War Stories Post your racing wins. CobaltSS.net does not support or encourage street racing. Be smart and take it to the track.
16psi + C16 + 150shot + 22* timing = Z06 Killer :-)
Old Jul 23, 2008 | 11:33 AM
  #151
Mss26's Avatar
Originally Posted by StreetDreamz
245/45R17 (25.7" diameter) Nitto 555R on a 17 x 8 +40mm Konig Again 5 Opal with a 3mm spacer and NO rubbing. Also lowered on B+G springs.
Thats a nice setup, I'm looking at the same one. Do you need the spacer because you're lowered? I am on stock suspension still and wondering if 245/45/17's will fit.
Old Jul 23, 2008 | 11:41 AM
  #152
StreetDreamz's Avatar
No, it rubs the inner fender liner ever so slightly. It's not because it's lowered. Ifyou take the wheel off and look at the fender liner towards the front of the car where it dips in a little is where it's rubbing. Not the plastic part, the metal on.
Originally Posted by Witt
Oh ok, nice. I have a pair of Hoosier QTPs 26x9.5x16 on steelies I was going to offer you if I end up being able to make it, but as of right now it looks like I have to keep the mrs. occupied for the day.
Yeah the 555Rs are technically my street tires for this car.
Last edited by StreetDreamz; Jul 23, 2008 at 11:41 AM. Reason: Automerged Doublepost
Old Jul 23, 2008 | 12:47 PM
  #153
Crill_Borsby's Avatar
i still dont understand but thats ok, i dont need to. i dont tune cars and never will. all that matters is that someone else understands and i will just pay them to take care of it.
Old Jul 23, 2008 | 12:57 PM
  #154
Witt's Avatar
Are you talking about timing affecting air/fuel ratio?
Timing generally doesnt change afr, especially in supercharged and NA engines since the idea of afr is the input quantity of fuel mass per quantity of airmass. Now heat fluctuations can affect sensor readings that report an approximation of afr such as an oxygen sensor, however generally the actual ratio itself isnt changing.
A turbo car will exhibit different properties since exhaust gas temperature affects the compressor. On an ideal tune, the afr should not change, however the margin of error across a fuel map is usually less precise then the resolution of an o2 sensor which is why turbo cars will show bigger afr swings on a dyno when timing is modified, more importantly, those changes being actual afr changes and not changes in the sensors metering properties.
Old Jul 23, 2008 | 12:59 PM
  #155
06blackg85ss's Avatar
damn man where the hell you been?
Old Jul 23, 2008 | 01:07 PM
  #156
Area47's Avatar
Rent me! per hour
playing choo choo
Old Jul 23, 2008 | 01:24 PM
  #157
ok i think i get so if you advance timing without changing the octane to slow the burn down. it will just ignite early but you still have the same afr.
Old Jul 23, 2008 | 01:27 PM
  #158
Witt's Avatar
Takin a break from car related activities for a bit. Going to finish up a few loose ends with this car next month, run the time I want and call it a day.
Originally Posted by Area47
playing choo choo
This too.
Old Jul 23, 2008 | 01:36 PM
  #159
Area47's Avatar
Rent me! per hour
if you don't break 109.52 with your car. im callin you out f00!
Old Jul 23, 2008 | 01:59 PM
  #160
pjk91's Avatar
look forward to the vid. i predict 12.4 @ 121
Old Jul 23, 2008 | 02:03 PM
  #161
djt81185's Avatar
lol if i dont trap 110+ on my first pass...I will on my 2nd lolol
Old Jul 23, 2008 | 02:06 PM
  #162
ColeJJones's Avatar
Bannned
I beat a viper
Old Jul 23, 2008 | 02:08 PM
  #163
Mss26's Avatar
Originally Posted by ColeJJones
I beat a viper
srt-10? me too but just barely.. i was heat-soaked from beating an amg slk55
Old Jul 23, 2008 | 02:12 PM
  #164
BoostedYards86's Avatar
sadly things aren't looking good for the weather up here in pittsburgh. not sure if the track will be open or not.
Old Jul 23, 2008 | 02:17 PM
  #165
Area47's Avatar
Rent me! per hour
i will send a midget up there in a clown suit to kick you in the nuts if you don't
Old Jul 23, 2008 | 02:27 PM
  #166
You better be. I was trapping 109 before I even put in the C16 or the 150 shot. If you can't trap 109 in the 1/4 all modded up then you might want to kick your tuner in the nuts.
Old Jul 23, 2008 | 02:50 PM
  #167
djt is the tuner lol. i think it would be difficult for him to kick himself in the nuts. PS the track is still open.
Old Jul 23, 2008 | 03:16 PM
  #168
Nope, they closed it. *******. It's sunny and 80 there right now and they closed it. I swear to go if an ant sneezes on the track it's too much precipitation for them to handle and they close.
Looks like no track numbers for me on the blower and bottle. FUCCCCCCCKKKKKKK!!!!!!!!!!!!!!!!! We'll just have to see what the turbo spits out in a few weeks.
Old Jul 23, 2008 | 03:18 PM
  #169
fballman1987's Avatar
um clicky. want to see this at home.
Old Jul 23, 2008 | 03:25 PM
  #170
ya those idiots just closed the track. Its beautiful out now. It rained at 1pm its now 3.30 and perfect out. Its even cool temps.
Old Jul 23, 2008 | 03:33 PM
  #171
It would be awesome if there was another track open Wednesday night. The only other one I know of is 6 hours away in NY lol.
Old Jul 23, 2008 | 05:24 PM
  #172
djt81185's Avatar
lol i had 109 traps about a year and a half ago with 2.5, 60s, intake, and my hpt tune...this year im aiming for high 110s low 120s
Old Jul 23, 2008 | 06:16 PM
  #173
It took you a 2.5 to do that? Shew, better get on the ball with that driver mod thing. I was only on a 2.8 pulley.
Old Jul 23, 2008 | 06:25 PM
  #174
04redline0124's Avatar
either you guys lie, or you ran in negative temps out side lol..down here stage 2 traps 100-102
Old Jul 23, 2008 | 06:33 PM
  #175
Area47's Avatar
Rent me! per hour
