5 lug swap
Old Jun 9, 2012 | 10:17 PM
MastaShaKe_88's Avatar
wat'd you do for the rears? did you swap the whole axel?
Old Jun 9, 2012 | 10:35 PM
BLKLS's Avatar
Hell no, that's to much work lol. Unbolt hubs, replace hubs.
Old Jun 18, 2012 | 08:25 PM
BLKLS's Avatar
Just a quick little update, finally had a littlebit of open roads tonight, (very little), but I was surprised. It feels way better then I thought it would. No idea where it's limits are yet but it's already got me more confident then before.
On the other hand, not sure if its all from the added weight, everything weighs more, or that I have been driving a little harder to make up for the feeling of the loss of power but I'm down from 28/29 mpg down to 25.
Old Jun 18, 2012 | 08:51 PM
tpete763's Avatar
Good to know! Maybe because the sc rims are bigger than the stock ls ones the computer is reading the data wrong? your speedometer is probably off a few mph as well.
On a side note, I've got sc hubs coming to me soon and I'm getting them redrilled to the 5x114.3 bolt pattern, So hopefully I'll have a 5x114plus an lsj brake swap done within the month
Old Jun 18, 2012 | 09:58 PM
BLKLS's Avatar
Sweet man, I checked the tires with an online tire calculator it told me to use 225/35 18 as a direct replacement size but one, I was mounting the tires, 35 profiles are a bitch, two as you know PA has some potholes I don't feel like bending the crap out of rims so I went with 225/40. Only supposed to be like 1% off or something. But even on the turnpike keeping up with traffic it seems ok. I haven't been able to really check it yet.
I would have done the 5x114 thing but I felt it was just to much of a hassle to get rotors drilled every time I needed them.
Oh and I read on here somewhere that the 4 lug and 5 lug abs rings have different tooth counts so if you have abs it will no longer work. Keep that in mind people!
Old Jun 19, 2012 | 12:54 PM
Brags's Avatar
Got a few preview pics of my lug/brake swap. PRS lsj BBK, and rear PRS drum to disc
Thanks to Performance Autowerks and Powell Race Shop!
Old Jun 19, 2012 | 03:18 PM
huh? Wat'd you do then??? I thought the rear disc brakes wouldn't bolt up to a drum brake rear axle
Old Jun 19, 2012 | 07:40 PM
BLKLS's Avatar
Powell sells a kit but I didn't change to rear disk. I just changed from 4 lug drum to 5 lug drum.
Brags I love the wheels
Old Jun 19, 2012 | 07:51 PM
ROB517's Avatar
Is there any down fall of having hubs redrilled?
Old Jun 19, 2012 | 09:05 PM
BLKLS's Avatar
Just having to get rotors redrilled every time you need rotors. On the up side you have more wheel options. That's all I know of.
Old Jun 19, 2012 | 11:35 PM
  #36
tpete763's Avatar
Interesting, I thought they were all the same, just that if you don't have ABS, it wont matter if you get new hubs with ABS. You just have to leave the sensor disconnected, or cut it off. I hope this isn't so because I have no ABS and the hubs I bought do unless you are just referring to the ABS sensors (which i hope you are) lol
Old Jun 20, 2012 | 12:08 AM
  #37
Brags's Avatar
Thank you sir
Old Jun 20, 2012 | 06:42 AM
  #38
BLKLS's Avatar
Yeah, that's what I did just cut the front leads off I have no abs. But there's a thread around somewhere a guy with an hhr went from the 5 lug to 4 lug for wheel options and his abs no longer worked. Someone said it was because the tooth count was different so if you have a s jus keep in mind it may not work after.
Old Jun 20, 2012 | 01:34 PM
  #39
tpete763's Avatar
Whew! Sounds good to me man! I read that in another thread, that some lsj/lnfs have a different voltage for the ABS, so when someone swapped LSJ hubs on their LNF they had a CEL on because the voltage was reading wrong from the sensor.
Old Aug 6, 2012 | 11:27 PM
  #40
tpete763's Avatar
So I swapped over to LSJ front calipers and 5 lug rear drums saturday and also to a 5x114 bolt pattern. What do You guys think?
Next in line is some lowering springs to get rid of some of that wheel gap.
Old Aug 7, 2012 | 06:37 PM
  #41
BLKLS's Avatar
Good deal, by anychance you didn't end up with a highway speed raking vibration in the rear did you? I changed the shoes and still got it. Haven't had time to recheck my wheel balance yet tho.
Old Aug 7, 2012 | 07:48 PM
  #42
Dark Cobaltz's Avatar
send me a link to where you got all the parts. Thank you.
Old Aug 7, 2012 | 09:40 PM
  #43
BLKLS's Avatar
Every thing but the wheels and tires I got from local parts stores.
Old Aug 7, 2012 | 11:33 PM
  #44
part numbers bro part numbers.
how much did all of it cost you?
Old Aug 8, 2012 | 07:43 AM
  #45
BLKLS's Avatar
Pffff part numbers, no idea. I got all my hubs threw parts at work. I got a steel of a deal on the wheels, tires, and front calipers. Cost me about $1100 all said and done but I only spent 400 for tires, wheels, and the calipers.
Any parts store can get you the parts. Just tell them what your looking for, fronts off a cobalt ss/sc and rears off like an 09 five bolt ls.
Old Aug 8, 2012 | 01:58 PM
  #46
tpete763's Avatar
Not really, I definitely need an alignment and the lower profile tires make more road noise than my other ones but no vibrations in the rear.
Old Aug 8, 2012 | 02:03 PM
  #47
tpete763's Avatar
I bought the LSJ calipers off here, the rear drums off ebay, the front pads/rotors from the auto store, and the LSJ hubs off ebay as well (from dearborn axle, I have bought hubs from them in the past and they work great). All these parts cost me a little over $500. The wheels I have had for years from my previous car cost me $900 used at the time from my sister's fiance.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ThoR294
Oct 4, 2015 08:44 PM
ernnyyes
Oct 2, 2015 05:16 PM
ThoR294
Sep 28, 2015 05:31 PM
