Failed Spring Install
Okay guys, whats the size of the bolt holding the lower part of the rear strut on? I went to install my springs today and i couldn't get that bolt off so I blew the day. Also how many lbs of torque of a drill will I need to get it off, and put it back on?
There are no rear struts. There are only shock absorbers on the rear axle, and they are the only part you need remove. Actually you only have to remove one side, not the whole thing.
I don't know off the top of my head the bolt size, but I do remember it wasn't anything weird. I think 19MM, same as the wheel lugs. It should screw right out.
Heres a how to;
https://www.cobaltss.net/forums/show...highlight=rear
He removed the top bolt from the shock, I would remove the bottom one, but same thing. Don't cut the stops unless instructed to.
Heres a how to;
Unless the instructions with the springs tell you to cut them, don't.
Read this:
https://www.cobaltss.net/forums/suspension-67/bump-stop-cutting-alignments-camber-kits-lowering-springs-53340/
Read this:
Well thanks to Halfcents speedy response, i went out to home depot got the bits i needed and went back out there. I got my rear springs installed, kick ass. Then i went to do the fronts and decided it was a little over my head, so on Friday ill be having those professionally put in, thanks for the help guys i really appreciate it!
