View Full Version : Parts
- For Sale BC coilover, 18X8 Rial Nogaro, Interceptor, Gauge Pod, Cluster Pod, MOAR
- For Sale LsjIon Ported m62, 80# Injectors
- Wanted Oem rear view mirror
- For Sale lnf zzp intercooler increased clearance
- TVS wanted
- For Sale Lnf ecu
- Garage Sale
- Wanted OEM shift boot
- Wanted LNF Lower Charge Pipe w/ MAF relocate
- For Sale cobalt ss stage 3 kit with new cobra heat exchanger
- Nitrous full package deal
- Wanted ZZP Intercooler Package
- Wanted 2.2 l61 cyl head
- For Sale LSJ shorty header, 3 inch DP, magnaflow resonator
- For Sale 06 LSJ Head
- For Sale OTTP Stage 4 LSJ Camshafts
- For Sale id1000s big boy injectors w. harness
- For Sale OEM SS fog lights in PA
- Wanted A pillar dual gauge pod with rpd
- For Sale Turbo XS CAI
- Looking interceptor (PT) for lsj
- Wanted Aftermarket LNF mods
- Wanted Front End parts
- For Sale stage 3 clutch
- For Sale SS/TC intake, charge pipes,TWM shifter,guages,down pipe
- For Sale SS/TC FE5 Coil Springs **Low miles**
- Wanted Stock 08-10 SS Intake
- For Sale HP Tuners Standard
- Wanted K&n sri
- Interceptors for LNF and 3gauge pod
- LSJ Cylinder head
- FS: OTTP neutral balance shafts and GMPP Clutch upgrade
- WTB - internal items
- Pedders Springs
- Avid Motor mounts front and rear
- Blox aluminum open extended 12x1.5mm 20pcs
- Wanted HP Tuners.
- Wanted Piece from parts/JY car
- ISO: Aftermarket Lower Charge Pipe (LNF)
- Hp tuners
- Wanted HVAC Control Unit, Floor Mat
- For Sale LNF Parts: 3bars, injector rail, turbo, DP
- Wanted Catalytic Converter
- Wanted G5 tail lights
- For Sale Crackhead cheap mods/some stock stuff
- Wanted Side Skirts
- Wanted Steering Wheel for 2007 SS S/C
- Wanted WTT: Hahn LNF CAI for....
- For Sale Complete LNF w/Turbo, and Transmission
- Wanted Powell Oil Seperator
- Wanted OEM TURBOCHARGED badges (2)
- For Sale Side skirt clips, TC head rests, OEM Lugs, and more
- Looking for Turbo Parts, for my Lsj.some lnf stuff works
- Wanted Wanted. Limited Slip differential.
- For Sale Tvs, pulleys, header, downpipe and some others
- For Sale prothane sway bar bushings
- For Sale zzp upper charge pipe with bov for sale
- For Sale FIC 1200CC injectors
- Cobalt ss parts stock turbo, intake cam , hahn intake
- Wanted Lowering Springs and Struts/Shocks
- Wanted Cobalt Coupe Third Brake Light
- Wanted LSJ T Parts
- zzp downpipe and header NORCAL and momo floormats
- Wanted Lsj camshaft caps needed
- For Sale NEW Performance Autowerks 80# valvesprings
- For Sale Mongos Winter Sale
- Wanted WTB/T: ZZP Pulley
- For Sale FS: Cluster Dual Gauge pod
- Did i get duped?
- For Sale Powell CABs $175 Shipped
- Cobalt ss front passenger strut/spring handling suspension option fe5
- Wanted aftermarket intercooler
- Wanted WANTED - LSJ Throttle Body
- For Sale 60lb injectors NEW $100 shipped
- For Sale Hockeyman's Garage Sale
- For Sale Neochrome dip pearls
- For Sale trans mounts off an LNF
- Wanted looking for a front bow tie
- For Sale Used m62 with lsj throttle body
- For Sale SSR Type-C RS Wheels
- Wanted Parts (Stage 3, Exhaust, Seats)
- For Sale Cobalt Headlight Bulb Harness
- Wanted 60lb or 80lb injectors
- LNF Everything For Sale!!!
- Wanted Pcm
- S256ET turbo
- For Sale Ksport coilovers
- Wanted 80lbs Injectors for LSJ
- Wanted wtb intermediate shaft
- LDK brand new engine block
- For Sale TRU-boost gauge, ebay ic & bov, lsj alt
- Wanted Lowering springs
- For Sale 2007, 5 Lug, Pontiac G5 rebuilt/powder-coated front calipers
- Wanted Looking for Parts for 07 SS/SC
- For Sale Things and stuff
- For Sale FS: trifecta black box cable
- Wanted s/c parts for 2.4l
- For Sale Retrofit headlights!!!!!!!!
- Wts: Ttr mani & zzp lk9 mani
- Wanted 2007 ss shop manuals
- Wanted Rear sway bar, aftermarket IC
- Wanted Need a few things
- Wanted
- For Sale 17x8 5x114.3 TSW Max Wheels Will Not Fit Cobalts without Wheel Adapters
- For Sale GM Stage 2 Fuel Injectors Used
- For Sale OEM Cobalt SS Supercharged Open Differential
- For Sale OEM Fuel Injectors For Cobalt SS
- For Sale New Hawk HPS Rear Brake Pads
- For Sale Rial 17x8 Wheels
- For Sale Injen Intake for Supercharged Cobalt SS
- For Sale Cobalt SS Supercharger Pulley
- For Sale Aluminum 3.35 Supercharger Pulley
- For Sale GM Stage 2 Pulley
- For Sale Yellow Powell Motorsports XXX Rear Sway Bar
- For Sale Hahn Racecraft CAI For LNF
- FS: SSC springs, Injen Intake
- For Sale 3 bar map, bypass solenoid, MAF relocate, Sway bar brackets
- For Sale ZZP 3.1 Pulley, Tensioner Pulley, Pulley boys Tension tool
- 17 inch ss wheels n/a NOT SOLD YET
- For Sale Wide selection of quality garage equipment at CARiD!
- Wanted : fuse box cover and few other things
- Wtb. Aftermarket intake for lnf
- For Sale Big turbo setup!! any engine!
- For Sale stock lnf parts for cheap
- Wanted SS shifter assembly
- F/S Innovate LC-1 Wideband and 2.8" Pulley
- Wanted WTB stock LNF intake
- For Sale ZZP S3 Heat Exchanger (Near New!)
- Wanted: Stock exhaust tip
- For Sale Don't miss the opportunity to get the Christmas presents from Injen at CARiD!
- Wanted MAP Sensors
- For Sale Basic LSJ parts (injectors, harness, fill tube, sensors)
- For Sale FS: TTR Solid Engine and STOP Trans Mounts
- Wanted 30psi LNF boost gauge
- 2.0 LSJ Engine WTB: Cam Angle Sensor
- For Sale Parts you want!
- For Sale Mongos Cabin Fever Sale LNF LDK
- Wanted Cobalt 2.0 half shaft
- For Sale LSJ & L61 parts for sell
- For Sale Two red LED ss clusters
- For Sale GM Stage II NIB
- For Sale Complete Stage 1 zzp supercharger kit for 2.2l
- For Sale Jensen Touch Screen Radio (Nav,DVD,USB,AUX,Bluetooth)
- For Sale SS/TC springs
- For Sale Retrofits
- For Sale 17 inch ss wheels
- Wanted nitrous
- For Sale Carbon Fiber Hood/Trunk, Triple Gauge Pillar, more.
- Wanted ASAP: ISO Random Bolts.
- Wanted Exhaust Cam, lash adjusters, and rocker arms needed
- Wanted hood & bumper
- Wanted VR SS Bumper Cover
- LSJ Long Block
- For Sale HP tuners
- For Sale Yakima Roof Rack Cobalt 2dr & Mountain Bike Accessories
- Wanted SS side skirts
- WANTED! Stronger # Valve Springs & Retainers for LNF
- For Sale pioneer AVIC-F900BT Double Din GPS Unit and all the goodies!
- For Sale Varrstoen Es6 18x9.5
- For Sale Sway Bar Bushings 24MM
- For Sale OEM LNF springs
- For Sale Stock Subwoofer & Black HVAC Controls
- For Sale Plastics, Seats, PCM, Header, shocks, misc. bolts, airbox and more
- Stock headlights off 06 SS/SC
- For Sale 3BarMaps,HPTuners,TrifectaRedCable,Brembos,Passpor t9500ix
- 2.0 LSJ Engine almost complete turbo kit lots of new parts
- For Sale LNF HP fuel pump, Helms manuals, SS/TC grille
- For Sale Devil's Own Progressive Meth Kit
- 2.0 LSJ Engine Brembo Swap Parts
- 3" pulley
- NEW LNF ECU, Innercoolers, A Pillar Gauge Pod, Airbox Lid, Turbo Intake Tube & MORE
- Wanted LNF Rocker Arms n Lash Adjusters
- For Sale Ebay LongTube Header Setup
- For Sale Left Over Stuff, Specialy Tools
- Wanted LNF Coil Pack Cover
- For Sale BPS STS. Black. (05-10 SS Only)
- For Sale FS/WTT: Injen Upper Charge Pipe
- Cobalt Sedan Weathertech Window Deflectors
- wanted: clips to install rear/front valances.
- cobalt ss front lip...
- Wanted Wanted: Coilovers
- For Sale Misc. Parts for $50 and under! Need gone!
- For Sale Ingalls Engine Damper
- siemens 60LB injector with harness
- ingalls engine dampner
- gm stage 2 42LB injectors
- For Sale brand new m62
- Wanted M62 kit
- For Sale 1" (25mm) 4x100 stud wheel spacers
- For Sale Fall Cleanout: Seats, valve cover, cylinder head, seatbelts, etc
- Wanted TC Wheels
- Wanted Phenolic spacer
- For Sale Trifecta Red Cable $110
- For Sale Lnf parts and misc
- Wanted td04L-16t or corresponding turbo for lsj
- For Sale Treadstone BPV Block Plate, ZZP MAF Relocation Harness
- For Sale ZFR turbo
- For Sale zzp brfps and more
- For Sale 07 FE5 Shocks N Struts
- Wanted LNF LCA's
- For Sale Vibrant 2.5" VBAND
- For Sale Turbocharger
- For Sale lollypop red brembo calipers. freshly coated
- Wanted- Brembos
- For Sale Random parts for cheap
- Wanted Right (passenger) side LNF Knuckle
- Misc. Parts
- Wanted transmission bolts and transmission mount bolt
- For Sale Rear SS leather seats
- Front Bowtie
- For Sale Turbo kit FOR SALE S256ET
- For Sale Saab intake manifold for LSJ-T setup
- 2007 ss/sc complete part out
- Wanted LNF Clutch
- For Sale Ev6 60#, L61/LNF Gates Belt, Autometer n2o Gauge
- Wanted ZZP Addjustable Clutch Rod
- For Sale Stock Parts off 2008 LNF
- Wanted Stock k04 Turbo
- Wanted Wheels and tires?
- For Sale Red Cobalt low rise spoiler for sale
- Wanted OEM Shifter Cable Clamps (SS/SC/TC)
- GETS NO BETTER...... parts for sale
- spec stage 1 clutch for sale
- Wanted M62 Actuator
- For Sale Parts from 08 LE5/ 06 LSJ
- Engalls Engine Torque Damper
- For Sale LSJ/L61 stuff for sale :)
- Wanted Door panel, Shift boot
- For Sale LNF GMPP Clutch & OEM LNF Flywheel *Brand New*
- For Sale Phenolic Spacer & Walbro 450lph fuel pump
- Wanted LSJ stock stuff
- zzp stage 2 supercharger cams and supertech valves
- LNF Turbo Kit For Sale S256ET unused
- For Sale Hallman in cabin boost controller
- Wanted G5 GT Interior Carbon Trim Piece (left of Wheel).
- Wanted 08+ Black Radio Face w/ USB and AUX in
- For Sale L61/LSJ spare parts that I don't need
- Wanted HP tuners Standard
- For Sale For sale wheels and tires
- For Sale Retrofits . Color changing halos. Morimoto.
- Brake lines, tow hook, cable clamp, lnf mount, tvs pulley, tb spacer
- Wanted Parts
- For Sale 252et Turbo needs rebuilt
- For Sale Oem f35 lsd
- For Sale Many parts, Sc kit, seats, manifold
- For Sale Retrofits and Double Din GPS unit for grabs
- For Sale New LNF Throw Out Bearing
- Wanted 60lb injectors and 3.0 or 3.1 pulley
