View Full Version : Parts
- Some leftover lsj goodies
- Wanted headlight harnesses
- HPTuners VCM MPVI PRO Editor+Scanner 8 GM Credits! Cheap!
- Wanted 2008+ SS boost gauge
- Wanted Speedometer clueter 2008+ SS
- Wanted 2008+ headlights
- For Sale ACDelco Spark Plugs - ACD#41-108, GM#12620540 - OEM Cobalt SS
- For Sale GM Transmission Fluid 88862472 - 2 Bottles
- For Sale Carbotech CT1095-AX6 Rear Pads - Cobalt SS/TC
- Wanted ss front bumper lip
- Black/White cobalts! Retrofit headlights for sale brand new
- For sale.
- Aeroforce Interceptor Blue Cobalt SS Edition
- Wanted Full suspension for 09 cobalt ss
- FOR SALE: Custom Suede Door Panels
- For Sale Dual pass endplate
- For Sale ***LED Kit - NEW - $10 Shipped***
- Wanted Elbrus i05 Hubcentric Ring
- For Sale ZZP LNF intake tube
- 2008 Cobalt SS Total Part out
- CBM Remote Oil Filter Adapter
- For Sale More LNF Stuff
- For Sale Full part out thread TVS Cams seats & more custom
- 2.0 LSJ Engine FS: S/C, Dowpipes, valve covers and more!
- FOR SALE - MISC Cobalt Parts
- WTB GM stage 2 for 07 lsj
- For Sale 80# OTTP Valve Springs
- For Sale Southbend Stage 4 Clutch
- For Sale injectors, oem pulley, ttr manifold
- For Sale Gen 1 LSJ block, sleeves and rotating assembly
- For Sale Morimoto Retrofit build, radio install kit, interceptor, new parts
- Engine with supercharger
- GOT SCAMMED $50 BY KEVIN FRIERMOOD AKA Kfrizzle
- For Sale l61 and lsj stuff
- For Sale Carbon Fiber dash trim and center console complete kit
- For Sale Stock LSJ Supercharged TB, ECM and Injectors
- For Sale Mongos Winter Solstice Sale
- For Sale LNF Stuff - ZZP Catback, CIA Downpipe, K&N Intake
- LSJ Parts "stage 2" setup
- More ZZP/Ecotec Goodies
- Wanted Black hvac
- For Sale Comp cams
- For Sale GMPP LSJ Clutch kit, Flywheel, Dual Gauge Pod, Interceptor
- For Sale GMS1 Sensors, Navigation and DVD Headunits, Double Din Install Kit.
- For Sale Brand new OEM LDK Intake cam.
- Complete part out lsj
- For Sale M62, Manifold and TB
- For Sale F35 LSD Partout 3.82
- Wanted pair of tires for inspection/winter
- Wanted Stock Passenger Side Seat near NJ (pref black)
- Shift Boot Plastic Ring
- For Sale LSJ Parts AEM CAI, ZZP Lowering Springs, 42# injectors
- For Sale LSJ Pacesetter header & (NEW) OTTP DP w/cat + 02 bung
- Wanted ZZP 3in intake LSJ
- Wanted Turbo lsj parts
- For Sale 9k mile lhu part out
- For Sale LSJ stage 2 factory gm kit - new in sealed box
- For Sale LSJ Parts and LNF Stock Downpipe
- Wanted Yakima Roof Rack for SS Sedan
- For Sale t304 stainless header and downpipe
- LSJ Pacesetter header & (NEW) OTTP DP w/cat + 02 bung
- Heat exchanger pump with bracket and TMAP connector for SC swap
- For Sale Some LSJ or SC swap stuff
- 4.45 gears and bride seats
- For Sale Complete Part out!!! 06 SS LSJ
- Wanted 07 g5 cruise and power locks
- For Sale "BRAND NEW" 17" high performance winter tires for sale
- For Sale 2.2 L61 Slightly ported bare head
- Fs: unlocked 07+ radio and custom HVAC
- For Sale Aeroforce LNF
- Wanted WTB Stock LSJ Downpipe
- Lsj pistons and rods
- New Front Hub Assembly Cheap (5 Lug with ABS)
- Cobalt SS Gauge Cluster Cheap
- For Sale LNF engine parts
- NEW 4.45 gears and Quaife LSD F35
- Wanted Enkei's! M52s or Pf01's
- Wanted 3.15 TVS pulley (80mm)
- For Sale TWMP shifter
- For Sale ZZP Adjustable clutch rod
- Wanted Lsj lower intake manifold brace
- For Sale S/C parts, Interceptor, radio/hvac
- Wanted GMPP clutch + brake covers
- Wanted Stock LSJ Intake
- For Sale GM upgrade clutch kit GM 19212712
- N2MB 2 step box.
- Wanted Stock SS Shifter assembly.
- Wanted aeroforce
- For Sale Small lot for sale. SS/TC parts.
- For Sale Ebony Armrest:
- For Sale LNF Brembo kit
- For Sale complete Armrest and other stuff
- 2.0 LNF Engine LNF engine parts
- Wanted Shift Boot Retainer Ring
- Zzp 2.9 pulley
- For Sale GMPP Stage 1/2 42 lb/hr injectors & NGK AFX wideband
- For Sale Blue LSJ Aeroforce Interceptor
- For Sale tykuura's cleanup sale
- Wanted LSJ Stock parts
- For Sale Eibach Sportlines
- For Sale Drag radials with wheels
- 2.0 LNF Engine WTT Hahn Coolram Intake for K&N intake
- Wanted lsj dp
- For Sale Fore sale: Superchips and Injen intake
- For Sale Garage Cleanout to Fund Supercharger Build
- Wanted GMS1 or 3 bar map sensor
- Soundstream 4 channel amp
- Another LDK manifold, not painted, no throttle body gasket
- For Sale Japeatr's Garage Sale
- For Sale new garage cleanout thread
- Performance Autowerks valve springs
- Misc K04 lines/brackets
- For Sale Brand new CM Springs for Base Cobalts (2.2)
- For Sale Brand new Exedy clutch
- For Sale New GMPP Clutch, PP+disk only - $150obo
- need some ss supercharged parts
- Wanted Stock LSJ 2.0L intake
- Garage Sale
- For Sale Suspension Parts and some other junk
- Wanted Catback and remote tune
- traction bars,heat exchanger pump
- 2.0 LSJ Engine fidenza flywheel,clutch masters stage 4
- For Sale Varrstoen ES3, Shaved G5 Trunk, K&N Intake, SS door panels, Short Throw, Moar
- Wts: black on black s/c leather seats
- Wanted Rear coiliver spring perch
- For Sale ZZPerformance midlength header combo
- For Sale Wheels and tires for T/C
- For Sale ZFR 6758 K&N catless DP
- For Sale headlamps that need some work
- For Sale Forge VTA BOV
- Wanted LNF grille, ultra silver SS front lip- any condition
- Exterior SS parts
- Wanted 08-10 oem headlights
- Wanted GMPP exhaust manifold
- 2.0 LSJ Engine LSJ short block feeler
- For Sale Pedders
- For Sale LSJ Idler and Tensioner w/oversize pulley
- For Sale LDK intake manifold - black, lightly ported.
- Wanted 2.2 Supercharger Kit
- For Sale Aftermarket Sale, Take a Look
- Wanted Victory Red High Rise Spoiler
- Wanted OEM Leather Wrapped Shift Knob
- For Sale ZZP 82# springs/stock style retainers ($200)
- For Sale Seat headrest braces
- For Sale Cobalt SS engine parts for sale..mostly LNF
- 2.0 LSJ Engine aem wideband,zzp front mount exhanger,stock exchanger
- For Sale New F40 TOB GM:55565331
- For Sale LHU Longblock and BNR with goodies
- Wanted Coilover parts
- TWM Short Throw Shifter
- For Sale new parts
- For Sale 05 lsj partout
- WTB: HPTuners
- WTB: Fe5 Control Arms LSJ
- Wanted Wanting to trade my 2.7" zzp modular pulley
- For Sale Enkei, Vision, stock wheels, hubcaps
- For Sale Hoosier DOT Drag radials, wrapped on 17" rims (will fit brembos)
- For Sale (2) 225/40 18 Continental ContactSport A/S tires
- Wanted WTB Transmission and clutch
- For Sale GT2871r
- Injen upper charging pipes w/ bov flange
- Wanted small and misc parts I know you have to sell
- Wanted HP Tuners, Downpipe, Catback
- For Sale Stock SS/TC springs and Stock SS trunk with high rise
- For Sale tons of lsj goodies
- Hp tuners cable
- For Sale 2009 Cobalt SS Catalytic Converter
- Wanted Zzp intercooler and 3 bar maps
- Wanted 1000cc injectors
- For Sale Brembos off 2010 cobalt ss complete set $300
- Wanted 2.6 pulley,good lsj head
- parts for sale
- TVS and other lsj goodies
- Elbrus rims with near new tires
- Wanted Zfr 6758
- Vibrant resonator for sale
- For Sale Varrstoen 5x110, Roofrack, Header, Downpipe, MAF Sensor, More
- Wanted Charge pipes and down pipe
- For Sale Ss front bumper
- For Sale LS4 Throttle Body & Stock LSJ Endplate
- Wanted K04r
- For Sale OTTP LSJ intake
- Parts- interceptor for lsj, 3 pillar, 2.8, more!!
- WTB: Cobalt SS Hitch
- For Sale Cobalt zzp 5 Speed Aluminium shifter base bushings
- Zzp longtube catted setup for sale
- For Sale LNF Intake Mani
- For Sale Factory ss/SC muffler
- For Sale Supercharger parts and more
- For Sale Forge BPV
- For Sale arm rest & interior trim (carbon fiber look)
- Wanted ZZP mid header or similar
- For Sale 2008 LNF Long Block, G85 Trans, K04 Turbo, FULL ASSEMBLY
- Wanted Wtb s256et
- For Sale PAC Steering Wheel Controls
- Wanted Bolt on turbo
- Wanted 06 fe5 front sway bar
- For Sale 09 SS/TC RPD and A Pillar for SALE!!!
- LSJ..2.8 pulley,42lb ingectors
- Wanted K04r
- Wanted OEM headlight harness
- For Sale Carbon Fiber Trunk & ZZP S3 Heat Exchanger
- For Sale Tire Totes
- For Sale Big Dawg LSJ Stuff
- Wanted LNF 3 bar map sensors w/ harness adapter
- Wanted 2007 2.0 SC/SS Spark Plug Coils
- Cobalt SS Edition Aeroforce Interceptor F/S
- 2.0 LSJ Engine Looking for a header
- Wanted WTB: Suspension and Interior parts
- For Sale Brand New LNF Opel Injectors + Fuel Rail Upgrade for Gas and E85
- Wanted Coilovers
- Wanted All turbo LSJ parts
- Solid rubber front transmission mount
- Wanted K&n Intake
- For Sale #80 injectors, 2.8 pulley, ladder tach & boost gauge (cobalt & ion parts)
- Looking for stock black front and rear bumpers,
- need a apple itouch 5th gen+
- Wanted 07+ steering wheel
- For Sale Lots of LSJ Mods and Parts
- For Sale Lsj pcm
- For Sale ZZP Longtube header
- Wanted Rear sway bar/powell springs
- Wanted Cobalt SS Front Lip and OEM Wheel Center Caps
- For Sale Wesico L61 pistons. 10:1, .020 over $395
- Enkei 18 for cobalt ss
- Wanted Duel/triple gauge pod, wideband for lsj
- For Sale moving sale
- Wanted K04R Turbo
- For Sale id1000 Injectors
- For Sale: Sedan 2 pod a pillar, moog sway bar end links, PAC Adapter and hose
- timing wheel
- Wanted Turbo XS RFL or FL catback
- WANTED: 2007 OEM base radio
- For Sale GTR style LED taillights by colodude18 for sale
- For Sale Shaved door kit
- dark gray, charcoal interior trim
- For Sale Moving, need to sell asap
- 2.0 LNF Engine Complete lnf cylinder head
- wanted: front bowtie w/ nuts
- For Sale SALE !! Tons of Stuff
- Wanted Lnf k&n sri
- For Sale Jvc kw-av60bt
- For Sale ((LNF PARTS)) R1 slotted rotors/Hawk Pads/Depo projector light/Tail lights...And MORE
- For Sale Custom Forgestar F14 wheels for cobalt ss brand new
- For Sale Brand New Custom Stance Coilovers
- Wanted Interceptor for lsj
- For Sale Zfr 6758 with turbosmart wastegate , Opel injectors and GMS1 sensors
