SynapseTurbo's Initial testing 365whp 359wtq
Old Nov 5, 2008 | 07:14 AM
  #76
06blackg85ss's Avatar
Originally Posted by 40rty
I only wish the transmission was beefier or there was a way to make it stronger. Other than that i would drop 10G's for synapse's kit and axles and Eibach springs. Let me know when you guy are up for the GB, ready!!!! **** GM for abandoning us Cobalts.
yup are tranny's won't take 400wtq.... Don't tell mine that.
Old Nov 5, 2008 | 07:49 AM
  #77
SynapseTurbo's Avatar
Got a few cars on the dyno today, hopefully we can get the cobalt back on the dyno tonight for some more testing.
Old Nov 5, 2008 | 07:55 AM
  #78
duke3323's Avatar
From: no longer a kansas member i live in GA ALPHARETTA
are you really using Psykostevo to do your tuning and how do you go about picking tuners on here
Old Nov 5, 2008 | 08:13 AM
  #79
Up to this point we have done all our tuning in house, no one has touched our tune or car but us. We will spend alot of time on the dyno trying diffrent thiings and parts. If everything looks the way we want them, then no outside tuning will be done. Our goal was to provide the best and the most complete kit available, not something you slam-dunk together with no other proper supporting mods. When we are satisfied with the results then we will release it to the public, this was "initial testing" and up to this point we are happy with the results as we have been building the hardware for it the last 2 months.
Old Nov 5, 2008 | 10:54 AM
  #80
psychophyr's Avatar
Pleeeease get some vids of the tc dynos
Old Nov 5, 2008 | 11:28 AM
  #81
krispy's Avatar
is it just me or does it seems like how the torque curve was affected and how the HP curve would keep increasing past redline that this turbo is too big?
Old Nov 5, 2008 | 11:36 AM
  #82
PimpLay2's Avatar
you know me, have 2 subscribe
Old Nov 5, 2008 | 12:05 PM
  #83
IonNinja's Avatar
the dyno only reads to 6100 rpm
also they tend to rev it out a bit which is why they chose a bigger turbo
Old Nov 5, 2008 | 04:50 PM
  #84
peachpuff's Avatar
Originally Posted by 06blackg85ss
well there's your lag
I agree, the gt2871r is a mid size turbo and should be treated as one. The turbine housing/wheel should be as small as possible for instant response but still be decently sized so it doesnt choke at the top.
Theres a dyno sheet on hptuners forum with a GT3582R on the lnf, its a much bigger turbo yet spools identically to the gt2871r.
Old Nov 5, 2008 | 04:53 PM
  #85
08BlackSS/TC's Avatar
I was going to post that dyno sheet but I said nahh
Old Nov 5, 2008 | 05:10 PM
  #86
I just tuned a 600hp 2.0l honda with a race motor today, gt3582r, and full boost at at 5500rpm, so I am going to have to disagree. This head has been flow tested at 305cfm.
But I will let you guys make your judgments when you see some street video, your not waiting for anything.
Old Nov 6, 2008 | 08:37 AM
  #87
boostking's Avatar
GT2871R - 743347- 2 with a 71mm, 56trim, .60 a/ FTW. would this turbo work with your components? I have some good friends that work for garrett so I will be buying the turbo direct from them. but wish to use many of your products. please pm me when I can start buying your parts! got cash in hand....
Old Nov 6, 2008 | 08:44 AM
  #88
stage2's Avatar
plz post a street vid .....thank you
Old Nov 6, 2008 | 09:05 AM
  #89
Baldturbofreak's Avatar
I have had the 2871 and 3071 on a few differnt cars 2.0,2.4. They seem to be a bit more sluggish than their slightly larger brothers. I beleive it's the ratio of turbine eff to the compressor it's turning.
Also the trim is pretty large on the back side, making the velocity across the turbine volute slower. THis was done for turbine flow at the cost of turbine efficincy.
Edit- I just double hecked, for sure the spooltime has to do with the turbine efficiency. that particular model's turbine map is only 66% efficient.
What this means is that it takes more pressure delta (mroe turbine inlet pressure) across the trubine to generate a given shaft torque. I.E. it takes more turbine pressure to make a certain intake boost when compared to some of the other offering where turbine efficinecy is in the low to mid 70's.
That being said they are great turbo's and flow very well for having an internal gate.
I'll ask again, what gear was the pulls made in?
Old Nov 6, 2008 | 09:16 AM
  #90
boostking's Avatar
I was looking at your pics and I see the car has not been map clamped. clamp that car throw some meth and full exhaust and you have 400whp+ easy!
Old Nov 6, 2008 | 02:04 PM
  #91
Runnerdown's Avatar
After cam tuning, our powerband was drastically increased, and with the help of our superior tubular manifold we are able to make singificant peak power. Baldheaded, all of our runs are done in third gear.
Old Nov 6, 2008 | 02:08 PM
  #92
elecblue06's Avatar
holy **** .. overlay the new dyno with the stock one.. thats ******* crazy.. it has more power then 80% of cobalts by 4k
Old Nov 6, 2008 | 02:28 PM
  #93
Runnerdown's Avatar
Here you go...
Old Nov 6, 2008 | 02:30 PM
  #94
1badBlueberrySC's Avatar
Still falls on it's face after 5500 though...... hmmmmmm
Old Nov 6, 2008 | 02:36 PM
  #95
boostking's Avatar
rev that motor!!!!!!!!!!!
Old Nov 6, 2008 | 02:46 PM
  #96
Runnerdown's Avatar
I wish we could we are waiting on Hptuners software revision for that.
  #97
lewisb13's Avatar
From: Home: Utica, MI Current Location: Mobile, Alabama
Yep, definately need to increase the compressor wheel size.
Old Nov 6, 2008 | 02:49 PM
  #98
cakeeater's Avatar
not really. Power is still increasing at redline. The drop in torque isn't significant enough to outweigh the higher rpm's. Looks like a great powerband for the street imo.
Old Nov 6, 2008 | 02:56 PM
  #99
Runnerdown's Avatar
Its not the compressor wheel, there is a graph of a gt35r in another thread that drops tq just as hard
Old Nov 6, 2008 | 03:40 PM
  #100
06black's Avatar
you don't know how power is calculated do you.......
horse power is a function or torque and RPM.
as you can see there, power climbs all the way to redline, with the curves both intersecting at 5252rpm as per expectations, and math.
the torque curves drops as rpm climbs because its inverse the RPM count.
quite simple my dear man.
EDIT-
inverse is the wrong word to use, basically as RPM climbs, torque past 5252 will always drop.
the rate and amount are dependent on the power the motor makes up top.
