Failed Spring Install
Old Jun 9, 2007 | 12:22 PM
Xavipheus's Avatar
Okay guys, whats the size of the bolt holding the lower part of the rear strut on? I went to install my springs today and i couldn't get that bolt off so I blew the day. Also how many lbs of torque of a drill will I need to get it off, and put it back on?
Old Jun 9, 2007 | 12:28 PM
Halfcent's Avatar
I'm old school
There are no rear struts. There are only shock absorbers on the rear axle, and they are the only part you need remove. Actually you only have to remove one side, not the whole thing.
I don't know off the top of my head the bolt size, but I do remember it wasn't anything weird. I think 19MM, same as the wheel lugs. It should screw right out.
Heres a how to;
https://www.cobaltss.net/forums/show...highlight=rear
He removed the top bolt from the shock, I would remove the bottom one, but same thing. Don't cut the stops unless instructed to.
Old Jun 9, 2007 | 01:27 PM
Xavipheus's Avatar
Whats your opinion on how much i should cut the bumpstops on the progress springs?
Old Jun 9, 2007 | 02:44 PM
SSdan's Avatar
I removed the top. Worked fine for me. I also didn't cut my bumpstomps.
Old Jun 9, 2007 | 02:52 PM
Halfcent's Avatar
I'm old school
Unless the instructions with the springs tell you to cut them, don't.
Read this:
https://www.cobaltss.net/forums/suspension-67/bump-stop-cutting-alignments-camber-kits-lowering-springs-53340/
Old Jun 9, 2007 | 04:10 PM
Xavipheus's Avatar
Well thanks to Halfcents speedy response, i went out to home depot got the bits i needed and went back out there. I got my rear springs installed, kick ass. Then i went to do the fronts and decided it was a little over my head, so on Friday ill be having those professionally put in, thanks for the help guys i really appreciate it!
Old Jun 9, 2007 | 04:15 PM
06blackg85ss's Avatar
yeah it was an 18 or 19 mm (more towards 18 I think) just spray it with some lubricant and it should come right off... just take the bottom ones off, pretty easy
Old Jun 11, 2007 | 01:02 AM
mkulrey13's Avatar
fronts are easier then doing an oil change man, sva eyour $$ AND DO IT YOURSELF
Oct 21, 2015 11:57 PM
justinchinn
Oct 2, 2015 12:18 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
yellow dragon
Sep 28, 2015 09:49 PM
