holidai's Avatar
ok im going to replace it ill look for the how to now thank you
Old Nov 20, 2011 | 06:53 PM
https://www.cobaltss.net/forums/how-...71/index5.html
https://www.cobaltss.net/forums/5965767-post105.html
Old Nov 20, 2011 | 06:55 PM
ChriSS/SC's Avatar
it's a bumble bee brah
Old Nov 20, 2011 | 08:20 PM
holidai's Avatar
it be so much cooler if a bumblebee was bouncing around my exhaust all pissed off, everyone says go to that post for how to install but there's other people saying you don't even have to do all that, there's a different version out, just pull the old one out and put new one in. is it that easy or should i have a shop do it
Old Nov 21, 2011 | 02:31 PM
holidai's Avatar
Ok so I bought the tensioner and put it in I'm assuming I needed it because the old one fell apart when I pulled it out, but the noise is still there, next step I'm gonna ghetto rig up some kind of smoke machine to find a leak I guess
Old Nov 21, 2011 | 02:32 PM
Did you just take out the old one and put the new one in?
Old Nov 21, 2011 | 02:37 PM
snoftall's Avatar
Does it sound like this (watch videos in the first post):
https://www.cobaltss.net/forums/2-0l...o-fins-265742/
Old Nov 21, 2011 | 02:58 PM
holidai's Avatar
Yes just took old one out and put the new one in, and I've been driving so its fine
And the problem with it being a bad turbo is I have a SC
Old Nov 21, 2011 | 03:06 PM
holidai's Avatar
Could one of the gaskets between the midpipe and catback have gone bad.
I had a gti before this and the exhaust was all clamps so I've never experienced it happening
Old Nov 22, 2011 | 10:31 AM
snoftall's Avatar
my bad, didn't see anywhere in your posts that said if you were SC or TC.
Old Nov 22, 2011 | 02:05 PM
06G85's Avatar
I had a hissing sound only on acceleration and I thought it was an exhaust leak. Come to find out it was a hole in my flex pipe. Then eventually my flexn pipe completely blew out and i was runing open headers. HELLA loud bro lol
Old Nov 22, 2011 | 03:58 PM
Yeah, I was just gonna say.. if it wasn't the tensioner, most likely something with your flex pipe.
Old Nov 23, 2011 | 10:31 AM
Chevrolet Cust Svc's Avatar
Holidai,
I see that you've already replaced your timing chain tensioner, and that you're now looking into gaskets. If you do decide eventually to work with a dealership towards diagnosing this concern, please let me know!
Best,
Sarah
GM Customer Service
Old Nov 23, 2011 | 12:53 PM
holidai's Avatar
Ppo
Originally Posted by Chevrolet Cust Svc
Holidai,
Best,
Sarah
GM Customer Service
Thanks sarah I actually have a appointment Tuesday to get my power steering recall Taken care of and if I ccant fix it by then I'm going to ask them to look at it, if it is the flex pipe would it be covered under the same 10yr warranty as the catalytic being its part of the same pipe
Old Nov 23, 2011 | 01:02 PM
rivaladore's Avatar
You can also try tightening your header bolts down, some people have had a problem with them not being tight enough. I had a sound coming from the passenger side too and it was the header bolts. The bolts going to the head not the downpipe.
Old Nov 23, 2011 | 01:36 PM
holidai's Avatar
Ok I'm gonna have to check that out too, my brothers a mechanic and we were feeling around for a leak in the flex pipe and header area but couldn't feel any exhaust coming out but I'm going to check the header bolts when I get off work
Old Nov 23, 2011 | 02:31 PM
Ppo
Sounds great! Please keep me updated on how things progress at the dealership.
All the best, and a great Thanksgiving!
Sarah
GM Customer Service
Old Nov 27, 2011 | 11:22 AM
bratboy90's Avatar
rofl
biniecki
Oct 25, 2015 02:23 PM
Jimmy Beilfuss
Oct 5, 2015 04:18 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
Tupp
Sep 30, 2015 08:18 PM
