Moog swaybar endlinks
Old Oct 6, 2011 | 05:13 PM
  #76
outtamymind's Avatar
k80252 is for the ss/na suspension and the others are for the ss/sc suspension. you can use both on the ss/na but alot of people prefer the k750012 as it gives the front suspension a bit of pre-load
Old Oct 6, 2011 | 08:42 PM
  #77
BlackyK's Avatar
Great thanks for explaining what the other end links are for
Old Nov 11, 2011 | 12:59 PM
  #78
MadBrad's Avatar
So after reading. I would need the k750012 for my LS with FE5 TC and sportline springs. Or would these not fit on my sway bar?
Old Nov 11, 2011 | 07:13 PM
  #79
FryLoch's Avatar
I just put a set of these in today and it still makes that clunking sound. WTF? I made sure the bolts were tight as **** like trying to stick your dick in a cheerio but it still makes a little bit of that clunking sound. Is there anything else that causes that noise?
Old Nov 11, 2011 | 07:50 PM
  #80
tpete763's Avatar
Control arm bushings, Mine make an awful clunk and it makes my wheel shake when braking from 55+. I got a flat the other day and checked out the bushings while my tire was off, mine are cracked and all worn out. I just ordered new ones today, I will be replacing them next week and I'll let you know if this fixes my clunking.
Old Nov 12, 2011 | 12:01 AM
  #81
08SSTCRD's Avatar
Originally Posted by outtamymind
i dunno the powergrids just seem like a waste of money to me for something that the average driver won't take full advantage of
They are great for fine tuning a track car, buy for a street car/daily driver they are definitely overkill.
The Moog links are very nice quality for $55.
Old Nov 15, 2011 | 09:10 AM
  #82
MadBrad's Avatar
__________________
Old Mar 5, 2012 | 08:51 PM
  #83
Cobalt Smurf's Avatar
Help new to the site
i have an 05 ss s/c and my sway bar end links are shot i need a good site 2 order some good ones i have stock suspension but next month i will be getting the megan coilover kit so any recommendation on a good set of sway bar end links thanks
Old Mar 6, 2012 | 01:19 AM
  #84
06 GM CobaltSS's Avatar
Moog, Amazon.com has good prices on them!
Old Nov 27, 2012 | 09:18 AM
  #85
erockxp's Avatar
So to revive an old thread...I am looking into the moog end links for my 2.4 SS/NA. I am lowered 2" and was just wanting to make sure, I should order the shorter FE5 endlinks (K750012). Also, what's the deal with steering rack spacers? Are these required? Thanks!!
Old Nov 27, 2012 | 08:22 PM
  #86
CordiaDOHC's Avatar
Yes the shorter FE5's is what you want. Not sure why there are 2 #'s. The FE5's to my knowledge were 1 length. Then the FE1/FE3's were a longer length.
As far as the spacers I know they recommended them for sportline equipped cars and I think they are around 2" so I would say yes.
Old Nov 28, 2012 | 12:06 PM
  #87
erockxp's Avatar
Thanks a million!
Old Nov 28, 2012 | 12:29 PM
  #88
Powell Race Parts's Avatar
You cannot SAFELY install rack spacers if you do not have rotated mounts; the steering rack WILL PROBABLY crash into the rear mount when you try to raiseE RACK . Not good. cheers
Old Nov 28, 2012 | 03:27 PM
  #89
CordiaDOHC's Avatar
You cannot install rack spacers if you do not have rotated mounts; the steering rack will crash into the rear mount when you try to raise it. Not good. cheers
Does this apply to autos? It's been a while since ive been under my car but if I remember right it looked like there was room. Then again I'm on eibach pro kit springs so it doesnt matter lol
Old Nov 29, 2012 | 12:35 PM
  #90
erockxp's Avatar
Thanks so much for the tip. I am lowered 2", are rotated mounts and rack spacers not needed?
Old Nov 30, 2012 | 12:16 AM
  #91
tru2nrtt777's Avatar
Powell, unless you are strictly referring to manuals you are mistaken, check the how-to section and search for my thread about installing rack spacers, fe5 endlinks, and fe5 front sway bar... Spacers have been in there for a while with no problem.
Infact, there you go:
https://www.cobaltss.net/forums/how-...s-pics-271421/
Old Nov 30, 2012 | 12:36 AM
  #92
CordiaDOHC's Avatar
Pretty sure he just means the manuals. Since the autos sit differently (figure you know this but not everyone does).
Old Nov 30, 2012 | 07:31 AM
  #93
this is an easy answer. AT or Manual is the same;l they use the same rear mounts and the issue is rear mount ( attached to cradle ( all cradles are the same all years except 2004 Redline pretty much,) to steering rack clearance the trans has not much to do with anything other than as a support for the mount bracket. so nothing to do with it.
You did not take a picture of the steering rack installed. If you put a 10mm spacer under the rack and did not space the rear mount, the housing is most likely touching the mount and there will be marks on the mount/rack housing. Check it out. if you have a 1/4 inch spacer in there, it will clear the mount, but a thin spacer also does not a whole lot for bump steer on a slammed lowered car.
Depending on production car variation for clearances, there is a big risk to break the rack housing from contact with the mount.
Old Nov 30, 2012 | 09:05 AM
  #94
CordiaDOHC's Avatar
Ah didn't know the rear mount was the same. Had always wondered which mounts the autos could use though lol
Old Nov 30, 2012 | 08:05 PM
  #95
IDK, I used the taller ones OTTP sold when the HK rear sway bar came out... I will have to check but I am pretty sure they aren't touching... Weather they are or not I will post back in a few days and let you know what I find...
SSnRXP
Dec 4, 2015 11:02 PM
nathan112i
Sep 30, 2015 07:12 PM
medic710
Sep 6, 2015 08:53 PM
barthello
Aug 28, 2015 11:41 PM
Corrinaannajo
Aug 28, 2015 09:44 AM
