zzp header/dp to corsa exhaust problem
stock header and d/p is ... ummm .... meh....
Do you have the corsa sport? If so, I hope you like abnoxiously loud cars... Depending on how nice youre local popo is, you can expect some attention for sure.
WHat the hell!!!
Get a 2" gasket?
That would be pissing me off... after all that work..
Is there anyway to move the Corsa towards the DB a bit? SLide the engine back? (j/k)
BTW - Lose the heatshield
Get a 2" gasket?
im hella pissed. it took forever to get all that **** off... what the hell
i might just have to put the bolts on anyways and pull everything together while im tightening it... what do you guys think?
Last edited by ColeJJones; Dec 19, 2007 at 11:49 AM. Reason: Automerged Doublepost
yea, i will be careful. but still. this really does suck!
it bolts up perfectly with with the stock dp/ header... wtf
Last edited by ColeJJones; Dec 19, 2007 at 11:52 AM. Reason: Automerged Doublepost
indeed. Modding always sounds fun in the forums, then when your lying on your back under a car with knuckles bleeding, hidden bolts, and parts that dont fit, you start understanding why some people bring their parts and car to a shop, go for lunch, come back and drive it home. I know how to do **** loads to my car, but sometimes I couldnt be bothered.
Dont worry about this, it will fit.
bro, STOP FREAKING OUT. THIS IS NORMAL!!!!!!!
it will fit. you may have to pull a little bit. pipes are cold, flex sections are cold. i have put on several exhausts, and that always happens. it's not a big deal. stop freakin out so much! and get it done and put sounds clips!
when it's cold it will contract. like things do when they're cold.
