opinions
Old Mar 18, 2011 | 09:33 AM
DerekDTP!'s Avatar
opinions
Trying to choose between drop springs for my 09 ss
Looking at eibach, progress, b&g and h&r
Want the lowest ride height but still decent ride quality
I know coilovers are the way to go but I can't afford a set, had springs on my 2001 Jetta and they were horrible and switched to coilovers but they're alot cheaper for the dub.. I've heard the drop springs for the cobalts ride pretty decent.. Any input would awesome, thanks
Old Mar 18, 2011 | 09:52 AM
metalmedic's Avatar
I just put eibach sportlines on my car this past weekend.... the drop is good and the ride ain't bad at all... got my from zzp for like 220 shipped...
Old Mar 18, 2011 | 09:55 AM
Shibito's Avatar
I used sportlines and loved them. H&R are lower but you will have to worry about scraping more.
Old Mar 18, 2011 | 10:04 AM
DerekDTP!'s Avatar
Im thinking about he eibachs.. I'm not too worried about scrapping.. My Jetta was maybe a half inch from the ground, lip and oil pan.. Roads aren't too bad here
Old Mar 18, 2011 | 10:39 AM
northvibe's Avatar
after the eibachs break in have fun with the harsh ride....although I suspect you should know that when doing lowering springs..
Old Mar 18, 2011 | 11:09 AM
DerekDTP!'s Avatar
By harsh do you mean a really stiff ride or what.. As long as its not bouncey I'm ok with it
Old Mar 21, 2011 | 08:31 PM
NexTnmE's Avatar
I've had sportlines for about 1.5 years. I really like the drop, not excessive, but tasteful. I feel that the handling is slightly better than my stock 2007 springs, but the car does "slam" on big hard bumps...
Old Mar 21, 2011 | 08:36 PM
whyyoumadson?'s Avatar
eibachs are eh drop if you ask me....garbage springs too if you ask me....h&r provides the best drop but the handling isnt good and the ride quality is meh.
Old Mar 21, 2011 | 08:37 PM
Hammbones's Avatar
I picked up the SSC from ZZP. I'm lower than most TC / SC's locally and I'm just SS/NA. I have a 2 finger gap all the way around (2 fingers top of tire to bottom of fender) Ride quality is not bad. A little bumpy on the less than maintained road and you have to worry about rubbing on bad drive-ways.
Old Mar 21, 2011 | 08:38 PM
i think overall the ssc springs are the best way to go for ride and handling...its slightly a downgrade but its very close to stock rates for the lnf... on the other hand it lowers you more then pedders although pedders handle better.
Old Mar 21, 2011 | 08:41 PM
NexTnmE's Avatar
my bad, I didnt realize the op had a 2009. In that case the sportlines would be a downgrade...
Old Mar 21, 2011 | 08:45 PM
everythings a downgrade.....except pedders and the eibach prokit...the pro kit doesnt give you dick worth a drop though and atleast with pedders you get some....
for what he wants i think he would be happy with ssc.... close to stock handling and drops more...h&r has the best drop if you ask me BUT the ride like i said is meh and when i had runflats holy hell it sucked.
Old Mar 21, 2011 | 08:47 PM
NexTnmE's Avatar
yeah... 'tis true...
Old Mar 21, 2011 | 08:49 PM
oh not to mention the pedders rates are still better then the pro kit...so yeah...pro kit is a definate no.
Old Mar 21, 2011 | 08:52 PM
NexTnmE's Avatar
maybe someone should try cutting a coil out of the pedders!
Old Mar 21, 2011 | 08:54 PM
Hammbones's Avatar
No matter what you choose, lowering helps stability at the high end (120+) because the spring has less lateral movement with body slide (and momentum)
Upgrading different things will help with the "loose" feeling the car has with high speeds or hard braking. You won't really notice a difference until you auto-x.
Old Mar 23, 2011 | 10:46 PM
DerekDTP!'s Avatar
When you say 'meh' for the ride quality.. Do you mean stiff? Or more bouncy..lol
Tupp
Sep 30, 2015 08:18 PM
importkiller
Sep 30, 2015 07:18 PM
dasoftest
Sep 29, 2015 02:14 PM
reybalt
Sep 22, 2015 06:35 PM
Haily229
Sep 17, 2015 07:18 AM
