7163 zfr
Sweet. Hopefully you will notice lower underhood temps and maybe even get boost a few rpm's earlier. I am definitely interested to see how this goes as I may do the same this winter. For now I just put a turbo blanket on to lower temps a little.
Keep up the good work.
Thanks it's turning out really well!
Ceramic coating is a insulator so it keeps under hood temps lower but since it's also on the inside on the pipe it lowers EGTs cause the heat likes to leave not soak into the metal as much
I could port my o2 housing for stock turbo but i have a 2.4 so the results would be different on an lnf. I also have a ported exhaust mani outlet and ported turbine housing. Single scroll mod
Cyl head is back and looks beautiful! Will be throwing on soon after I finish some more stuff and order my actuator. I can't wait to see what this thing can do now that she can breath!!!
Any superb numbers with pump gas? If I ran meth or E id have very similar numbers that you did get with the 7163. People say it's not safe but I've been revving to 7200rpms for the last 2 years now.
