LNF Valve Gunk..
Old Nov 2, 2012 | 11:39 AM
  #201
Sox-Fan's Avatar
Got Brakes?
Our engines are more susceptible to it because there isn't a constant flow of gasoline (which has detergent additives) across the back of the valves, but it doesn't mean you are guaranteed to have carbon buildup on the valves.
Certainly seafoaming regularly helps prevent build up, but once it's there seafoam will not remove it.
Keeping the RPMS up a little helps, though the more important thing is just not lugging it so the cylinder temp doesn't climb.
Keeping the oil clean helps of course, as does running a lower ash oil base.
And a good air/oil separator for your PCV system keeps the engine from sucking blowby oil back into your intake and across the back of your valves. That's where John's new setup will help considerably.
Because let's face it, any engine is going to get some blowby as they age. If you can catch that oil before it gets baked onto the back of your valves you'll extend the life of your engine.
Old Nov 8, 2012 | 03:26 PM
  #202
vahdyx's Avatar
Powell suggested I get a Baroscope, but they're expensive. How do you guys check without one? Something a novice like myself can do without too much **** up or is it something I should just wait on.
Old Nov 8, 2012 | 07:44 PM
  #203
bspeed's Avatar
Where would you put the bore scope in to get a good view of the valves I have one
Old Nov 8, 2012 | 08:14 PM
  #204
Powell Race Parts's Avatar
not easy to get them all, but remove the vacuum booster line and fitting from the IM it gives you a nice big orifice to go in with. Good luck.
Old Nov 9, 2012 | 10:01 AM
  #205
gone_in_10_sec's Avatar
Originally Posted by CobaltItaliano
So I have to jump in on this. So this valve gunk just appears because the LNF is DI?
I'm in the market for an LNF, but only as a DD (not a track car) would this be a huge issue for me?
This thread has gone back and forth on seafoam working/not working, some people up to 80k miles and never did anything and their car still running perfect. So just trying to figure this all out. I would plan on owning the TC forever so is this valve gunk going to cause an issue for me?
Using the LNF as DD isn't going to be huge issue at all, the problem is being on top of everything and making sure everything is ok.. [fluids/ not beating the car up/ etc..]
With John's Powell new product, it will cure 99% of the problem, BUT you will still need to be on top of it.. (checking the oil and add oil, using quality oil [Mobile 1], quality oil filters [K&N or AC/Delco], Seafoam with every oil change).. once your doing this the car should last for along time.. maybe over 200k+ miles..
Old Nov 9, 2012 | 07:36 PM
  #206
blrt's Avatar
I guess the thing I have going right for me is have a higher revving 4.45 gear, my commutes is around 35 miles each way 90% of the time, let my engine warm up close to operating temp before driving off, low ash oil or zinc additive is a double edge sword giving up some antiware for less coking in the oil. Getting John's pcv kit will further help fight the gunk.
Old Nov 11, 2012 | 03:18 PM
  #207
As long you keep an eye out for the oil coking, then your car should last for a long time.. as long as you don't beat on it..
Old Nov 11, 2012 | 04:20 PM
  #208
cw383's Avatar
4.45
Hey BLRT, how did those 4.45's effect MPG's and daily driving? I thought my 1st gear was all but useless due to having to hit 2nd at about 20mph.
Old Nov 11, 2012 | 10:22 PM
  #209
blrt's Avatar
I suppose spending $2K to rebuild my head/valve at 100k miles seems reasonable to me?
Old Mar 5, 2013 | 08:32 PM
  #210
Mr Al's Avatar
after reading a ton of posts on gm sport compac, the best solution for me IMO is the walnut shell blast..
yes - it costs a few coins - but after looking the "before" and "after" for what the BMW/Audi/MB guys have done already to cure this problem.. it's a no brainer..
doing the walnut blast and coupled with Powell's PVC product.. this could minimize the coking to a point, provided the walnut blast is done once a year and Powell's PVC product is clean & working properly..
Before "Walnut Blast" pic - I though this was the intake valve in the middle of port - that not bad oil coking? oh'boy was I wrong..
After "Walnut Blast" pic - look at it sparkle!!
How much is a few coins? I need to budget this in a couple years.
Thanks,
Al
Old Mar 5, 2013 | 08:35 PM
  #211
Sox-Fan's Avatar
Got Brakes?
24.99 for the gun
1 Liter Abrasive Blast Gun
23.99 for the medium
Fine Grade Walnut Shell Blast Media - Harbor Freight Tools
Old Mar 6, 2013 | 08:49 AM
  #212
user 72239's Avatar
Originally Posted by Sox-Fan
wow. i didnt know you could buy that stuff from Harbor Freight.
Old Mar 6, 2013 | 09:10 AM
  #213
Chevy_tuner's Avatar
Looking at the pics..........walnut blasting can be done with the head still installed?
No worries of some entering the cylinders?
Old Mar 6, 2013 | 09:21 AM
  #214
Sox-Fan's Avatar
Got Brakes?
You can do it head on. That's how BMMW does it for their DI motors. You need to make sure the valve is fully shut, so that means rotating the engine over as you go through the valves in order. If you do happen to get a tiny bit in there.... well, it's walnut shells, not sand or silica.
Old Mar 6, 2013 | 05:57 PM
  #215
umrdyldo's Avatar
Forgive my ignorance but what is the correct procedure of rotating the engine for this?
https://docs.google.com/file/d/0B3Ta...aEE/edit?pli=1
Old Mar 6, 2013 | 06:21 PM
  #216
Look in the port once the IM is removed. Put the car in 4th gear. roll the car forward or back until you see both valves closed. work on that port. repeat until all four are done. (thats the easy way) OR Remove rocker cover and rotate motor the same way in 4th gear to you can see the inlet cam lobes peaks facing upward on the one cylinder, then those valves are closed. Repeat 3 more times. lol
Old Mar 6, 2013 | 06:24 PM
  #217
correct walnuts are wood and burn harmlessly.
WARNING proper shielding with a blanket to cover all ancillaries is recommended, the walnuts get everywhere (especially if you have your mouth open lol)
and the HF el cheap gun needs a decent tip so buy an extra good tip with a flexible extension to get in the port easily...
Old Mar 6, 2013 | 06:29 PM
  #218
user 72239's Avatar
Subbed. Going to probably do this here soon to get rid of the gunk and then buy powells catch can.
Old Mar 6, 2013 | 06:32 PM
  #219
Please its a seperator, not a can lol. Talking of the bandwagon, Lingenfelter are using the same style seperator |(only the 200 series which is much larger) for their LS motor conversions now. A lot more money of course.
Old Mar 6, 2013 | 10:14 PM
  #220
FMSR Performance's Avatar
Thanks,
Al
Normally walnut blast is around 3-500 depending on how bad it is..
We provide this service.. pm me.
Old Mar 6, 2013 | 10:27 PM
  #221
John sent email..
Old Mar 7, 2013 | 06:15 AM
  #222
QuickSilver_SS's Avatar
What psi would we run that gun at to clean the valves? Also, what extra tip should we get? And if some walnut blast does get into the cylinder. Will it destroy the walls? I guess after blasting the valves i should vacuum up inside the valves as well as blow some clean air in there to remove any left over blast material?
Old Mar 7, 2013 | 08:04 AM
  #223
Sox-Fan's Avatar
Got Brakes?
Nothing happens if some gets in the cylinder if it's only just a tiny amount. It's wood, it'll burn. That's why you use walnut shells, not sand or other silicate abrasive.
Old Mar 7, 2013 | 08:21 AM
  #224
I kind of figured wallnut shell was used for a reason and wouldn't hurt the cylinder if it got in there. But i just wanted to make sure. Any idea as to how much psi to run through the gun. Any where from 25 to 150 ??
Old Mar 7, 2013 | 05:41 PM
  #225
idrinkV8's Avatar
90psi for the gun from HF ^
