SynapseTurbo's Initial testing 365whp 359wtq
Old Nov 6, 2008 | 03:50 PM
  #101
psychophyr's Avatar
Originally Posted by 06black
you don't know how power is calculated do you.......
horse power is a function or torque and RPM.
as you can see there, power climbs all the way to redline, with the curves both intersecting at 5252rpm as per expectations, and math.
the torque curves drops as rpm climbs because its inverse the RPM count.
quite simple my dear man.
  #102
cakeeater's Avatar
hp = torque*rpm/5252.
Old Nov 6, 2008 | 04:10 PM
  #103
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Originally Posted by Runnerdown
Its not the compressor wheel, there is a graph of a gt35r in another thread that drops tq just as hard
The 35r has a way bigger turbine wheel. Im talking about small turbine, big compressor, this engine would love that.
Old Nov 6, 2008 | 04:19 PM
  #104
steddy2112's Avatar
Tasty...
Old Nov 6, 2008 | 04:20 PM
  #105
06black's Avatar
thats the recipe for any "street car" with big power admirations.
Old Nov 6, 2008 | 04:26 PM
  #106
lewisb13's Avatar
True that. I think if they would keep their current turbine size the same and increase the size of the compressor, theyd have a "mostly" stock powerband with the added boost in there. Just my 02
Old Nov 6, 2008 | 04:51 PM
  #107
Terminator2's Avatar
Originally Posted by 1badBlueberrySC
Still falls on it's face after 5500 though...... hmmmmmm
The stock head and cams are probably holding it back a little. Good numbers, but tune needs some tweaking no doubt.
It is breathing through their 3" downpipe but still has the stock 2.5" exhaust switching to 3-3.5" will show decent gains in the top end. what troubles me though is the loses down low hopefully they will be able to fine tune to help low end power.
Old Nov 6, 2008 | 04:58 PM
  #108
1WhiteSSTC's Avatar
just wait till steve gets there and does some extra fine tuning on it
Old Nov 6, 2008 | 05:18 PM
  #109
Baldturbofreak's Avatar
Actually a bigger compressor would likely exacerbate the turbo lag seen here. It's a lower trim,bigger turbine that would benefit most here. It would reduce the turbine inlet pressure considereably, generating pressure sooner due to the higher turbine efficiency.
With that nice header they got there, they would move much closer to the coveted positive MIP/TIP ratio, where for a narrow band there is more intake then exhaust manifold pressure. THis nets huge torque returns and can reduce egt's in a DI motor since most fuel is injected during intake only and a small amount during the compression stroke if your really stuffin' the lbs/min thru there.
We dont have full control yet but changing the beginning of the injection event to happen later would allow air only to bypass to the turbine during certain ranges. reducing EGt's.
Old Nov 6, 2008 | 05:20 PM
  #110
peachpuff's Avatar
I wish we could we are waiting on Hptuners software revision for that.
The currenty version allows you to increase the rev limiter, just increase oil temp limit, trans limp, transiant limit, normal and short incr in fuel control>fuel cutoff.
Old Nov 6, 2008 | 05:55 PM
  #111
Tomtwtwtw's Avatar
basically as RPM climbs, torque past 5252 will always drop.
I'm sure you meant to say something different than that. Otherwise a Honda Si engine couldn't have peak torque at over 6k rpm.
Old Nov 6, 2008 | 06:28 PM
  #112
SynapseTurbo's Avatar
Thanks, raised, time to hit the dyno again tomorrow.
Old Nov 6, 2008 | 07:12 PM
  #113
Edubs's Avatar
I think you'll be okay here, they have a thin candy shell. 'Surprised you didn't know that.
Old Nov 6, 2008 | 09:29 PM
  #114
06black's Avatar
notice i said its all related to how the engine builds power past that point.
the VE of that motor becomes MUCH greater in that rev section due to the cam change over.
VARY few engines do such a thing.
the larger turbine would require more shaft inertia to "come up" thus requiring more energy, while i agree with the trim note, the larger size turbine wouldn't benefit here.
i'd much rather see a 4-4.5mm bump in compressor wheel size for air flow Vs a 6mm jump in turbine size for efficiency. (those are just common size jumps from where they are now)
also, a lager comp wheel could be attached to the 28r CHRA shaft, if you bump the size of the turbine / the motor of the turbo i'd bet shaft size would have to jump to sustain the rotational forces that this larger turbine would generate.
This would require even more energy. not only from the larger shaft, but from the larger barring race's (sp?) as well.
if i missed something here, please let me know, you seem educated on the topic and I'm always game to pick things up.
yea, thats just what they need now....
ugh.
Old Nov 6, 2008 | 09:33 PM
  #115
We shouln't jack this fella's thread, but if you want to move it to a new one I always love talking turbo tech.
Old Nov 6, 2008 | 09:52 PM
  #116
AaronHHRSS's Avatar
This is very promising. Still, I'd like to see it spool sooner.
Old Nov 6, 2008 | 10:33 PM
  #117
06black's Avatar
good call.
my bad OP.
Old Nov 7, 2008 | 12:41 AM
  #118
hawkeyez's Avatar
Nice numbers guys.
Old Nov 7, 2008 | 11:08 AM
  #119
boostking's Avatar
any updates with some more rpm.
Old Nov 7, 2008 | 11:54 AM
  #120
40rty's Avatar
So for the torque to go up some are you going to have to change out the camshaft?
Old Nov 7, 2008 | 12:35 PM
  #121
06black's Avatar
no no no.
Just like I was saying before, tweak out the cam timeing in a specific mannor and u can spool a large turbo vary quickly.
Vvt and turbos go hand-in-hand.
I went over the basics of what to do in a preveious post.
If these guys keep it up, they will have THE kit to buy, simply because tweaking the cam timeing ontop of proper ign adv and fuel will give them set ups that make more power and respond quicker then the guys who sell a kit with a tune that's not optimized.
Kudo's to synapse once again!!!
Like I said before, can phase, cam phase, cam phase!!
Old Nov 7, 2008 | 01:17 PM
  #122
Psykostevo's Avatar
Originally Posted by camarokiller
I lol'd when i saw who the tuner was
I have not yet tuned this car, this was tuned by their in-house tuner up to this point.
No it doesn't appear to fall on it's face. Torque falls off after 5,250 on almost all cars because of the formula used to calculate hp etc. It was still making power up to the top of the chart.
Old Nov 7, 2008 | 07:24 PM
  #123
2JZ4ME's Avatar
LOL
Ehhh Neeoope. Torque drops... Because the intake mach number starts to get much too high. "runs out of breath"
Old Nov 7, 2008 | 08:32 PM
  #124
Sw4y1313's Avatar
Originally Posted by 2JZ4ME
LOL
Torque always drops at 5250.... Has nothing to do with the turbo.
Old Nov 7, 2008 | 08:36 PM
  #125
slowswap's Avatar
Torque does not have to fall past 5250. HP and torque will always cross at this number. It does NOT mean it will fall.
