Superchips
Old Jun 27, 2009 | 04:21 PM
  #401
elecblue06's Avatar
Originally Posted by sherm420
ya if i went thru another universal tune i would go with SC but since ive been hp tuned no problems and car is runnin strong, but the trifecta tune just wouldnt work for my car i dunno...
so did you get the 3rd cyl misfire figured out ? what was it .. and did you try to trifecta tune after you got that fixed or did you go with hptuners then?
i'm just curious to see what was up with your car since i remember there were issues some people were saying it was tune related others were saying hardware related.. you said you had some misfires before you got tuned .. and it got worse after you were tuned.. that suggests it was hardware related but i'm just curious so I don't go spouting off wrong info..
i'm not saying trifecta's perfect.. but posting that going with trifecta WILL make you have problems is ignorant.. just as ignorant as saying trifecta isn't a custom tune..
Old Jun 27, 2009 | 04:27 PM
  #402
sherm420's Avatar
ya i had a hole in my cp but that has since been fixed but the hp tune was put on the car without problem being fixed and it worked perfectly...no misifre so i have no idea....not saying trifecta caused it just saying trifecta didnt work on MY car, i guess we will see im gonna buy a new 3rd cyl coilpack just to be sure
Old Jun 27, 2009 | 04:51 PM
  #403
elecblue06's Avatar
haha wow .. yea a hole in the charge piping will DEFINITELY F with the AFR but the misfire is weird
well glad you got it worked out though.. sorry trifecta didn't work for you
Old Jun 27, 2009 | 04:52 PM
  #404
steven6870's Avatar
Does anyone know why the HHR is putting down +20HP/25FT/LB more than than the cobalt with the superchips tune? IS this seriously because of the intake?
Old Jun 27, 2009 | 04:57 PM
  #405
drewbroo's Avatar
intake and 93 octane tune, also its tunes have been around a bit longer.
Old Jun 27, 2009 | 08:12 PM
  #406
steven6870's Avatar
^^^Didnt really think about 93 and length of tune being out. Thanks.
Old Jun 27, 2009 | 09:08 PM
  #407
det_lions87's Avatar
Well I've had my car superchips tuned for around 500miles and through a CEL today. P0302. Cylinder 2 misfire...
Old Jun 27, 2009 | 09:43 PM
  #408
steven6870's Avatar
hmmm...plugs or coils? Replaced them recently? Obviously it cant be compression loss...although a good way to tell is park on a very steep hill and leave the car in first, see if she rolls, although I doubt this is an issue on a new 08/09 SS/TC. And the only other thing it could be is AFR. What are you AFR numbers looking like? I dont even know what SC adjusts these too. You running aftermarket intake?
EDIT-Saw your sig. Hahn intake...try putting stock air box on and see if it misfires. I am willing to bet it wont.
Old Jun 27, 2009 | 09:52 PM
  #409
MaxVQ35DE's Avatar
can we dig up any documentation on that HHR tune?
Old Jun 27, 2009 | 11:01 PM
  #410
drewbroo's Avatar
I am running a Hahn CAI on mine with no codes. Running the car hard in wet weather can cause the missfires, and not letting it properly warm up too. I don't drive my car until it settles its idle well below 1K.
Old Jun 27, 2009 | 11:09 PM
  #411
V8e12's Avatar
I think many have downplayed the complexity of tuning this motor.
its a DI motor that uses unconventional afr's and igntion-timing with infin. variable cam phasing,
and while Im sure people like Trifecta, etc. are talented, HP tuners doesn't have complete control over the ECU
One would have to think that The PPC and Superchips people crack the ECU their own way
and maybe have a different amount of control over the ECU
Whatever the case its less aggressive
PPC has experience with all sorts of euro gas and diesel turbo motors from VW and others,
and Superchips knows turbo diesels
Trifecta seems to make power but.... idunno
Old Jun 28, 2009 | 06:51 AM
  #412
drewbroo's Avatar
excellant point
Old Jun 28, 2009 | 10:31 AM
  #413
MaxVQ35DE's Avatar
People may consider Vince the best at working with the LNF ecu (personally I think its Westers Garage), but superchips and BSR have much much more experience with forced induction. Whats great is that everyone learns from everyone
Old Jun 28, 2009 | 12:16 PM
  #414
VRCobaltSS/TC's Avatar
I had after market plugs in my car with the Super Chips tune and threw a code for misfire on #4 cylinder so I put the factory plugs back in and have had zero problems since.
Old Jun 28, 2009 | 01:07 PM
  #415
Sweetsandman's Avatar
I should be getting back up to the track sometime soon. I'm confident I could get my numbers lower. I was just figuring out this tune and how to drive it when they told me to get a helmet and then I broke that stupid solenoid wire. Luckily warranty covered it all. I'll be doing the zip-tie mod to that wire soon so I don't get the same issue again. And as soon as I find some time to get up to Big Shots I'll have this thing dynoed as well to give further ideas as to what this tune puts down. I'm much closer to stock than drewbroo so it'll be interesting to see how much things differ. I'll try to get some baseline numbers as well since I can just flash it back to stock.
Old Jun 29, 2009 | 08:29 AM
  #416
Donny Brasco's Avatar
Superchips is looking good in lieu of the mythical beast a.k.a. the LNF Stage 1 kit.
Old Jun 29, 2009 | 08:53 AM
  #417
Terminator2's Avatar
I tuned his car for him. His A/F was going rich at WOT because the air leak was pretty bad (hole the size of my thumb in the rubber hose on the hotpipe). His A/F was a full point richer then commanded because of that. He was misfiring badly on Trifecta's tune because Trifecta's tune is already very rich compared to everyone elses tunes so his A/F was in the 10s!!!! We did log one misfire at 6300 rpms on the third to fourth shift. If you want Brian Let me know when you plan on going to the dyno I can tweak a few thing for you to see if I can make you more power now that you have the CP fixed.
Old Jun 29, 2009 | 11:16 AM
  #418
elecblue06's Avatar
ahh i see .. ye athta would definitely screw with things
Old Jun 29, 2009 | 11:18 AM
  #419
Donny Brasco 2's Avatar
Guy's, thanks for all your feedback and enthusiasm. We are right there with you - as we are enthusiasts just like each of you. I wanted to jump in here and give you an update on where we are at with info on the kit.
There is no hiding that GM has gone through its fair share of some very rough times here this summer. In fact - GM has never been in a position like this in it's lifespan. So there are a lot of new things that they are learning as they go through everything that the Government is taking us through. With all of that, GM has stayed very focused and loyal to what and who they are. It's under more extreme pressure and harder to do things that have been easy in the past - but so is life right?
We are working hard to provide an update for you. Believe me, your thoughts are not falling on deaf ears. They are working as hard and fast as possible to be able to push this out for all of you. As you can imagine, there is more red tape for GM to do anything "normal" right now - given the state of affairs.
I ask that you be patient and stay tuned here for updated info. If you will give us that, I promise we will serve you with respect and the way we would want to be treated.
On the other hand, if you cannot wait and do not want to - we understand that as well. That is what is so wonderful about this country that we all live and work in - you have the free right to do what you feel is best for you. We still respect that and always love to hear how you did with your upgrades and what worked and what didn't.
As for us, we are one of you. Normal Americans that are working as hard as we can to provide the best service as possible. We will not let that ever slip and will only get better over time. Thank you for all of your continued support and love that most of you share with us. The feeling is very mutual.
Have a great day. We are back to work to hunt down what you are all waiting patiently for!
FAILLLLLLLLLLLLLLLLLLLLLLLLLLLLL
Old Jun 29, 2009 | 11:24 AM
  #420
wantedSS/TC's Avatar
ugh ....
Old Jun 29, 2009 | 11:37 AM
  #421
austinss's Avatar
Just ordered the flashpaq from autoanything for $305, should be here on thursday!!!!!!
Old Jun 29, 2009 | 12:27 PM
  #422
I'm about to do the same....
Old Jun 29, 2009 | 02:46 PM
  #423
I only have 3000 miles on my car.. is it really necessary to replace the plugs or coils this soon? I deleted the code and it hasn't happened again, should I call the dealership and have them check it out?
Also I had to put some 93 octane fuel in because I was about to die and it was either that or 89. Do you think that could have caused the misfire?
Old Jun 29, 2009 | 02:48 PM
  #424
drewbroo's Avatar
you have to have 91 or above in your car period, tuned or not. Never use 89 or 87
Low oct will cause knock and missfires. 93 Octane would not have been the cause, I put sunoco 100 in the other day with no issue. (felt faster too)
Old Jun 29, 2009 | 03:34 PM
  #425
As the superchips 91 octane most certainly uses the stock timing the 100 octane should not make any measurable difference. In fact, most of the time it will show a slight decrease in performace because of the higher combustion temps required to burn 100 octane. If you modified your timing table to reflect the use of 100 octane it will show decent gains (10-15 whp) but on stock timing it is just placebo effect.
