Knock and Misfires
Old Mar 5, 2011 | 12:44 PM
  #126
meckel's Avatar
Originally Posted by drewbroo
I understand they are looking good, but after you clean the maf and change spark plugs its a good idea to send it in to see if any of the readings were skewed due to the bad plug or dirty MAF. Just putting that out there, its your car do what you want.
Was going to do this anyway, I thought you were referring to sending him more logs with the way the car is running now. Sorry about glghe confusion on that, I'll definately be monitoring the car after all of this is done.
Old Mar 5, 2011 | 09:53 PM
  #127
silverbullet08's Avatar
Originally Posted by MTE
if your running on the trifecta tune constantly chances are you will go through spark plugs allot so keep that in mind.
Just cause you have a tune you shouldnt go through spark plugs constantly. If you cant keep a set of plugs in the car for a decent amount of time then something is wrong with your tune, your running too much timing or too much boost. Before you destroy another set of plugs go make a long 3rd gear pull on your car then pull the plugs out and check the timing marks. evaluate and go from there.
Old Mar 7, 2011 | 08:55 PM
  #128
MTE's Avatar
MTE
ummn, that sounds good, Ill get a run tomorrow and download new data for a re-tune.
Old Oct 11, 2011 | 11:52 AM
  #129
vahdyx's Avatar
So I was experiencing the same thing with my TF tune but Vince had a different response. He said he will safely tune mine out and he's thinking since its under light load he thinks its mechanical noise. So there could be a chance that it's nothing to worry about.
Also I spoke with a local shop about dyno vs street tune he said its good either way but they prefer to dyno tune and edit it on the street.
I also texted 542542 for you guys LOL and their response is, "The best tune is a combination of dyno and street tuning. Start with a street tune, and refine the tune on the dyno. kgb_ team" LOL
Anyway im indifferent, but it was a fun read.
Old Oct 11, 2011 | 12:29 PM
  #130
Knightwolf's Avatar
Don't have time to read all of this.. and I see it's an older post as well.. I also see the Op is in Alberta like me.. so what are your mods? When's the last time u changed your oil and what are you using? Also, what plugs and gap are u using? I've had problems too in this area and I've found a solution for my particular instance.. if u still have problems Pm me and I'll tell ya what worked for me. Nothing wrong with Vince's tunes as long as you logged them and he fine-tuned. I'll leave it at that for now.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Sean Cummings
Mar 9, 2018 12:26 AM
717ssbalt
Oct 2, 2015 04:01 PM
Tupp
Sep 30, 2015 08:18 PM
twilson380
Sep 14, 2015 10:52 AM
