Treadstone stage 4 install!
Old Feb 17, 2012 | 01:25 PM
  #101
MTE's Avatar
MTE
Ok, took the Wastegate apart while under the car and since it was upside down you can immagine the work, anyways, it had 2 springs in it, a green one and a yellow one, the yellow one was HUGE so I removed that one, put the W/G back together and drove it, the car now see's constant 21/22 boost and holding it, just at the end of each gear it spours so its something to do with the Pdi (ez) fix. Now if that green spring is 21 lbs, what the hell is that other huge as spring inside of it...lol.....in tomorrow for another tuning day and c, if not Ill try going back to regular 93 octane.
Old Feb 17, 2012 | 01:29 PM
  #102
09BlueBaltSS's Avatar
I think u should give turbosmart a shout before u start disassembling and leaving out pieces of such a vital part. That spring combo probly added up to a certain pressure. Different combos different pressures
Old Feb 17, 2012 | 01:35 PM
  #103
jonathan923's Avatar
sounds like your running outta fuel up top like i told you.
Old Feb 17, 2012 | 01:37 PM
  #104
rallycobalt06's Avatar
It's your fuel map, it's got a nasty hole. That's why your unloading in third.
Old Feb 17, 2012 | 01:47 PM
  #105
Chevycobaltss3's Avatar
^^^ lol this guy..............hahaha.. but have Joe send me a log on the final ones.. ill look at it and send me the tune so if there is somthing I think that would needs adjustment
Old Feb 17, 2012 | 01:51 PM
  #106
sorry, i had to. couldn't resist.
Old Feb 17, 2012 | 01:54 PM
  #107
I would have if you didn't...
Old Feb 17, 2012 | 02:20 PM
  #108
Treadstone's Avatar
If there were 2 springs, its a 14psi and a 10psi spring. So you running the 14psi spring.
prob the boost controller is active to give the extra boost. Ive never scene that amount of boost with just a 14psi spring.
Old Feb 17, 2012 | 03:13 PM
  #109
Correct me if I'm wrong but a boost controller can only raise boost above what the w/g is set at so if the w/g was at 24psi and the controller is at say 23 psi wouldn't they be fighting each other and in a car like the lnf you would have tuning issues?
Old Feb 17, 2012 | 03:37 PM
  #110
You can control boost with the lnf pcmcia, yes is it more difficult to manage? Yes.but its possible. But you can not get less boost then rated spring
Old Feb 17, 2012 | 04:23 PM
  #111
BLAZIN07SS's Avatar
I'm too JDM for you
Originally Posted by Chevycobaltss3
Lmfao apparently you dont know lol. The lnfs are not like any other car now is it.... It's Tq based, so if you put commanded dals and mals in and then your not using the Pid controller what do you think happens. It's not like a lsj , yeah itll work but it will have drivability issues if not run through the pid controller.
It's a ******* boost controller. You act like your some god with this ****. Besides the fact that I know 2 big turbo lnf's running manual controllers just fine. It's going to read boost through the maps and make adjustments either way.
Old Feb 17, 2012 | 04:36 PM
  #112
Your correct it is a ******* boost controller. No Duh ... Did I say i was a god. No I ******* didn't. Using just a boost controller actually does cause drivability issues .. you calling for a.commanded dal and mal and also using proprtional, integral, and deriative gains and a wgdc. So therefore the ecm willl act as if its failing somewhere .... I've tuned.plenty enough of Tq based ecms to know what im talking about. The drivability issues may not be badly affected.but the cars power may or may not surge in areas or the car will shutter, stutter ect..
Yes you can disable all the codes, woopdy doo. But it still doesn't matter.. the car will act differently to just a manual boost controller then to the cars actual controller with a possible online manual controller.
This is from wiki
PID controller
A block diagram of a PID controller
A proportional–integral–derivative controller (PID controller) is a generic control loop feedback mechanism (controller) widely used in industrial control systems – a PID is the most commonly used feedback controller. A PID controller calculates an "error" value as the difference between a measured process variable and a desired setpoint. The controller attempts to minimize theerrorby adjusting the process control inputs.
The PID controller calculation (algorithm) involvesthree separate constant parameters, and is accordingly sometimes called three-term control: the proportional, the integral and derivative values, denoted P, I, and D. Heuristically, these values can be interpreted in terms of time: P depends on the present error, I on the accumulation of past errors, and D is a prediction of future errors, based on current rate of change. [1] The weighted sum of these three actions is used to adjust the process via a control element such as the position of a control valve, or the power supplied to a heating element.
In the absence of knowledge of the underlying process, a PID controller is the best controller. [2] By tuning the three parameters in the PID controller algorithm, the controller can provide control action designed for specific process requirements. The response of the controllercan be described in terms of the responsiveness of the controller to an error, the degree to which the controller overshoots the setpoint and the degree of system oscillation. Note that the use of the PID algorithm for control does not guarantee optimal control of the system or system stability.
Some applications may require using only one or two actions to provide the appropriate system control. This is achieved by setting the other parameters to zero. A PID controller will be called a PI, PD, P or I controller in the absence of the respective control actions. PI controllers are fairly common, since derivative action is sensitive to measurement noise, whereas the absence of an integral term may prevent the system from reaching its target value due to the control action.
Last edited by Chevycobaltss3; Feb 17, 2012 at 04:36 PM. Reason: Automerged Doublepost
Old Feb 17, 2012 | 04:39 PM
  #113
Now if you read through this, you'll notice you have commanded values and all three work together. So if the Pid is not seeing these values it will act differently ecspecially since its not seeing the actual wgdc or sending anything to control the wastegate.
Old Feb 17, 2012 | 04:40 PM
  #114
O yeah I'm also a big turbo lnf ad I run straight boost controller inline with my wastegate and Pid. Never said you couldn't do it..
Old Feb 18, 2012 | 11:41 AM
  #115
BLAZIN07SS's Avatar
I'm too JDM for you
Want to know how I know you didn't type this post?
BECAUSE I CAN ACTUALLY READ IT.
you continue to say it will act "differently". I really think you're just full of it.
Old Feb 18, 2012 | 11:52 AM
  #116
Lmfao yeah .. I did write that post there. You know the one you replied to.. the one before I even said it was from wiki. Lol. I'm full of it hahah. Yeah ok Mr zzp man.. lol .. tune a large lnf with just a boost controller and notice the differences. it will be a lil different. Lol.. ah .. your full of it.
Old Feb 18, 2012 | 11:56 AM
  #117
Lsj isn't Tq based is it ? Lnf is a Tq based ecm.. there's a big difference. Not once did I say you couldn't do it. I've done it before but i run the boost controllers in line .... Since its ran online the ecm still pushes the calibrations through the Pid and amcan control it.
Old Feb 18, 2012 | 11:58 AM
  #118
BLAZIN07SS's Avatar
I'm too JDM for you
You'll notice the difference. It'll be a little different. Go jump off a bridge or tie your hpt cable into a neuse.
Old Feb 18, 2012 | 12:13 PM
  #119
Lmfao comes from the guy who hasn't tuned a lnf larger turbo more then likely. So go jump off a cliff and sale Ure tuning cable since you wanna talk ****... Kid
Old Feb 18, 2012 | 12:14 PM
  #120
Little difference / difference. Still drivability differences ..
Old Feb 18, 2012 | 12:18 PM
  #121
BLAZIN07SS's Avatar
I'm too JDM for you
At least I can type like an adult and not like a ******* retard....kid
Old Feb 18, 2012 | 12:57 PM
  #122
Boosted4's Avatar
Why are there so many douche bags and haters on this forum?
  #123
Your right. Talk **** about online grammar! Your such a big kid....
Old Feb 18, 2012 | 12:59 PM
  #124
And boosted I'm not hating. Im just getting a correct point across lol..
Old Feb 18, 2012 | 01:01 PM
  #125
Boosted4's Avatar
This is Richard's buddy Wes. I wasn't talking about you James, I was talking about the flaming guy
