Treadstone stage 4 install!
Thanks guys, Glad we could help Manny out with his install. Should make some good power today.
Angel's car was stock head and cams, My car (Ramon) was stock port/valves but had BC cams/springs.
yea we couldnt keep a set of axles in it and when it was on the stock ka transmissions, i broke about 8 of them lol.
yup thats true, guy bought my motor didnt retune it and took it racing and blew it up.
Thats actually Angels girlfriends car. We have more pictures on our facebook page.
RaceLab - Automotive - Miami, FL | Facebook
Most screens are actually more restrictive than a normal k&n filter and still wont stop the smaller sand/dirt particles that will mess it up anyway.
looks like he's just using the vacuum line for the bov only from the mani and going to tune out the sensor that normally controls boost release/wastegate release on our stock setups.
ill prolly do the same once i pick up my new turbo.
op are you going to use a boost controller or how are you working that out?
i
i
The line goes directly to the intake manifold, not the cold side pipe. A BOV cant work without a vacuum signal. We also removed the Boost control solenoid off the factory turbo and reused it, so he can still control boost with the factory PCM.
We encounter some problems while trying to tune the car, at first the car wouldn't boost past 3-4 lbs no matter what, so we open the hood and Joe changed some Vac lines with the Help of Jason (Treadstone), now the car goes unto Boost just fine but, its just way to fine or so it sounds like. Well, now the car jumps to 26+ Psi of the bat and the engine shuts it of, like the pcm is panicking somehow, so we are unable at this time to get a full throttle log with hp tuners. I I'm wondering if its something to do with the E85 Mixture the I have and since its a bigger turbo its sucking in more air then fuel!! or should it be? Also there's this, the Wastegate has 2 springs in it, a 21 lbs and bigger one to make 25 psi total in it. I was going to remove the bigger spring and leave only the 21 lbs spring and c if that helps, if not then try and run the car on 93 octane only. But, as of right now the car its untuned and wont get donw hopefully till Saturday. Ill put up some pictures of the current setup and wher all the lines are going to, give me some ideas....Thanks.
Current setup
Factory Boost controler!!
Do I need any hoses to go through this?
Thanks.
Current setup
Thanks.
LNF manifolds do tend to leak, i've seen a couple.
On MTE's car, I was looking over the one time I got it to try and spool for more than a second and it is also running out of fuel. Needs to go back to the 14psi spring and tune from there, so I can increase boost marginally and see where we tap out the fuel system.
And also, if you don't have a base file your not gonna run correct. Ecspecially into boost. You'll pop and crap.. so add fuel on top.. just guess it, and while logging look at fuel trims .. in that area, and add little by little.
I don't really understand why the bigger spring was used, on a stock engine daily driven car i'd want to be able to lower boost a little bit if needed, and use the stock controller to raise it as needed.
I've also tuned more then cobalts. My point is that I'm making here is all his stuff his hooked up wrong, and if the tune is not even close it'll spit a **** ton of fuel and act like its getting to much
Do you know who ended up with your car? I'm just curious who has a built motor floating around.
Last edited by ItalianJoe1; Feb 16, 2012 at 06:09 PM. Reason: Automerged Doublepost
