255/35/18
Old Feb 21, 2011 | 11:02 PM
army_greywolf's Avatar
255/35/18
same overall height as factory contis...
Think I can get them over a factory TC rim? What kind of spacer do you think I'd need, my 245s are at the hair's breadth of rubbing now.
Old Feb 22, 2011 | 01:46 PM
87gn06gto07irl's Avatar
255/35/18 is meant for a wheel at least 8.5" wide. T/c wheels are 7.5. 235's will fit the wheel well.
Old Feb 22, 2011 | 05:42 PM
AyrtonSenna's Avatar
There is somebody on this forum that has 255/35-18 on factory rims, but i don't remember who. If you search the thread, you will find it, he also got pix of them. For sure at least an 18x8 rim is more appropriate for that kind of size.
As someone stated above, for that measure a 18x8.5 rim is much better anyway. Once you install them, let us know if you're rubbing
Old Feb 22, 2011 | 05:46 PM
TommyP's Avatar
AWD > FWD
It's not just rubbing you're gonna have to worry about, you're gonna have so much tire bulge that the tire is not gonna sit completely flat on the ground. You're gonna hurt grip more than help it with tires that wide on such a narrow wheel.
Old Feb 22, 2011 | 05:53 PM
Garret's Avatar
Pretty sure shibito had 255's on his
Old Feb 22, 2011 | 05:55 PM
devilbmxer120's Avatar
It also depends on the brand of tire.... Shibito on here had 255/35/18 on with stock rims with no problems.
Lol beat me to it. :p
Last edited by devilbmxer120; Feb 22, 2011 at 05:55 PM. Reason: Automerged Doublepost
Old Feb 22, 2011 | 06:41 PM
bfg kdw2, I've run both 235 and 245 on factory rims, 245 had just a bit of abnormal wear on the inside shoulder but my camber adjustments would point out to you that's probably normal. you certainly couldnt run a dunlop or pretty much ANY all season at 255 i think.
I was just curious if anyone has done it yet, I think I won't rub, 245 doesn't rub on mine. Worst case I'll move up to an 8 inch rim width. Are we sure it isn't 8 inch factory? I never bothered to check but they do seem wide.
Old Feb 22, 2011 | 06:43 PM
EXsoccer1921's Avatar
its all about brand. i've seen 255s of one brand that are no wider than a 225 of another
Old Feb 22, 2011 | 10:01 PM
well, next set ill try 255s and if after the first rotation they wear shoulders and not evenly, then ill step up to a 8 or 8.5 rim, no problem.
Old Feb 23, 2011 | 08:42 AM
jboogie's Avatar
Time to step up to a big boy wheel, Army. https://www.cobaltss.net/forums/auto...rrived-242175/
Old Feb 23, 2011 | 03:18 PM
Really? 255 are supposed to be over 1 inch wider that 225
So you think a 245/35 on a 18x8 rim would be fine?
Last edited by AyrtonSenna; Feb 23, 2011 at 03:18 PM. Reason: Automerged Doublepost
Old Feb 23, 2011 | 06:27 PM
ive ran set after set, this next set being my 8th set, thats 1 set of contis, 1 set of 235 KDWs and 5 sets of 245 KDWs all on factory rims.
Old Feb 23, 2011 | 07:52 PM
jboogie's Avatar
I think you'll get much more grip out of any of the extreme performance tires in a smaller size over a 255 kdw.
Old Feb 23, 2011 | 11:38 PM
How is the difference in grip as far as traction with those 245 KDWs compared to the stock tires? How much is a set of those?
Old Feb 23, 2011 | 11:58 PM
night and day for real. I was still at stock power when i made the move to wider tires, but the grip was phenomenal from 225 contis to 235 kdw, and i cut another 1.5 seconds to 245 size
id totally agree if I was autocrossing, but my home track is a power hungry track that begs for long duration traction.
Old Feb 24, 2011 | 12:11 AM
Holy damn!! Thanks for sharing the info. I have to get new tires for the summer and i was thinking of something like those
Old Feb 24, 2011 | 12:19 AM
CrystalRedSS's Avatar
Does anyone know what kind of increase in traction i would get going from the stock 225 conti's to 235/40 Nexen N3000's?
Old Feb 24, 2011 | 06:12 PM
Bumpin Balt's Avatar
Probably none. The Nexen's will have a harder rubber compound.
IROCZ0r
Nov 25, 2014 05:42 PM
Bumpin Balt
Wheels and Tires
54
Oct 26, 2014 09:21 PM
Lero593ffdkfje9
Wheels and Tires
Mar 3, 2013 07:06 PM
Bumpin Balt
Wheels and Tires
13
Mar 19, 2011 11:15 AM
drewbroo
May 12, 2009 08:59 AM
