B+G Cobalt Suspension have finally arrived
Old Aug 18, 2008 | 06:22 PM
  #76
B-G Suspension's Avatar
Originally Posted by zinner
What setting are you guys using? I am getting a lot of bouncing in general. I have the rears as low as they will go and the fronts about 2 inch lower than stock.
Zinner,
do you have the rear shocks as short as they will go? also do you have your springs just set so they are tight..? and doing all the lowering using the front bottom mounts?
mike
Old Aug 18, 2008 | 09:37 PM
  #77
zinner's Avatar
Moderator Alumni
Originally Posted by B-G Suspension
Zinner,
mike
Yep. There is no spring preload in the front. And as far as I can tell the fronts ride/act ok.
The backs are bounce, unless there is something I don't understand. When I hit a speed bump/dip in them it seems like the rebound in the rear is very strong and the car spring up pretty hard. Should I turn up the dampening? I have the rear dampening at the middle 5/6 from the softest and the fronts are at the softest.
Old Aug 19, 2008 | 12:45 AM
  #78
stryder's Avatar
hey mike im getting a creaking sound from the front passenger side any ideas on this noise?
Old Aug 19, 2008 | 12:44 PM
  #79
try lubing up the pillow ball mounts some more.. they will take time to break in..
Old Aug 19, 2008 | 12:51 PM
  #80
ls1fbody's Avatar
Haz l33t wheelz.
my k-sports did the same thing, drop some oil in the pillow ball mounts and drive it for a week, it'll go away. sounds like the spring is winding up and slipping? kinda like an echoing pink/clunk?
Old Aug 19, 2008 | 03:18 PM
  #81
stryder's Avatar
yeah pretty much, ok i will lube it up
Old Aug 19, 2008 | 04:56 PM
  #82
Eddie's Avatar
mmmmmmmmmmm lube. n e preference? KY, they have lots of different kinds.
tomj77
Oct 2, 2020 05:36 PM
chefhhr
Oct 26, 2015 10:36 PM
Green
Sep 13, 2015 01:30 AM
jcalvin1126
Sep 11, 2015 10:24 AM
