Installed Road Magnet Springs
#201
I don't know if I got a bad set or what, but I bought a set of these last year after reading this thread and they had quite a bouncy ride and I could pull the springs out in the rear without even unbolting the shocks. I wasn't too happy with how high the rear sat either, it didn't really make a noticeable difference, the front was a nice height though. I just replaced them with Stance coilovers recently and they're definitely stiffer but I personally feel like they ride better. Just my 2 cents.
#202
Did u purchase yours directly through roadmagnet or ottp?
Thank you for posting your experience though, not all experiences with certain parts will be perfect.
#204
There is absolute zero bounce in my set. If you were able to take the rear springs out w/o unbolting the shocks I feel there was some "installer error" there. You also mention the rears sat high which also leads me back to installer error (aka not seating the springs correctly). My rear gap is around a two finger gap. I've had these installed on my car for about 1.5 years now, and they are just as good as the day I installed them. Ride is just like SS/TC springs with a little extra stiffness. I'm very particular with what I install on my car, and if these springs weren't top notch, they would have been removed a long time ago.
#207
No I didn't put them in the wrong place haha, it's pretty easy to tell the front from the rear. The springs never fell out, I could just pull them out without unbolting the shocks.
#209
Edit - Man, I'm feeling like a total newb here but correct me if I'm wrong - Would the addition of the adapter cause the rear to sit higher? Or does the adapter just act as a stabilizer to limit side to side movement?
#210
I didn't get those, all I received from them were the 4 springs. Those would definitely solve that issue, but I still didn't like how the front springs sat in the strut.
#211
The front springs sit just like factory in the perch... I do not understand why you had issues.
I didn't use the adapters... Do they just slide over the jounce assembly or?
Yes... they slide over the jounce assembly.
10846042 10107715596090474 4416381645868735925 n
1908468 10107667695862914 5567385209728372192 n
#212
Anymore updates on how people are liking Road Magnet/OTTP lowering springs? I'm looking for a new set of lowering springs. My B&G's are just too low and ride so harsh for my taste. Was debating between the OTTP springs and CM springs. I could care less how the car handles I'm just looking for a good comfortable ride.
#213
I had CM springs before Road Magnet, and there is no comparison between the two. Road Magnet offer great ride and handling.
#214
CM springs have super soft spring rates thus cause a poor ride over rough driving surfaces. If anyone tells you they ride good, they never rode on quality lowering springs with proper spring rates.
#215
Thanks for the input Staged! So do you think that the OTTP springs(Road Magnet) would be a good option for what I'm looking for? I know it's a Cobalt SS and that's it not going to ride like a Caddy. But I do a lot of city driving and I'm just looking for a good comfortable spring that doesn't make my car feel like it's going to break everytime I go over a bump.
#218
Understandable. Again, thank you for your help! I'll see if I can do a little more digging. Just looking for a good daily driver set up.
DANRICKARD
10-01-2015 12:08 AM
