Bullseye Power Batmowheel for Ko4
Old Mar 19, 2012 | 08:22 PM
  #826
2010SS's Avatar
Useless then...
Old Mar 20, 2012 | 10:17 AM
  #827
Terminator2's Avatar
Originally Posted by RYRO14
Here is the dyno runs, I did change the tune for the Batmowheel due to the tune spiking 30 PSI (didnt want to risk the motor). The Batmowheel was on a 24 PSI tune with a little more timing than the 30 PSI stock turbo tune. That is also why the torque is lower for the Batmowheel than the stock turbo run.
Timing was only 15* due to the knock showing on the logs ( I think it was false knock but Idid not want to risk the motor).
Old Mar 20, 2012 | 10:29 AM
  #828
RoadconeTuning's Avatar
so does that mean that with 24psi and 15* of timing the batmowheel made the same hp up top as a stock turbo at 30lbs?
Old Mar 20, 2012 | 11:03 AM
  #829
Chevycobaltss3's Avatar
It's not gonna make much more whp at 30 then 24 since its a spike.. if the boost was kept more linear it would but not a spike.. it also depends on car.
Old Mar 20, 2012 | 11:18 AM
  #830
Well the boost drops off from 30 psi up top but yes. His other tune was 3* more timing which is scary with the 30 psi spike and the amount of midrange timing it had. I think he may have something causing false knock because it seemed like no matter how much timing I pulled or added it showed 3* of knock on the logs we did.
Old May 22, 2012 | 10:47 AM
  #831
ford's Avatar
Why is this still a sticky if it proved pointless and not cost effective?
Old May 22, 2012 | 11:13 AM
  #832
40rty's Avatar
Man, amazing how this fell off the face of the earth.
Old May 28, 2012 | 10:11 PM
  #833
MastaShaKe_88's Avatar
so nada eh?
Old May 28, 2012 | 11:27 PM
  #834
Matt M's Avatar
People just need to be realistic. The K04 already makes more power than most turbos it's size. Switching to a slightly different shaped compressor wheel of the same size is not going to produce 50hp gains. It just doesn't work like that.
Old May 28, 2012 | 11:32 PM
  #835
Sonicyeller's Avatar
**** this ****. Get NAWZ!
Old May 29, 2012 | 12:24 AM
  #836
EXsoccer1921's Avatar
pretty much why i stopped posting after it left my hands lol
Old May 29, 2012 | 01:28 AM
  #837
haha i was more into it for potential... Stage1 cams wont net 50whp but they'll def help make more power.. My question (without skimmin thru 34 pages) was, Will this Batmanmopowheel help make more power, or is it jus somethin to add to my mod list to impress the cool kids with their supras?
Old May 29, 2012 | 09:28 AM
  #838
Unless you want to run a 34 psi spike tune it will not add any measurable power vs the stock turbo.
Old May 29, 2012 | 04:49 PM
  #839
Matt M's Avatar
Pretty much. We had to beat the crap out of both setups to see a solid difference. Most improvements would be in the 0-5hp range.
Old Apr 12, 2013 | 11:16 AM
  #840
vahdyx's Avatar
So it's a good cheap stock replacement or no
Old Apr 12, 2013 | 01:21 PM
  #841
RooTBeeR's Avatar
Needs double batmowheel on efr
Old Apr 13, 2013 | 04:13 PM
  #842
40rty's Avatar
Unsat for bringing such a dead product out.
Old May 18, 2014 | 10:59 PM
  #843
tomj77's Avatar
idk why people waste their time with this stuff, take off turbo, new compressor wheel, put it back in, all that work for pretty much nothing. why not do that work and put a zfr on and ull have the power u want and u don't have to screw around trying to push k04 to the very edge of its ability and still be unsatisfied after a week of running that.
Old May 19, 2014 | 02:02 PM
  #844
40rty's Avatar
idk why people waste their time with this stuff, read through an old thread and then post on it when no one has for about a year to revive a thread that has already proven that the product isn't worth it. The end result of you reading all this(Your opinion) was that its not worth it. Great!! but I hate to break it to you.... your very late to the conversation. Did you ever see it pop up in ZZP's product line over the passed 2 years? No right? That should of been the clue to not even bother. Noob ****.ing move there governor.
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
ernnyyes
Oct 2, 2015 05:16 PM
717ssbalt
Oct 2, 2015 04:01 PM
Stuff
Oct 1, 2015 05:47 PM
