Feeler- Solid Front and Rear Strut Mounts.
Old Dec 4, 2008 | 10:13 PM
  #51
laserblue2006's Avatar
Originally Posted by qwikredline
I bet those ground control guys do one for scions isnt that a californication kinda car? well they only have one for a Mr. Two isnt the scion a toyota car deal
http://www.ground-control-store.com/...ory.php/CA=194
I lied the ground control thing is 399 for a pair of them:
http://www.ground-control-store.com/...gory.php/CA=88
I am told that caster is improved by cutting away part of the scuttle and ovalizing the strut tower hole and shoving that top mount waaaay back....so i have read on the internet....
wait explain to me how to adjust my caster??? pm me and tell me
Old Dec 4, 2008 | 10:28 PM
  #52
Maven's Avatar
Unbolt the 3 bolt from your strut mount, jack up car, go GGRRRRRRRRR with a dremel and make the holes nice long oval that extend toward back of car, renistall.
Old Dec 4, 2008 | 10:30 PM
  #53
TurboTechRacing's Avatar
I wasnt sure my self, but that is the first thing that came to mind LOL. Right way to do it or not, it would get you more - (negative) caster (by going back)...
Old Dec 4, 2008 | 10:35 PM
  #54
Maven's Avatar
Positive
Old Dec 4, 2008 | 10:37 PM
  #55
well of course that way....i was looking for a way to do it cleanly and look profesional like the GC piece
Old Dec 4, 2008 | 10:41 PM
  #56
Maven's Avatar
Here the easy way to remember it, caster is the measurement of the steering axis' inclination on a longitudinal plane as viewed from perpendicular to the vehicle centerline, if the caster is negative, then the steering axis will intersect the ground plane at a point behind where the vehicles hub centerline intersects the ground plane. okay so thats not the easy way.
Positive=good good caster=leaning back.
Oh. I C. I know. I was being facetious
Old Dec 4, 2008 | 10:43 PM
  #57
but if i didnt care about aesthetics at all its probly how i would do it...
  #58
Positive
Ha my bad. Positive caster when the top of the strut is back, allowing better straight line tracking. I guess I was driving in reverse
Old Dec 4, 2008 | 10:48 PM
  #59
knoxbox's Avatar
whoa, maven just went off, not in a bad way but lol... it reminded me of will farrel in old school during the debate competition... i just didn't know he had it in him LOL.
Old Dec 4, 2008 | 10:50 PM
  #60
maven is extremely knowledgeabl if you didnt know that then i dont know what of his you have been reading...
Old Dec 4, 2008 | 10:51 PM
  #61
qwikredline's Avatar
because your car is a ricer and the struts are in the middle of the engine bay unsupported, you could grind away reposition, use the stock top mount of course, and then are you ready FIT A STRUT TOWER BAR triangulated to the firewall and you would be kewl and it would do some good and cover up the dremel marks... and as for Maven ****n you I failed math so =good= fall over backwards i understand...thanks oh and one more thing the ricers are bailing out of F1, Honda by Friday, can Toyota be far behind? Good deals on 2.5 million dollar motors
Old Dec 4, 2008 | 10:53 PM
  #62
knoxbox's Avatar
he is more than extremely knowledgable lol i know him from a diff forum and this is the first time i seen that side of him LOL... crazy... good to know tho. i know who i'll be pm'n if i have questions on something haha.
Old Dec 4, 2008 | 10:54 PM
  #63
my struts are all the way at the back...on the firewall...they are actually under the windshield wiper cowl which is why you arent getting pictures tonight because it was too cold....
but a triangulated strut bar does sound good...atleast it would look more functional than the **** bars out for my car....
ok...thought you were thinkin he was another guy dicking around on here...
Last edited by laserblue2006; Dec 4, 2008 at 10:54 PM. Reason: Automerged Doublepost
Old Dec 4, 2008 | 10:56 PM
  #64
ilovecars's Avatar
i luv maven. i sure op dosent but maven knows alll
Old Dec 4, 2008 | 11:08 PM
  #65
knoxbox's Avatar
nope thats not like me at all... i was just shocked cause i never seen that side of him before i knew he knew his **** but i mean dayum haha.
Old Dec 4, 2008 | 11:29 PM
  #66
lol...
Old Dec 4, 2008 | 11:32 PM
  #67
my bad teach me for grinding on your ricer....dont bother with the strut bar then sounds like you dont need it pics will help
Old Dec 4, 2008 | 11:43 PM
  #68
ill get you pics tomorrow...its 30* here and my southern ass doesnt like it....
Old Dec 5, 2008 | 09:21 AM
  #69
dohc v6's Avatar
I dont know what happened to my thread. It kind of got off topic just a bit. The mounts that you showed are camber adjustable. I was not going for this. I was going for a very simple design that would eliminate the rubber stock bushings. I am pretty sure I expressed exactly what you were looking for, not sure why the comments kept coming.
Would you be more interested if I just got rid of the poly bushings and inserted the spherical bearings? If thats all that you would rather prefer thats very easy to do, just makes them more expensive.
Old Dec 5, 2008 | 09:29 AM
  #70
What benifit would your design over stock(OEM)? Assuming you are keeping caster and camber at the same location as stock...
This is where we are confused?
Old Dec 5, 2008 | 11:34 AM
  #71
dohc v6's Avatar
First longevity. It would last about 5x longer than the stock rubber bushings. I have noticed that when people lower there car on the older sunfires and cavaliers, the rubber just cant hadle it. So thats one thing. The other thing, being that they are 90% solid. Its along the same principals of why change your factory motor mount thats rubber to a poly design, it will elimate "play" in the suspension.
Here is what we came up with. These are camber adjustable. They are PROTO-TYPE, we just laser cut these so you can get an idea of what we are going to do to fix this problem. If we do develope these there will be an option to order non camber, and just have a spherical bearing at the top.
There will be a bearing at the top of the plate, just ordered some so they should be here in a day or so. Does this look like a better design?
Old Dec 5, 2008 | 11:42 AM
  #72
except that it is particle board
but seriously im not an expert but that looks 100000x's better than your first product....and it also has MORE functionability...
Old Dec 5, 2008 | 11:50 AM
  #73
dohc v6's Avatar
I know its a proto-type.
All input is greatly appreciated. I want to make sure its perfect especially for the ones that are going to be using them.
Old Dec 5, 2008 | 12:09 PM
  #74
i was joking about the particle board..
Old Dec 5, 2008 | 12:14 PM
  #75
dohc v6's Avatar
Cool, so it looks good. I would like Maven's opinion actually.
